Kenmore 970-C45072-00 washer front drum seal leaks. How to replace drum seal?
How do I replace the rubber seal which is inside the door and rides against the washer drum. I cannot see how to remove the top cover for the controls under which are screws to remove the front section of the washer holding the door.
catriver
  • 878 Answers
SOURCE: Black stains on Laundry from a front load washer.
bob, if your model starts with 417. this is a mother of all jobs. The black marks are coming from the rear bearing assy. in the tub. I just changed one out and it is misery. I don't believe the boot is causing the black marks. When I tore this one apart I found the tub, tub to drain pump hose, pump itself, contaminated with this black crap. Replaced them all. The tub and bearing comes as one piece and it is no fun to put in. The whole washer has to come apart to do this job and it requires two men to do it. The boot (bellow)itself is a pain to install. You might want to check with Sears and see if this is covered under the 5 year warrany on the bearing and tub, parts only, if not, it's not worth the time or money..Catriver..post back.
Posted on Apr 23, 2007
gittos73
  • 244 Answers
SOURCE: water leaking from front door
not really due to therebeing 3 holes at the bottom of the door seal which lets water out that is stuck in the seal
Posted on Sep 12, 2007
  • 225 Answers
SOURCE: Washing Machine Door seal replacement
Hi, I'm not familiar with your particular model, but there is most likely a very similar type of clamp holding the back end of the seal to the static part of the drum. It is most unlikely that you will need to take off the front cover as on most machines only the back and top are removable. You might need to unfold the rubber to get to see the wire which is holding it on. If it is the type of clamp with a screw-tightening device, it might be rusted up and a new one might be called for.
If the old seal is damaged there is nothing to be lost by cutting away some of it with scissors so you can see better what you are doing.
When you get to the stage of putting the new seal on, try lubricating it with a bit of washing up liquid or soap to allow it to slip properly onto the casing and rum, and try to avoid tightening up with a twist in it - the soap should help. Remember to put the new one on in the reverse order to the way you got the old one off.
Hope this helps you a bit more. D
Posted on Jul 18, 2008
jsrock516
  • 5911 Answers
SOURCE: Front Loader Kenmore Mod # 110.44832202 is leaking.
The rubber seal is known as a bellow. If the bellow is torn, more than likely it IS the cause of your leak. Your only course of action is the replace it. Searspartsdirect.com carries replacements. Just type in your model (as you provided) and look under the "Door and Latch Parts" heading for item number 1 (part #8182119). It is not a cheap part, but it will cost you much more to have an appliance repair company install it for you. This is not a difficult repair, and you can accomplish this on your own if you follow these steps:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Some additional parts that normally do not need replaced, but you may consider just in case are the front and back clamps that hold the bellow in place. They are listed under the same heading as items 6 and 14. They don't cost that much and may consider them just in case you need them. In particular, the front clamp, can break or the spring becomes stretched. Inspect these items just to be sure.
I hope you find this information helpful. If you require additional assistance, please let me know.
PS You may also try repairclinic.com for comparative pricing. They also carry the same parts (sometimes for less).
Posted on Sep 12, 2008
SOURCE: replacing door seal rubber boot
Hi its just a peice of wire with a spring tensioner just pull the door seal free" towards side of machine not forward" it will come .....then you will see wire ! you will kick yourself when you see.... it i did lol
Tommy-B-
Posted on Nov 02, 2008
Cold water leaks into tub when machine is off
Try to identify roughly the area the leak is coming from. This will eleminate some of the following
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the WATER INLET valve
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace inlet water valve
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace pump .
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. 9696d86e-1b8b-4b2e-af2c-6f3a3ae921dc.jpg
May 23, 2013 | Siemens WK61420GB Front Load Washer /...
Kenmore 417 97962705 Leaking below tub from transmission gasket
see this causes and fix it. God bless you
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the water inlet valve.
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace the door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace the water inlet valve.
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace the pump assembly.
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. Follow the video for the strut replacement and remove the top springs and the inner and outer drum will pull out the front.
Sep 28, 2012 | Kenmore 98702 Stacked Washer/Dryer
How do I fix my Kenmore front load washer ?
your drum bearings have gotten water in them due to a bad lip seal on the back side of the inner drum,if you can buy the bearings and lipseal you can tear it down and replace these rusty noisy bearings,and leaking seal
Aug 26, 2012 | Washing Machines
Leaking water under drum area seems to leak more with larger load
Check the gray rubber seal by the door. Look all around, inside the folds, for a hole. (usually found on the right or left side) Replace door seal if hole found.
Jan 26, 2011 | LG WM-2277HW Front Load Washer
Our front load washer is leaking from the door down the front.
The leak is either the door seal of the large circular rubber seal that sit between the drum and the opening.
Aug 09, 2010 | Kenmore Elite 45986 Front Load Washer
Small **** in the rubber molding inside the door; leaking.
You may need to replace the door seal. But first take some 100% pure silicone and push some in the hole and around the hole. Let this dry for 24 hours before using this should seal it up. If this does not work replace the door seal. Here is a link that should help http://appliancehelponline.com/washerdoorseal.html
Jul 12, 2010 | Kenmore 42822 Front Load Washer
GE Profile front loader washing machine is leaking front of door, believe the problem is the rubber washer ring, however can this be replaced?
Hello, this is usually the door seal, most machine incorporate a one piece combined door seal and outer drum seal(often just called a DOOR GASKET), the door seal are put in on the front panel first in the factory, then the drum assembly is put in and the seal pushed over the outer drum. This means a lot of stripping down has to be done just to replace the drum to the door seal.
Thanks
Jun 14, 2010 | GE WSXH208A Front Load Washer
We have a kenmore elite washer mod. 970-c40062-00 ser. xc11700832. the washer leaks, and is very noisy. It is 10 years old
Your Stainless Steel drum is supported inside of the washer tub by a spider assembly. The assemply, which is made of cast aluminum, has corroded (steel and aluminum and detegent don't mix) and the spider assembly has broken. The drum has likely wobbled enough to wear a hole through the tub. You need to replace the drum and spider assembly, and tub.
Mar 06, 2010 | Kenmore Elite 45986 Front Load Washer
Rubber seal damaged. needs to be replaced kenmore model 970-c44052-00 How do I remove sides to get at it?
there is no need to remove the side to replace the door seal, just behind the door seal there is a spring clip undo this and fold the seal into the drum were you should see another spring clip undo that as well and the door seal comes out from the front through the hole in the door, to refit a new fold the seal till its inside out and fitted on the inner drum first fit the inner clip then pull it through the door hole and fit the outer spring clip out side the door
Dec 06, 2009 | Kenmore 43142 Front Load Washer
Leaking front loader
If your washer has a rubber seal around the inside of the door and it has a little opening where the detergent comes into the washer put your hand inside the rubber piece and feel all the way around and see if you feel any holes or cracks in it and that is where it will leak from.
Dec 03, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
