Question about Plumbing
Where is anode rod located in a Rheem model TE40 electric hot water heater
3 Suggested Answers
  • 252 Answers
SOURCE: cant locate anode rod on rheem gaas water heater
It looks like a plug screwed into the top of the water heater (it IS plugging the hole so turn off water and release pressure b4 removing)
Posted on Oct 01, 2009
Healeyman
  • 1198 Answers
SOURCE: Anode rod Installation for Rheem Water Heater Model 41VR40N
Anodes last a very long time. It will be on a pipe plug going into the machine. As long as most of it is there, it's ok.
Posted on Nov 30, 2013
Testimonial: "It is 10 year-old water heater and there should be sediment coming out, but there is none. Also I can't find a way to get the rods out from the top. I am just not sure if there is manual for it."
I have water in the junction box on top of my hot water heater and into the electrical conduit leading to the hot water heater.
I do not see your earlier post with photo.
The problem could be the conduit.....
-disconnect the conduit and wires from water heater
-run wire into a junction box set lower than top of water heater... -then run another #10 wire from the junction box up to water heater...
-So if water is coming from conduit, it will accumulate into junction box and not in the water heater wiring cavity.
Next thing....
... a water softener can cause rusted tank.
-Softened water adversely affects anode rod...
-causing anode rod to deplete faster...
-once anode rod is gone, then tank begins to rust.
-Here are details for checking anode rod each 2-3 years:
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/How-to-maintain-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 05, 2015 | Rheem 82v52-2 Tall Electric Water Heater...
Anode replacement. where is the anode rod located on a ruud g100-200 gas water heater
either in the anode port on top of water heater, or connected to hot water nipple as a combo ... or both if unit has 2 anodes
Gene
Sep 25, 2014 | Rheem ruud g100-200 water heater,gas,100...
Energy factor rating
Rheem 50 gallon Pro52-2 has EF .95, which makes it ordinary 240Volt 4500 watt non-simultaneous electric water heater that produces about 21 gallons hot water per hour, with 67 gallon first hour delivery.
Recommend 80 gallon per hour first hour for oversized bathtub.
http://bostonheatingsupply.com/Rheem/Rheem%20Residential%20Electric/Professional/Rheem_ResidentialElectric_Professional%20Spec%20Sheet.pdf
Maintain electric water heater and it will last indefinitely.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Anode rod is located on top in separate port.
Anode keeps tank from rusting.
Year of Rheem water heater manufacture shows 3rd and 4th digit of serial number.
Nov 25, 2012 | Water Heaters
How to how to install the anode rod - for extended warranty - in a new Rheem waterheater?
You are installing a combo anode rod that replaces hot water outlet nipple. This means you will have 2 anode rods, which doubles the anode capacity of tank, which can cause extended life of water heater, assuming that both anodes are inspected each 2-5 years.
Sounds like a heat trap insert is in the way.
Look at parts sheet that comes with product manual.
Pull insert out since it will cause clogs.
Same insert is on cold side nipple.
I want you to contact the Tank forum since they are anode experts:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Tank will recommend magnesium anode and not aluminum.
My understanding is that Rheem water heaters are made so only Rheem brand anodes fit their tanks. While other companies use generic anodes that are sold at any plumbing supply, and also sold at Tank website.
You can configure pipes to make heat traps that save save $2-4 per year on gas water heater operation.
http://waterheatertimer.org/images/Heat-trap-install-900.jpg
Sep 08, 2012 | Water Heaters
Where is anode located mdel no. 82yp30-1
Question posted under Rheem water heater.
Model number does not describe water heater.
Model number posted in question does not appear at Rheem, and does not appear in a web search for water heaters.
Here are options:
1) Add a comment and describe water heater in detail so expert can access more information
2) Contact Rheem.
http://www.rheem.com/Contact.aspx
3) If this is tank-type water heater, the anode is located on top of heater.
Look for 1-1/6" hex nut located under a plastic plug.
Some anode rods are connected to the hot-water nipple.
Sometimes the top cover has to be removed to find anode hex nut.
I have used impact wrench on anode, and could not remove in some cases.
4) More resources:
Sep 17, 2011 | Rheem Water Heaters
Where is the anode rod located on the rheem 81VP20s
Anodes are located on top of water heater.
There are no hard fast rules for location, either by model number or brand.
Most times the manual is likewise vague.
1) There is hex head visible on top of tank.
2) Hex head is located under a plastic cover
3) Hex head is located under metal top, so remove screws holding top, and lift top off to view hex head
4) Anode is connected to hot water nipple.
5) With 9-12-15-and lifetime tanks, you can have 2 anode rods, and each has to be made of same material to work properly. Usually magnesium-aluminum instead of aluminum.
But if you inspect and change anodes frequently to prolong life of tank, then one is as good as the next.
Open following links shows Rheem anode rods
http://waterheatertimer.org/pdf/Rheem-Ruud-anode-rods.pdf
http://waterheatertimer.org/pdf/Rheem-Ruud-water-heater-parts-guide.pdf
Tech resistor anode rod has resistor added to prolong life of anode.
You can cut rod off to fit size of tank. You want anode 5-6" from tank bottom so sediment build-up doesn't reach anode.
Anodes are standard 1-1/16" hex head.
http://waterheatertimer.org/images/Water-heater-anode-006-200.jpg
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 01, 2011 | Rheem 81VP20S/430157 Water Heater
Where is anode rod located on 100 Gallon rheem water heater natural gas
Anode rods for tank-type water heaters are located on top of tank.
This is true since anodes are about 44" long.
Top of anode is standard 1-1/16" hex nut.
Anodes can be located in 2 different places: either directly screwed into top of tank -or- attached to hot water nipple.
Most times the exploded parts diagram in manual simply shows 'anode rod' without specifing exact location. If your tank has long warranty, then it can have two anode rods, and 1 will be on top and the other probably attached to hot water nipple, or there could be two anodes screwed into top of tank.
If anode is screwed into top of tank, then it will be under a plastic cap -or- it will be concealed under the top cover of tank.
Look for plastic cap, and if none shows, then remove screws holding down metal cover and look there for 1-1/16" hex nut.
Lastly, remove hot water nipple and check for anode located there.
If you have 2 anode rods, then replace with same metal for each.
Add a comment for more free help.
Mar 22, 2011 | Rheem Water Heater Anode Rod AP12938
I have the Rheem 47 gal Short Electric Water Heater 82sv502 that is roughly 5 years old. I have been getting the infamous sulpher smell, I have drained it once and now am getting the same problem. Is there...
Use 2 pints of hydrogen peroxide instead of bleach.
1) You need to replace anode rod, and 2) flush water heater with hydrogen peroxide:
Following links have information and instructions for anode rod:
http://www.waterheaterrescue.com/pages/WHRpages/English/Longevity/water-heater-anodes.html
http://www.thisoldhouse.com/toh/video/0,,20047047,00.html
To find anode rod, see if manual shows image.
Some rods are hidden under metal cover of tank.
Some have circular plug located on top of tank.
Some heaters have 2 anode rods > this would be on 12-15-lifetime warranty tanks
Some anode rods are connected to hot or cold water nipples.
Post question on professional plumbing forum with brand and model number:
Look at label on side of tank for valuable information needed to post question.
Add a comment for more free assistance.
Also take advantage of fixya phone service.
For a price, fixya expert speaks to you via phone while you solve the problem.
Jan 01, 2011 | Rheem 47 GAL ELEC SHORT Water Heater 6YR...
Cant locate anode rod on rheem gaas water heater
Sep 30, 2009 | Water Heaters
Plumbing Logo
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
