Question about EliteGroup GF8200 MCP78S AM2+ Atx 32GB Pcie 3PCI 2PCIE (GF8200A) Motherboard
Can't find onboard display driver. gf8200a v.1
  • EliteGroup Master
  • 3,606 Answers
Hello you can try this driver:
http://drivers.softpedia.com/get/GRAPHICS-BOARD/NVIDIA/ECS-GF8200A-V1-0-Nvidia-MCP78-VGA-Driver-17516-for-XP.shtml
This is for xp.
Good luck
Posted on Oct 30, 2012
VisionTek Radeon HD 5450 VHDCI doesn't seem to recognize monitors?
Try one monitor at a time, if you get nothing, reseat the card, if you get nothing try another port like display port or hdmi. If you get nothing take the card out and try the onboard graphics. IF you get something with the onboard, replace the card.
Apr 03, 2017 | VisionTek Computers & Internet
When connecting tv to pc i'm getting an error message 'no signal input detected'
Did you click on the source button? Also you have to go to your desktop right click with the mouse thern click on properties you will go to your display settings you should see 2 display squares 1 & 2. now you can clone or extend. Another thing it would help to let us know you OS ie win xp or 7 or whatever. Whether you've got Nvidia or ATI or onboard Graphics. So I'm just giving you the basic info..Hope that helps Merry Xmas.
Dec 27, 2012 | Wharfedale Televison & Video
All video smears into vertical bars
A bad connection either at the point the display panel connects or inside the display panel where it cannot be got at all.
Dec 23, 2012 | Dynex DX-LCD32-09 LCD TV
Adding discrete graphics card to p6stp-fl
!O_O!
1) Unplug the computer from power.
2) Press the Power On button in, and hold it in for a count of 10 seconds. Let go. (HAS to be 10. Count)
Do this same procedure TWO more times.
(IF the Power On LED flashes for a second, keep repeating until it doesn't)
What you are doing is clearing CMOS Error Codes, and resetting BIOS Setup parameters back to the factory default settings.
3) FOLLOWING Anti-Static Precautions remove the graphics card.
Plug the monitor back into the Integrated (OnBoard) graphics, of the motherboard. (VGA connector)
4) Plug the computer back into power. WAIT 1 minute, turn the computer on.
5) When Windows has loaded wait a couple of minutes, then take that graphics card's Installation (CD) Disk, and put it in the optical drive.
If the disk doesn't start loading after 10 seconds, go to My Computer, and double-click on the drive letter, next to the optical drive, the Installation Disk is in.
When asked choose all software. Nvidia Control Panel, and drivers.
Your computer will keep on using the Integrated (OnBoard) drivers, for graphics. It will Not use the drivers, and software you are installing now, until the graphics card is physically installed.
Install all software. If you are asked to restart your computer -> NO
Close all windows, go back to your desktop screen.
Turn the computer off normally.
(Start > Turn Off Computer > Turn Off)
6) Unplug from power, follow Anti-Static Precautions.
Unplug the monitor from the motherboard. Physically install the graphics card.
Plug the monitor into the graphics card. Close the computer case.
7) Plug into power. WAIT 1 minute, turn the computer on.
You may have to go into Nvidia Control Panel, and set the correct parameters for your monitor. (Screen Resolution / Color quality )
Clear CMOS Error Codes, and reset BIOS Setup back to factory settings doesn't work?
You get to go back into BIOS Setup, and set the submenu you changed, (Or submenu's), back to the factory standard setting.
(F6?)
You are trying to use the OnBoard graphics drivers for the -> graphics card. This = NO.
You need THE drivers for the graphics card installed F-I-R-S-T.
(OnBoard. ON the motherBOARD.
Used to be used for Integrated Graphics.
Makes it easier to understand if you use OnBoard Graphics )
Why?
When a device, (In this case a graphics adapter card), is installed, Windows 'breaks it's neck' to find suitable, matching drivers.
If THE drivers are not there, Windows will match up one of it's THOUSANDS of generic drivers.
This = No.
You need THE drivers already installed. Windows looks to see what device is installed, then finds THE drivers needed.
Regards,
joecoolvette
Sep 13, 2012 | EliteGroup P6STP-FL Motherboard
Plugged in my emachine LE1938 to my dell without the DVI cable, screen displays 'no signal'. Shouldn't the monitor work without the DVI cable?
The DVI cable transports the display signal from the video card to the monitor.
I think what Ron is asking is if you used a different cable to connect the monitor to the computer. (I'm assuming you used an old 15 pin monitor cable or whatever those old cables were?)
Without getting into your BIOS:
So on your computer, you probably have an onboard video card (a video card built into the motherboard itself), and a dedicated video card (probably where you're seeing the DVI out).
It may be possible that you have the on board video card (with the traditional connection) disabled, when the dedicated video card is plugged in.
This isn't rocket science, so don't worry. Phillips head screwdriver is all you need.
Pull the side panel off your computer (assuming it's a tower... if not, it's the top panel). Once you have it off, you'll see that video card plugged into a slot on the motherboard, with 1 phillips head screw holding it in place (inside, near the back, where the DVI port is).
Pull the screw, and the video card should come out. From there, the BIOS should recognize your card is missing, and thus revert to using the onboard video card.
Sep 02, 2012 | eMachines E-machines flat screen CRT 17"...
My computer will not recognize my video card. My PC is a Compaq Presario SR5233WM and the video card is a Radeon 5450. The card is firmly in the PCIe slot, and i've set in the BIOS the video to PCIe x 16...
Do you get any display at all? If so then it's needing a driver. If it isn't working at all then:
1. it's in the wrong slot - slot won't support it. Double check the board specs. Some versions say it's supported but it really doesn't.
2. (without my looking at the mother board manual...) is there an onboard video card? If so there could be conflicts. You'd have to disable the onboard video and try it.
3. the radeon is bad.
If the board supports it etc you should be getting some kind of display even if the resolution is low. (then you'd need to adjust it). However if you aren't getting any output then it is one of the things listed above.
May 03, 2011 | Gigabyte RADEON HD 5450 PCI Express Video...
Plz send driver for sound and vga
plz give me the sound & vga driver
Mar 28, 2009 | Mercury PVCLE266 Motherboard
EliteGroup GF8200 MCP78S AM2+ Atx 32GB Pcie 3PCI 2PCIE (GF8200A) Motherboard Logo
101 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
