Question about Sony MDR-IF5000 Headphones
Sounds cuts in and out
This just started a week or so ago.... I'm watching TV with sound and all of a sudden it stops... Wait a few minutes and the sound starts back up. What is the issue?
davebies
  • 43 Answers
SOURCE: Power and sound turn off after 15 minutes
Is the red light blinking in the front of the tv. Counnt the blink sequence then I can give you more info.
Posted on Jan 05, 2008
SOURCE: Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Posted on Oct 21, 2008
welcomejee
  • 10594 Answers
SOURCE: HELP! KDFE55A20 watching TV and screen goes black and loses sound
Yes, its most probably lamp issue.
Please but original Sony lamp from Sony store and replace it in TV.
Posted on Mar 07, 2009
SOURCE: Sony KDL-32S3000 32in LCD TV.
Hi Chris,
I used to have the same issues with my 32S3000 but I've managed to fix it by factory reset.
It's described in a different post here:
http://www.fixya.com/support/t2222933-complete_factory_reset_sony_bravia_kdl
Good luck.
Rob
Posted on Dec 18, 2009
SOURCE: Sony KDL-46V3000 Bravia LCD Black screen
It's not to complicated, in the newer TVs as well as other things, when you first turn them on the diagnostic circuits kick in [that the first relay you hear click] it sends a signal (low voltage) to all the circuits to check them and make sure there are no problems. If it gets the proper returns from each circuit it kicks out and the full power relay kicks in and powers your set up. This is done to protect others circuits that might be effected by a flaw in a different circuit. What started as a small flaw in a component has gotten worse with use which is normal. Your set is kicking the diagnostic circuits and they are detecting the problem and shutting it down. You have problems with your power board, if the diagnostics circuits were not in place and full power hit the set the power board could possibly put triple or more voltage to some section of another board, thus burning it out also. That's why they started using the diagnostic circuits on TVs, Computers have had them for years. Late model car - etc. I would take the power board out of it and go to shop Jimmy's and enter the part # which will be on the board and order me another one and pop it in and kick back and watch TV again. I don't know what a power board would cost for it but "shopjimmy's" carries high quality boards at a reasonable price. I do caution you on buying a refurbished board, they are tempting but I have never and I mean never seen one hold up very long. As a matter of fact I will not put one into a TV or anything else for that matter. So there is light at the end of the tunnel and it's not the train this time! I only work on the kind of TV that plug into the wall or run on batteries, therefore, I've seen a bunch of them in14 years. Don't worry about getting the wires mixed up because one thing about TVs is a harness or plug will only fit one place and that is where it belogs you can't cross them up.
Gillight
Posted on Oct 23, 2012
1960 (approx.) b & w floor model TV sound suddenly doesn't work.
check av card
check speaker
check any dry soldering in power supply & audio section
Mar 25, 2014 | Zenith Televison & Video
Kymco **** 125 (1998) Engine lost power then cut out, now won't start
Is this a gasoline powered motorcycle/scooter? If so and if you got off in dirt, the carburator may have dirt in it. Drain the gasoline, clean the jets in the carburator and try again. If its electric, sorry, can't help!
Aug 15, 2012 | Cars & Trucks
When driving suddenly the engine cuts out.
I heave the same problem on my Corsa B 1.0 2000, engine cuts out, and whe it happens, I hear one of the relay under the right side of the dash buzzing. After a couple of minutes, starts like nothing happend.
So far I manage to find that the speed sensor is faulty, when I tap him the car stops. I order a brand new one, but I'm not sure that was the issue.
I order also a Opel Tech2 tester from ebay and it has to arrive next week, then I can see the error code.
Jul 13, 2012 | Opel Cars & Trucks
Rear Projection TV Cuts out Need to wait and then turn back on?
SOUNDS LIKE A FLYBACK PROBLEM AROUND $70.00 FOR PART
Dec 06, 2008 | Panasonic TX-42PT10 42" TV
RCA P60921 60 in. Rear Projection not working
could be the flyback as some eat them depends on how old it is, and what model it is be more specific. also possible high voltage divider box
Nov 11, 2008 | RCA P60921 60" Rear Projection Television
No sound
Hi, Probably you first have to determine if the "no sound" is the TV or your source (cable box). Try another source such as a DVD player hooked to the audio/video inputs of the TV, if still no sound then you have confirmed that it is the TV, if there is sound, then it is the cable box (in some cases it may be just the cables connecting the cable box and the TV; try wiggling it a bit, might just be loose). If it is the TV, go through the routine of the setup/menu; look for audio, stereo, SAP, etc, try different settings (pls log down original setting in case no change and you have to revert back). If all else fails, try the "thump test" this will help you determine if its a loose/cold solder problem inside the TV. Give your TV a good whack at the side, top or back, if sounds comes on even briefly, it's a loose/cold solder problem, if not then you probably have to have the unit serviced by a qualified professional. Good luck and kind regards.
Aug 26, 2007 | TruTech PLV16320 Television
Sound Interference
NO it dosent sound like there related problems at all. Now you say you get interferance or is it more like a static noise only when using the dvd player??? If thats the case then you have an output device problem as its breaking down and crackling into your input to your sound amp or the tv. Its a problem that will need to be traced with a scope and a test disk. as it could be a D to a converter or an op amp IC, or even as simple as a filter cap. Good Luck
Apr 10, 2006 | JVC DRM10 DVD Recorder
Sony MDR-IF5000 Headphones Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
