Question about Samsung St65 14.2mp Digital Still Camera dark Blue
Samsung ST65 camera wont stay on
Wont stay on even full charge
USB Cable won't connect
Possible bad cable. Possible bad plug on computer or camera. Possible XP simply isn't listening when you plug it in.
Oct 17, 2014 | Samsung Cameras
My camera will not connect to my computer through my usb cable
the cause why your camera doesn't recognized by the pc, first if the usb cable is not compatible or if it was defective tried to replaced it. then secondly if your camera not plug and play which need the installer cd of the camera.lastly if the usb port of the pc doesn't work tried with other usb port or you can plug with other device just to ensure if the usb port of the pc is working good luck.
Dec 09, 2012 | Samsung St65 14.2mp Digital Still Camera...
Memory full
Check for updates on the samsung site
Jan 17, 2012 | Samsung NV3 Digital Camera
My samsung nv10 camera wont come on and stay on, the battery is new
If there is no life even though you have a charged battery it is possible that the mother board if faulty and must be replaced.
Sep 30, 2011 | Samsung NV10 Digital Camera
My camera wont stay on it bleeps once then turns off
That sounds like your battery could be dead/not hold a charge. If you've charged your battery already and your camera still won't stay off and turns off right away, it's time to purchase a new battery for your Samsung TL105.
You can purchase replacement batteries quite cheap here:
http://www.amazon.com/Samsung-Digital-Camera-BP70A-Battery/dp/B003OEDQBE
May 07, 2011 | Samsung TL 105 Digital Camera
On Samsung ST65 is there a self timer? I can't find any....
Yes, on the Samsung ST65 you can use the self-portrait feature.
On page 44 of the user manual you can find the explanation of how to use it.
Here you can find the manual:
http://downloadcenter.samsung.com/content/UM/201102/20110208153302382/ST65_ST67_English.pdf
Basically you can trigger the camera when faces are in center of picture, or when you smile of blink the eye.
Let me know if this helped you, bye
May 04, 2011 | Cameras
Camera turns off immediately after being turned on. thought it was the battery, bought new one charged it and even though it says full charge, the camera still wont stay on.
This fault is usually caused by a lens problem.
Over 95 percent of lens problems are from Knock damaged or sand/grit in mechanism. Try turn it on in playback mode and see, does the lens come out and go back in before it turns off?
Cheers.
Sep 30, 2009 | Cameras
Samsung St65 14.2mp Digital Still Camera dark Blue Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
