Question about Zebra LP 2844 Thermal Printer
ZEBRA LP 2844 WON'T PRINT MULTIPLE LABLES IT ONLY PRINTS FIRST LABLE THEN STOPS
SOURCE: Zebra LP 2844 doesn't stop feeding paper
I had the very same problem but I know it could be several different reasons. In my case it was a media calibration issue. To perform calibration switch the power OFF, then pres FEED button and hold it, Power ON still holding and after three red flashes release it. Calibration report will print out. At the end of that print you should get "PRESS FEED TO END". Do it and it should be ok. Let me know if that worked.
Posted on May 07, 2008
jigeo
  • 57 Answers
SOURCE: Zebra LP 2844 prints blanks
If the printer is printing nothing but blanks, try another roll of labels.
If the printer is printing blanks in between labels, it probably needs to be gap sensed. You can do this by:
1. turn the printer off.
2. hold the feed button down and then power the printer back on while still holding the feed button down.
3. release the feed button when the light flashes.
4. the printer will then regap itself
5. when the regapping is done, press the feed button once. It will print on the label that it is 'out of dump'
6. the printer should then be ready to go.
Posted on May 08, 2008
  • 4 Answers
SOURCE: Zebra LP 2844 printer will not print anything but the test page
possibly not a real LP2844 but an LP2543, a printer mass produced for and used by UPS. refurbishers change the label and sell as LP2844 because they are almost identical.
if it has an AC-AC adapter, it is an LP2543. LP2844 uses a AC-DC adapter, and all LP2844's have USB ports.
Posted on Apr 10, 2009
  • 185 Answers
SOURCE: Zebra TLP 2844 prints slow in WinXP, but fast in
when submitting the print, un-tick the collate box. Use the properties section to check the speed settings in the driver and try again
Posted on Dec 20, 2009
  • 97 Answers
SOURCE: How to print configuration page for zebra lp 2844-z
With the printer off, press and hold the FEED key while you turn the printer on. When the LED flashes once, let go and a Config label will print.
Hope that helps !
Posted on Apr 08, 2010
Zebra only prints after restart
UPS VOLTEGE PROBLEM PLEASE INSTALL HIGH VOLTGE UPS
Apr 13, 2012 | Zebra LP 2844 Thermal Printer
How to stop printer from printing an extra sticker when it prints?
Hi
  • Turn the printer off.
  • Press and hold the green power button and turn on the printer.
  • Release after first flash of led light.The printer will run a test print.
  • Turn it off and then on again.
  • Now print!
Hope it helps.Thanks!
Oct 03, 2011 | Zebra LP 2844 Thermal Printer
Prints out 13 stickers with strange characters
Is this a 2844Z? the 2844 is an EPL printer and the 2844Z is a ZPL printer. Since your have described the printer as 2844 but mentioned that you are performing 3-flash proceedures, it sounds like you have installed the wrong driver. uninstall the driver and install the LP2844z driver so that you can send the correct print language to the printer. If this is not the case, then you need to clarify:
What is your model?
Details about the driver installed?
Firmware version of your printer?
Connectivity? (Serial, USB or Parlallel)?
What are the characters that are coming out on the page? ASCII -Extended?
Jan 19, 2010 | Zebra LP 2844 Thermal Printer
We have a LP2844 printer that prints multiple blank labels sporadically. How do we stop it?
Make sure the label size is set correctly and the printer is calibrated. If this doesn't work download drivers from Nice Lable or Seagul Scientific websites to suit you Printer, these are more adjustable than the original Zebra drivers and handle small labels better.
Oct 15, 2009 | Zebra LP 2844 Thermal Printer
Zebra prints one page then light turns red.
TRY HOLDING THE BUTTON DOWN AND LET IT FLASH 5 TIMES. RELEASE. WHEN THE DIMENSIONS ARE AT THE CORRECT NUMBER PRESS THE BUTTON AGAIN.
Aug 19, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Prints 30 pages of junk instead of a Dazzle mailing
Turn off the printer and place your finger on the green feed button. With the button depressed, turn the printer back on. Let the light flash2.gif (ONLY!) four times and release the button. Printer will cycle through 2-3 labels. Press the feed button one more time.
You've just set the printer back to factory default.
Jul 23, 2009 | Zebra LP 2844 Thermal Printer
Printer won't print
check for paper jam and the ink.
green flashing lights means it try to print but something is holding it back.
Oct 14, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 fuzzy print
1. Clean the print head with cleaning pen.
2. Adjust print speed/darkness in software.
3. Check the media and verify that print surface is facing up.
4. Check that correct thermal media is in use.
Apr 23, 2008 | Zebra LP 2844 Thermal Printer
Zebra 4m
If you are in rewind mode and don't rewind the printer will pause while the rewind spool tries to catch up.
Jan 10, 2008 | Zebra Z4Mplus Label Printer
Zebra LP 2844 Thermal Printer Logo
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
