Hard disk 1 (301) how do i fix it do i need a new hard disk?
How to fix disk 1 (301) error
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 59 Answers
Well, if you can manage to boot into a recovery console, you might be able to run chkdsk and verify that it is a bad hard drive. But most likely yes, you will need a new hard drive. If your laptop is under warranty, you may be entitled to a free replacement, otherwise you should consider whether you want to attempt the installation or have someone else that you trust do it.
Posted on Oct 25, 2012
HOW TO RESET CANON E600 WITH ERROR 5B02 ?
E600 is a hard disk failure error. Reloading system software might fix it. if not new hard disk is needed which will also require system software.
Oct 11, 2014 | Cannon Office Equipment & Supplies
Hard disk cyclic redundancy check
A cyclic redundancy check error on a hard disk means that part of a file read from the hard disk doesn't match the expected value.
A cyclic redundancy check error, in other words, means that files on your hard drive are corrupted.
Repair a cyclic redundancy check error on a hard disk using the Check Disk tool in Windows.
Click "Start" and click "Computer."
Right-click the hard disk with the cyclic redundancy check error under "Hard Disk Drives" and click "Properties."
Click the "Tools" tab at the top of the hard disk "Properties" window.
Click "Check Now" under "Error Checking."
Select "Automatically Fix File System Errors" and "Scan for and Attempt Recovery of Bad Sectors" in the "Check Disk" window by clicking each option if it isn't already selected.
Start a disk check and repair by clicking "Start" in the "Check Disk" window.
Click "Yes" if the "Do you want to schedule the disk check to occur the next time you restart the computer?" prompt appears.
A disk can't be checked if it's in use, so you'll need to restart Windows to check it.
Restart your computer by clicking "Start," clicking the arrow icon to the right of "Shut Down" and clicking "Restart."
Fix a Cycle Redundancy Check Error
The "Cyclic Redundancy Check" error is a Windows error message telling you there's a problem reading data you're trying to access.
The root of this problem could either be a damaged storage device or a corrupt file.
Windows has built-in tools to attempt to fix to this problem, and avoid further errors.
Click on the "Start" menu in the bottom left-hand corner and click "Run."
Type in "cmd" and press "Enter" on your keyboard.
This will open a black command prompt box.
Type in "chkdsk /f" and press "Enter."
If you receive a message saying the disk will be checked the next time the system starts, press "Y" and then "Enter."
Restart your computer by closing the command prompt box and selecting "Shut Down" from the Start menu.
Wait for the disk scan to reach 100 per cent.
This may take awhile.
When it completes, your drive errors may be fixed.
Avoid future problems with this type of error by replacing the file that caused the problem.
For example, if you got the error when using a text document, open the document and copy all the text (press "Ctrl" and "A" at the same time and then "Ctrl" and "C" at the same time).
Create a new text document and paste the text in by pressing "Ctrl" and "V" simultaneously. Save the new file, and delete the old document.
Hope this heps
Nov 02, 2012 | Ultra 0471 Seagate St3500418as 500gb Sata...
How do i fix x-box 360 e79 error permanently
Error code E79 on an Xbox 360 means you may have a faulty hard drive. This may be due to the hard drive not being connected correctly and can be fixed in a few steps. If, after following troubleshooting steps, the error does not resolve itself, you may need to purchase a new xbox 360 hard disk.
Mar 11, 2012 | Video Game Consoles & Games
How can i fix my acer 5515 smart failure predicted on hard disk 4 wdc wd1600bevt-22zcto-s1
This error message is warning that the hard disk could fail soon. It pays to back up your data frequently so when the hard disk fails you will not lose youe data.
The only way to fix this problem is to install a new hard disk, install Windows on the new hard disk and the Acer laptop's device drivers plus your programs and data.
Feb 18, 2012 | Acer Computers & Internet
How to fix error loading operating system on toshiba satelite m115 laptop
Go into the BIOS and check if the BIOS detects the hard disk. If not then most likely the hard disk has failed and the hard disk needs to be replaced then Windows needs to be installed on the new hard drive plus the Toshiba M115 device drivers and your programs/software.
Feb 02, 2012 | Toshiba Satellite M115-S1061 Notebook
Boot disk failure no hard disk found
The error means that your system is not able to detect the hard drive on the system, check if the hard drive wire connections are tight and not loose and then try rebooting the system.
Look for hard drive stats on POST whether it succeeds or fails. This is how you can do that.
When system boots up, press the PAUSE?BREAK on the black screen and see whats system comment for your hard drive power test. If it succeeds and your hard drive's connections are also tight then possibly your hard drive might have crashed ( which means there are bad sectors on the hard disk).
Try performing disk checking on the hard drive to see if there are any bad sectors on the hard disk, the disk check will automatically fix the soft errors but if the errors and hard errors in that case the disk checking utility will not automatically fix the errors and you will need to get a new hard drive.
Thanks !!!
Nov 22, 2010 | Computers & Internet
When i format my hard drive it says disk error how to fix it?
The "format" has failed to complete, due to input/output errors on the disk-drive. It's time to buy a new disk-drive. If the "old" disk-drive is still under warranty, exercise the warranty to get it replaced.
Jun 12, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
Instructions For Fixing Hard Disk Errors:
Reply to :- Instructions For Fixing Hard Disk ErrorsThe same problem is my window 7 is showing on my hard disk Disk Name: WDC WD2500BEVT-75ZCT2 ATA...
I can still access to my data but my laptop hangs a lot..
my laptop is Dell Inspiron 1525.
Is my hard Disk got failed?
I am very much worried...please someone help me.
Aug 11, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
What does ' a disk read error occurred press ctr alt del to restart, everytime i do it it gives me the same error??
You could have a hard drive problem. To check the hard drive boot up to the Windows XP cd in repair mode. At the C prompt type: chkdsk /r
This will start a program called Check Disk that will evaluate your hard drive and attempt to fix any errors. it Check Disk is successful it will complete 100% and return to a C prompt. You can then attempt to reboot. If Check Disk finds unrecoverable errors you will need to purchase a new hard drive and rebuild the OS.
Jun 14, 2009 | Gateway MX6453 Notebook
Computers & Internet Logo
405 people viewed this question
David Payne
David Payne
