Question about Cameras
Canon PC 1310 : It says memory card locked - Cameras
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Oct 25, 2012
5 Suggested Answers
t00nz
  • 4738 Answers
SOURCE: how to clear memory card, error card lock on a
Remove the SD card from the camera. Slide the tiny switch on the side of the card to its other "unlocked" position. Reinsert the card in the camera. But if you've already tried this, see this link for additional things that you can try.
Posted on Oct 12, 2009
  • 102366 Answers
SOURCE: will my canon ixus 60 take a 16gb memory card
Yes. The IXUS 60 was designed to work with SD cards. Cards larger than 2GB are actually SDHC (the HC stands for High Capacity) and will not work in this camera.
Posted on Jul 12, 2010
SOURCE: memory card is locked
Move the Red Tab on the side of the card and unlock it
Posted on Dec 02, 2010
  • 102366 Answers
SOURCE: my canon digital camera ixus 75 card is locked how to procedure to unlock
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on May 18, 2012
Download pictures
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Dec 03, 2012 | HP p2-1310 Desktop PC
Canon pc 1562 camera showing memory card locked
Oct 01, 2012 | Canon Cameras
My canon digital camera ixus 75 card is locked how to procedure to unlock
May 18, 2012 | Canon PowerShot SD750 / IXUS 75 Digital...
Hi Sir My CANON A470 it shows memory card is locked & memory card error, most of the file are in it how should i retrieve it, i ve tried with new batteries also.My PC also doesn't support it
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Sep 17, 2011 | Canon PowerShot A470 Digital Camera
I keep getting "card locked!"
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Troubleshooting steps for this problem are listed here.
Aug 24, 2011 | Canon PowerShot SD960 IS Digital Camera
Memory card locked. it's not the sd card i believe i need o send in for repairs. where can i do tha?
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Troubleshooting steps for this problem are listed here. If this doesn't help, consider trying Canon at 1-800-OK-CANON.
Aug 14, 2011 | Canon PowerShot S5 IS Digital Camera
My canon camera keeps displaying 'memory card' error and 'memory locked', what do I do?
check you sd card there is lock and unlock switch. unlock that button
Aug 08, 2010 | Canon Cameras
Camera reading memory card error, cannot get it to work. Tried removeing the card and replacing batteries. Checked and it is not locked.
try formatting the card once on a pc and then plug it in your camera....if that does not help either, you'll have to try a different card.
May 20, 2009 | Canon PowerShot A470 Digital Camera
Canon A560 will not erase pictures
Two possible solutions.
1. Apple users have reported that the switch on the memory cards performs the file lock function in either extreme positions Lock/Unlock. In some cases they have achieved success in centering the Lock/Unlock switch allowing access to the read/write operation of the memory card
2. Connect to PC
Access drive via windows explorer
Right click on drive (MEMORY CARD)
Select properties
Confirm that RO (Read Only) is not selected.
Selected RO
Try reading card
Repeat properties un-select RO
Try deleting files
If not successful card is likely defective
Hope this helps?
Mar 12, 2017 | Canon PowerShot A560 Digital Camera
How to unlock camera card--HP M525
Little sliding switch on the side of the SD memory card. Remove from camera, slide switch away from lock position, re-install and you should be good to go.
Mar 07, 2008 | Canon PowerShot A530 Digital Camera
Cameras Logo
185 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
