SONY TV KV-27TS36 PUSH THE BUTTON -- NO POWER
I have a sony tv, that was working fine, and that was repaired before about 4 years ago's for the same problem. When you push the button the set does not go on. Before the tv place replaced something with the power, but I don't remember what. Anyone know what I could check?
Just4help
  • 145 Answers
SOURCE: Sony tv that wont turn on anymore
Maybe This site will help you.
http://esupport.sony.com/US/perl/model-faq.pl?mdl=KV32HS500
Posted on May 25, 2009
SOURCE: tv repair
Undoutably the SMPSU (Switched Mode Power Supply) is faulty.. This will be a shop job... ensure you get a firm "Quote" and explanation B4 allowing it to be fixed.
Posted on Aug 01, 2007
freetek
  • 5568 Answers
SOURCE: Sony Trinitron Model No. Kv-27TS36 made in January 1994
Check the screen in a totally dark room.
If you see no sign of flashing or illumination from the screen, it is likely that the high voltage section has failed.
Worse yet, if the CRT filiment has failed, the Trinitron tube is quite costly and I don't think anyone is rebuilding them any more.
In either case, parts and labor will probably total more than the replacement cost unless you have a friend who will do the diagnosis and repair for you.
Along with your set, my whole profession is obsolete!
Posted on Apr 29, 2008
SOURCE: 2 blinks on sony kv-24fs100 no power
H.OUT (Q505) is shorted. IC1751 is shorted
Posted on May 03, 2009
amilayr
SOURCE: Sony FD Trinitron WEGA KV-32HS500 32
we have the same porblem. We just unplug ours and wait a couple of weeks while watching another tv plug and un plug it will eventually come on then we dont turn it off again it only goes off if the power goes off.
Posted on Jun 11, 2009
Suddenly, "No Signal" display when cable box/VCR Connected to UHF/VHF Jack
How long have you owned the tv? You have two options though your best bet is to locate your nearest authorized service center to have the tv repaired.
Thanks,
lee
Sep 14, 2008 | Sony KV-27FS13 27" TV
My Sony Trinitron shut down last night. I
4 times standby light blink shows that tv got problem in vertical deflection section and probably vertical output IC got defective, need to be replaced.
Replacement of parts in circuit board requires soldering work and expertise so call local tv repair shop guy if you are not familiar with soldering work.
Thanks.
Jul 25, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony kv36hs500 tv, suddenly no power, no standby lights, no sound
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
Jun 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
My sony trinitron won't come on
From your description it sounds like you TV is experiencing a shut down and re-set condition. This is usually caused by some type of voltage irregularity in the power supply section of the TV. Unfortunately, this is not an easy fix and will require a trip to the shop. Get an estimate before approving repair. In the new world of disposable electronics the cost of repair may exceed the value of the set. Keep in mind that TV components are most prone to failure during the electrical surge when you turn the TV on. So constantly pushing the on button will accelerate a permanent failure.
Aug 28, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony TV not turning on
Chances are the Power Supply failed because the Horizontal circuit failed. It would not be out of line if the repair cost ran 250.00 plus.
It is probably not worth fixing due to the age of the set.
Hope this helps,
Skyassoc
Jul 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Tv won't turn on
i can' turn on my sony tv . no lights are blinking. nothing. could something when it was moved.
Dec 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv repair
Jul 26, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
TV turns on......eventually
check for a bad cap ,relay sound ok or could be a bad solder connection in the power supply at the regulators
Dec 13, 2006 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Televison & Video Logo
159 people viewed this question
Top Televison & Video Experts
