Question about Fellowes Stripcut Paper Shredder, 32510
Novi Tech PS-014 Shredder metal gears
I know it's a cheap unit, but I hate to throw things away that might be repaired reasonably.
The metal gears at the shaft ends opposite the motor are shot. Any idea where to get replacements.
NoviTech and Fellowes model no.s look the same . Are they??
EdH
fellowesrep
  • 102 Answers
SOURCE: Fellowes Shredder keeps running
You should be able to flip up the cd cover and visibly see the sensors in the center of the paper entry(look like little LED lightbulbs) Clean with a Q-tip dipped in rubbing alchohol. This should solve your problem. If it doesn't you probally have a burned out sensor. call 1-800-945-4545 to check with customer service.
Posted on Feb 22, 2008
fellowesrep
  • 102 Answers
SOURCE: Fellowes 220c-2 repair manual
call Fellowes Customer Service 1-800-945-4545
dlundmark
  • 797 Answers
SOURCE: Fellowes Shredder Parent Part # 38605
If this unit is worth it to you, you can build your own gear.
Here is a link to get plastic repair materials to make plastic parts. This site also will have materials for repairing plastics.
Another possibility is to search Ebay for a unit like yours which has other problems. Never can tell... it may be there.
Make sure you ask for the model of the unit in your search (on the NET as well. The serial in this case is not needed.
Posted on Jul 26, 2008
SOURCE: Questions on Fellowes Shredder Spare Parts
these guys might be able to help http://wheelermachines.com/fellowes_parts.htm
Posted on Aug 07, 2008
SOURCE: novitech shredder
After clearing the jam (with the unit unplugged!), let the unit cool completely, then try using it again. A notice on the nameplate inside my unit says: "2 min on/4 min off." Apparently, a thermal cutoff keeps it from overheating by automatically preventing continued operation that might otherwise melt the parts. So heed the directions. I had the same problem with my NoviTech Model PS-026/B2 crosscut shredder (max: 5 sheets, 1 credit card). Also, make sure the motor mechanism is seated square and flush on the bin. I tried testing it out of the bin, and the green ready light wouldn't come on -- for a good reason: safety. (I still have all of my fingers, thanks to that!) Hope this helps.
Posted on Aug 17, 2008
Where do I get replacement gear for the shredder?
try a appliance repair shop for a supply agent for parts
office supply shops that sell shredders may be able to give you the names of repair agents
if it is more than 5 years old then junk it and get a new one as the cutter rollers will be blunt and probably the reason the plastic gear failed
Jun 19, 2015 | Tech Solution TS-6000 Shredder
Purchase gears
This is an inexpensive, light duty shredder. Products such as this are considered 'throw-away products' ; when they break, you throw it away and buy a new one. Larger, more expensive commercial shredders are repairable.
Jun 21, 2014 | Aurora Global AS501X-MS Shredder
Gears are not rotating; motor works though
I guess you have made sure that the cutters are not jammed by bits of paper and card?
Mar 23, 2014 | Office Equipment & Supplies
Need a manual
Can I purchase the plastic geers for a novi tech shredder. Model: PS-307B. Mine stripped.
Oct 25, 2012 | Office Equipment & Supplies
Staples SPL QW1200 shredder - how to disassemble it to get full access to blades?
remove the bin, remove thr screws that hold the bottom on (to get the cord free) then flip it over so its sitting on top remove the screws around the side walls to the top and remove the top shredder. with the shredder still up side down there are 8 screws around the outside edge (in the 1/4 holes) remove those and you can seprate the housing from the blades and motor. in the one i have the blades in the center are bent and the guides are broke i am looking for replacement parts or another for spare parts good luck i am a automotive tech, and i hate to throw things out just because ond small small part is broke but the hardest thing is finding parts. we live in a world where we are in couraged to reclye but we throw so much away because it is almost imposible to find parts or when you do the replacment parts cost more than a new one. sorry for the rant but i like to see people trying to fix things
Sep 09, 2012 | Office Equipment & Supplies
Where can I get new gears for my Tech Solutions TS8000 paper shredder
Unfortunately there are no replacement parts for many shredders...they are made to throw away when the break...
Stinks... but that's the way it is...
heatman101
Jun 15, 2011 | Tech Solution TS-8000 Cross-Cut Shredder
GBC shredmaster 1150x shredder now runs only in reverse. And when I press the "reverse" button, the green "forward/shred" light comes on, rather than the red "reverse" light....
The first thing that comes to mind is that the switch is faulty and that one of the contacts has come loose and is shorting across the reverse contacts. There is little else that can go wrong with a shredder, so in this case try replacing the switch.
Jan 26, 2011 | Quartet gbc 1150X Shredder
Paper is stuck in gears on auto Cannot reverse and bring back up.
throw it away and never buy OfficeMax cheap shredders
May 20, 2010 | Royal 10X Shredder
The plastic gear in my Fellows Powershred PS 60CC paper shredder is ruined. Is it possible to buy a replacement gear anywhere?
WHICH OF THE PLASTIC GEARS FAILED? FELLOWES HAS A REPLACEMENT THAT CHANGES A PLASTIC GEAR TO A STEEL GEAR-A GREAT IMPROVEMENT.
Oct 06, 2009 | OfficeMax 0M96431 Shredder
TS-6000 Shredder Problem
1800 639 3803 tech solutions service hot line for the ts6000
Aug 18, 2008 | Tech Solution TS-6000 Shredder
Fellowes Stripcut Paper Shredder, 32510 Logo
594 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
