Question about Philips 40pfl7705dv/f7 40 Hz 120 Led Tv - Philips
PHILIPS 40PFL7705DV/F7 keeps shutting off
The tv only stays on for a few minutes then it just shut down by itself. Whenever that happens it loses all the settings. What is causing that to happen? Its a new tv.
  • Philips Master
  • 933 Answers
If it is a new TV and under warranty, return it. There is an internal fault and it needs to be serviced.
Posted on Oct 25, 2012
5 Suggested Answers
jmgldsmth
  • 1889 Answers
SOURCE: TV keeps shutting down.
the power relay contacts are burned replace the relay
Posted on May 21, 2009
rhozel2010
  • 269 Answers
SOURCE: My TV won't stay on until it's warm?
have your unit power supply check, maybe some cold solder or leaky capacitor is the culprit.
Posted on Aug 01, 2009
SOURCE: My philips lcd tv is switching inputs/channels by
tv key pad section complind
Posted on Feb 13, 2010
  • 608 Answers
SOURCE: magnavox 15inch lcd shuts itself off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
Upside down
Your Horizontal and Vertical Flip is reversed for some reason. This will be a little difficult to do/see, but turn on the TV and Press the Menu Key. Goto "Lock" and press OK. Once you see the Lock Code Box come up, press and hold the Volume down on the TV and the OK Button on the Remote for 5 seconds or more until the TV shuts off. This resets the Memory.
If that doesn't work unplug the power from the TV now for 60 seconds then plug it back in. It should power up at that point.
If that doesn't work it is probably an issue with the Logic Board and a Re-flash of the Logic Board from a Company who has the Equipment to do so will fix it. This shouldn't cost anymore that $150. Goodluck!
May 20, 2013 | Philips Televison & Video
Picture keeps going out on Philips TV 47PFL3704D/F7, 2009 model. The sound stays on. It happens very randomly-may be fine for several hours, may happen every few minutes. Also happens when playing video...
I think that the connectors from the backlight inverter board that go to the LCD panel's backlight are a bit loose which explains why it comes back on when tapped. I am positive that unplugging and replugging the inverter cables should do the trick. WOuld like to do it yourself? It requires you to open up the tv ofcourse.
Jul 10, 2011 | Philips 47PFL3704D 47 in. LCD TV
My Magnavox digital converter box shuts itself off every 5 minute
Check that you have not got an auto power off setting on. Check that the aerial connections are good. That the signal is strong from the stations it is picking up. Weak signals can cause the box to shut down.
It the box is very hot when it shuts down, you might have a fault on it.
Apr 04, 2017 | Philips Magnavox M61117 (DBM61117)
Aug 01, 2009 | Philips 42PFP5332D 42 in. Plasma...
My Philips 20PT633 has started shutting off mid program.
Consult your technician there is a semiconductor problem inside your tv. Probably lose connection, and need to resolder.
Jun 08, 2009 | Philips 20PT633R 20" TV
May 21, 2009 | Philips Televison & Video
36 tv shuts off after few minutes
have power board checked -- sounds like a short in the transformer
Dec 10, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
TV keeps shutting off
Its the power pack located inside the TV, it needs replaced. contact manufacturer for parts or service.
http://www.support.philips.com/support/html/index_global.html
Nov 14, 2007 | Philips 50PF9431D Television
My TV keeps shutting off
Tvtek is on the right track. The remote will not solve the problem. Sounds like a voltage regulator in HV circuit if it only lasts a few seconds. If it stays on for a couple of minutes, beam limiter cicuit is pushing to overload and shutting unit down. Magnavox set not hard to repair, but a 27" set is not cost effective to repair either.
Jun 06, 2007 | Philips Magnavox 27MS343S 27" TV
Philips 40pfl7705dv/f7 40 Hz 120 Led Tv - Philips Logo
225 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
