Question about HP Hewlett Packard Pavilion A6200N PC Desktop
Cannot load drivers for Acer h233h monitor into hp a6200n running vista
Acer monitor does not show up when I try to install it after recovery. I cannot find LED driver for monitor at HP wevbsite
  • 3 Answers
moz205
  • 80 Answers
SOURCE: my new hp w2207h monitor,
Go to - CONTROL PANEL - DEVICE MANAGER then find monitors in the list,right click the desired device, then PROPERTIES this will tell you if the device is working properly. then click update drivers. If this fails check your screen resolution settings. The safest thing is to set it to default.Sometimes the graphics card isnt big enough for the monitor so try tweaking visual settings like shadows and fonts. Things like message box outlines and shadows can be turned off too speed the image up.If your using vista your probably using the default theme AERO/GLASS. Change it to a normal theme of your choice but dont use GLASS. this uses quite alot of graphics power.
Posted on Oct 25, 2008
rcampsr
  • 90 Answers
SOURCE: DVD
what operating system did you replace XP 32bit, XP 64bit? Was the version of Vista you used the 32bit or the 64bit. You may need to go to HP.Com and look for replacement drivers for the DVD. You can also use the windows update to obtain correct drivers for the DVD if they have tested them already. Another option is to go to the manufacturer of the DVD device and see what they list for the driver. Just remember there is a big differance between the 32bit and 64bit drivers. Read on the Vista system you installed and see what level was installed in your system. Regards, rcampsr
Posted on Feb 21, 2009
zohail
  • 1223 Answers
SOURCE: hi i need a recovery softwear of my windows vista
To restore to factory settings when you hit the start button the firstscreen that appears has the HP Symbol in the center of the screen. Whenthis appears hit the F11 key. Then follow the on screen instructions.It will offer you to either restore to last saved point or to restoreto factory settings. There are a few other options offered, like do youwant to back up you files etc.
kindly download this manual it will help u keep running ur system
http://www.spez.com.ua/NEWS/info/dc7800.pdf
pls rate me fixya if i helped u in ur problem
Posted on Feb 28, 2009
  • 7 Answers
SOURCE: Unable to reinstall DVD backups after HP SYSTEM RECOVERY failed
Code "purple" means you and your computer are done. It is an unrecoverable error that means you need a new system. However, I have found a couple of postings that claim to know a fix. I can not verify these methods, I do not own a HP or other type of prefab PC (custom is the only way to go). Anyway, here are the links, good luck.
http://h30434.www3.hp.com/psg/board/message?board.id=HardwareDPC&message.id=6115
http://forums.techguy.org/windows-nt-2000-xp/469752-code-purple-configuration-error-hp.html
http://forums.techguy.org/all-other-software/644163-code-purple-advice.html
Posted on May 16, 2009
sandro_monte
  • 72 Answers
SOURCE: HP Pavilion a705w PC Desktop\Ethernet Controller driver
obtain the driver from cd/dvd that was included as you purchased your desktop and try to check if the driver supports with the operating system you are using now. for example the driver available in your cd/dvd is only for windows xp and your operating system you are using now is windows vista of course driver not installed. try to download from internet the driver that are suite to your unit model and current operating system this can fixed your problem or else downgrade your os tha can support the driver that are available from your cd/dvd.
Posted on Oct 11, 2009
Hp vista and monitor hp2509 was working fine. i uninstalled monitor driver but now computer starts fine but monitor goes blank
Monitor drivers are built into windows OS, you can't uninstall the driver unless you went to devise MGR, monitor, and opened proprieties and hit uninstall, and even then when you restart windows, it will auto reinstall the hardware. So what you're saying does not make sense.
If you reboot and noting, try a system restore, if you have a windows disk, then run repair. But like I said, you don't install monitor drivers, DVD rom drivers, these are generic drivers that are made into windows. If you think a monitor has a driver that needs installing, explain how people install windows if they couldn't see the monitor.
Only onboard video and graph cards need drivers to run the video at its intended resolution, but it does not need a driver for the monitor, it's built into windows.
Mar 29, 2013 | HP 2509M 25 Widescreen LCD Monitor -...
I am running Red Hat Linux Enterprise my new Acer H233H is saying Input not supported any help would be greatly appreciated. Thank you
It says input not support because the PC video resolution is too high for the monitor to display, just need to lower the resolution. Nothing to do with OS, just the video setting.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
http://www.productwiki.com/acer-h233h/
If you set to native resolution and it still does not work then you will have to open it up and inspect the inside.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 31, 2010 | Acer H233H bmid Monitor
Trying to use an acer H233H lcd monitor with a Dell 4600
you have to install the original video drivers into it .from www.drivers.com if you have original drivers then install an AGP card into an AGP slot then you can see higher resolution
Apr 06, 2010 | Acer AL2016W 20" LCD Monitor
Hp pavilion loads to windows users then once the user is selected it acts as if it wants to load then everything goes solid pink. tried many different monitors
Sounds like you have a driver problem.
If you are running vista, go to your recovery manager and reload your hardware drivers.
If you are running xp, remove your video drivers and reload them from HP's website.
Oct 22, 2009 | HP Pavilion dv9000z Notebook
My broadcom wireless lan adapter for windows vista not detected in device manager and hp wireless assaistant not working.
You can run HP update to download and install drivers on your PC/Laptop, or run Microsoft update too.
Your HP PC came with a tool called Recovery Manager, Click the vista start menu and in the search bar type (Recovery Manager) without the parenthesis and it should display programs like RECOVERY DISC CREATION and RECOVERY MANAGER , please select the RECOVERY MANAGER an if you have VISTA USER ACCOUNT CONTROL turned on you will have to allow the program to run.
OK, once program launch, select the advance Options and click on HARDWARE DRIVER RE-INSTALLATION and click next. follow the screen instructions to re-install the driver or drivers.
Make sure you are not running any other program when using recovery manager.
GOOD LUCK
Sep 15, 2009 | Acer (D10709-002) (D10709002) 802.11g/b...
Recently, I purchased an Acer H233H LCD Monitor with the HP e9180f Desktop. However, the built-in stereo speakers in the monitor are not working. The sound card in the desktop is fine, as headphones and my...
Try installing the Acer Monitor software and disabling the the desktop sound card under 'My Computer'. 'Properties','Hardware Devices'.
Let me know if you need help doing this, or need more help.
Jul 25, 2009 | Acer H233H bmid Monitor
Screen will not display
Have you ensured that your display card driver AND correct monitor driver is installed. This is to make sure that your display card only generates signals that your Acer monitor is capable of handling. If you do not have the driver CD for your monitor you can download the software from www.acer.com. The problem is most likely that your display card is generating a refresh rate which your monitor cant handle. Go to your display properties and lower the refresh rate of your display card and see if this solves the problem.
Best wishes,
Graemevm
Jun 29, 2009 | Acer H233H bmid Monitor
Software app HP Director won't run
try to update the driver of your acer lcd and removed the driver of your old lcd.
Jan 01, 2008 | Acer AL1716 17" LCD Monitor
HP Hewlett Packard Pavilion A6200N  PC Desktop Logo
44 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
