My gas furnace has not work - Heating & Cooling
    Genius:
  • 1,847 Answers
Just want you to go through this link...
http://homerepair.about.com/od/heatingcoolingrepair/ss/gas_furn_trblsh_2.htm
Hope this will help..
Posted on Jan 03, 2009
    Genius:
  • 1,199 Answers
We are going to need way more info than that to help you!
How do I install a thermocouple part #322391 in a Williams gas furnace
Gas furnace will not light. Thermocouple test with the ...
? 4:03
https://www.youtube.com/watch?v=suen7QlJl4o
May 12, 2012 - Uploaded by grayfurnaceman
I show how to bench test a thermocouple for a gas furnace using a multimeter. This video is part of the pilot gas furnace playlist.... Pilot Light Won't Stay Lit - How to Replace a Broken Thermo Couple on Furnace - Duration: ...
Oct 29, 2015 | Williams Heating & Cooling
Home furnace comfortmaker blowing cold air
Home owner's manual? Troubleshooting section. Gas or electric?
If gas, pilot light may be out, or other gas controls. Are you sure you have gas supply? Do you have other Gas appliances so you can check? Furnace needs power for controls, fan and thermostat. Are you sure you have electric power to the furnace? Does the thermostat have a fan switch? If so turn it on and see if the fan turns on. If it does not turn on you may have a circut breaker poped. or some other reason power to the furnace is not working.
Feb 27, 2015 | Heating & Cooling
Gas furnace is Not getting enough gas
Is this a new furnace? or possibly the furnace has been converted from propane to natural gas? Was it working correctly at an earlier time and nothing has changed since? Or was there a change such as fuel change or another appliance was added? Any specifics you can add will help. The problem says furnace is not getting enough gas, why do you think that is the case? In other words what symptoms are you seeing that lead you to that conclusion?
Jan 08, 2014 | Ruud Rheem Rgfe09ezcms Gas Furnace
Convert coleman eb15b to natural gas unit
Sorry there is no way to convert it to a gas unit.. The only way is to replace the furnace with a natural gas unit. You will need a gas line ran to it and a Flue. and then room to fit everything in that space.
Nov 10, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
I have a goodman gmp075-3 furnace, blower and igniter are working fine but not getting any gas to get furnace going
Check if 24 volts is being sent from the board to the gas valve, if not the board is nad and will need to be replaced, if there is 24 volts at the gas vlave terminals then the gas valve must be replaced.
Nov 08, 2012 | Goodman GMS90703BXA Heater
90 + gas furnace. inducer full of water
need help with gas furnace put in new presure switch and it worked for a while now i have to blow into it to get it to turn on ignitor .
Dec 05, 2009 | York Furnace Draft Inducer Blower Fasco #...
Furnace will not light. Igniter glows but no gas
Make sure that the switch on the gas valve is in the on position. If it is and the gas valves coming into the furnace are open, you probably have a bad gas valve.
Oct 03, 2009 | Heating & Cooling
Furnace flame goes low fan stays on
if the gas pressure is good on inlet and outlet of valve u might wanna chk the burner trays and manifold for flakes, dirt, spider webs ect... once u kno the passages are clear from obstruction you can focus on the mechanical. (sounds like gas valve may be getting weak and not able to open fully)
Mar 21, 2009 | Dayton Gas Furnace Heater
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
