Question about Garden
My weadeater The engine starts but shutdown when try to use it
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 100 Answers
Carb adjust.may be all
Posted on Oct 27, 2012
Why won't primer bulb fill on homelite 26cs weadeater?
a primer bulb should not actually fill, that said, if it is not priming your carb then there might be a tiny crack or pin hole that is letting air in as you try to prime, order and change the primer bulb.
Oct 16, 2016 | Homelite Garden
Engine runs for about 30 seconds and shutdown like an electrical shutdown as opposed to a fuel related shutdown.
Engine fired up, ran normally for 30 seconds, then shut down ...
www.thedieselstop.com > ... > 7.3L IDI Diesels (Not Power Strokes)
Sep 25, 2012 - Engine fired up, ran normally for 30 seconds, then shut down. ... it fired up and has been running since... if it just ran out of fuel jump it, and keep ...
Viewing a thread - cummins m11 starts then dies - AgTalk Home
talk.newagtalk.com/forums/thread-view.asp?tid=332921...flat...1
Sep 24, 2012 - 9 posts - ‎9 authors
98 KW with a cummins m11 will start and run for 5 seconds then dies. ... anything else like that, because it would run for 30 seconds and then die, not 5. ... The engineprotection system will not shut down the engine unless the ...
[PDF]John Deere Engine Safety Shutdown with "Black Box" (prior ...
www.tuckerbilt.com/.../John%20Deere%20Engine%20Safety%20Shutdo...
John Deere Engine Safety Shutdown with "Black Box" (prior to Tier II ECU ... Ifengine fails to start in 30 seconds, the Low Oil ... Test #1 (Engine not running).
1800 RPM for 30 sec before shut down [Archive] - Pilots of America ...
www.pilotsofamerica.com > ... > Pilot's Lounge > Technical Corner
Jan 01, 2016 | Cars & Trucks
Lexus 1979 2JZ engine start but shutdown after i select gear
Use a bottle of yellow HEET dry gas to remove any moisture problem in the fuel.
Clean / replace air filter.
Top off ATF to MAX level.
Jan 16, 2014 | Lexus Cars & Trucks
2008 envoy code reader showing high purge flow on the evaporitiv emission system po402 have replaced gas cap and evaporate valve to no avail the vehicle is also slow starting after filling with gas
common problem with those mods ,is evap purge valve would get stuck open,then after shutdown vapors from fuel supply sys would flood engine with excessive fuel vapor ,so when you go to start vehicle it would act like a flooded engine and take longer cranking before it starts,try holding gas pedal to floor after a 15 min shutdown and see if starts faster,i believe that purge valve is along the d/s of the engine block.
Nov 22, 2013 | Cars & Trucks
Why is the gass cap leaking on my ryobi weadeater
that is where the tank vent is and it sounds like it is missing or damaged so instead of only allowing air in it is allowing fuel to come out. see if the valve is replaceable or if it requires a whole new cap
Mar 26, 2013 | Ryobi Garden
Weedeater on side for about an hour after filling tank. now flooded even tho it's been in correct position for 3 hours.
It may still be flooded. remove the spark plug, and dry it off, turn the weedeater upside down,
so that the sparkplug hole is facing down. pull it about 3 to 5 times so that any access gas,
will come out of the top cylinder, then put the sparkplug back in, primer the weadeater and
try to start it. good luck!
Jul 12, 2011 | Garden
I have a 2003 dodge dakota. 4.7l. I get codes p0685 and p0688. No start no spark. Relay is good. But voltage drops when using a voltage meter on one of the grounds in the pdc. Any live wire and that ground...
P0685 DODGE - Auto Shutdown Relay Control Circuit Failure
Symptoms - Engine Light ON (or Service Engine Soon Warning Light)
Possible causes - ASD relay circuit is open or shorted
- Failed Auto Shutdown relay
- Failed ECM
Tech notes Check all the ECM fuses, if the fuses are OK try replacing the ASD relay. P0685 DODGE Description Short or open in Auto Shutdown (ASD) relay circuit
P0688 DODGE - Auto Shutdown Relay Control Circuit Low
- Failed ECM
Tech notes Check all the ECM fuses, if the fuses are OK try replacing the ASD relay. P0688 DODGE Description The Front Control Module (FCM) has detected the supply voltage below an acceptable value
Jun 24, 2011 | 2003 Dodge Dakota Club Cab
Weadeater featherlite plus runs rough and cuts
It could be a number of things, but check the fuel lines first. They may be cracking apart at the gas tank. If so, replace them. There are other things it could be, but lets start there.
Jim
Jun 05, 2009 | Poulan Garden
Echo gt 2000 weadeater will not work
here are some of things to look for.look to see if the primer is cracked.it could also be the fuel lines.or the gaskets in the carburator.or your fuel filter could be stoped up. I have 4 years experince with 2 cycle engines.
Apr 27, 2009 | Echo Garden
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
