Hs5000 fan will run but no heat
Fan will run but no heat, switch on L lead had gotten hot,cleaned and reinstalled wire but still no heat
  • 2,878 Answers
Fans are supposed to cool systems and keep them from frying.
Posted on Oct 26, 2012
Turns on & off..but, no heat. electric furnace Is there a RESET button on a Nordyne electric furnace?
Does the fan run normally? Or does it run all the time? If the fan operation is normal the problem may be a bad heat sequencers(relays) or the heat strip itself could be defective. Kill the high voltage grab a meter and disconnect the wires from the heat strip and ohm out the winding. If it's open then that's a problem. If it has a value ( probably low that's ok) then they should be good. Plug all wires back in. Move to the the heat sequencers look for any burnt wires. The low voltage should be blue and white wires maybe brown (second stage normally). This is the part that requires live testing of the system do not attempt if u are not familiar or comfortable with high voltage...be careful. With all wire plugged back in and the panels off turn on the high voltage. With the meter check for low voltage across the heat sequencers to should read 24+ volts across the blue and white. This would indicate a on switch. if on then check for the lead that come from the high voltage to the heat sequencers red wire usually. This wire is hot always. Check between the chassis and this lead for 120 vac. If u have the switch on and high voltage present there should be high voltage on the opposite terminal check with meter. In no voltage the sequencer is bad. Hope this helps. Oh if no low voltage check tstat wire (white) and then check the tstat for correct programming if digital.. you might do that step first btw
Dec 30, 2016 | Heating & Cooling
Light only turns on with the remote. How do I set it to turn on with the wall switch?
There are some fan models (particularly with a remote control) that use multiple cycles of a single power switch to select the operating mode. For example, if you simply flip the switch on, you get the fan. If you flip it on, then off, then on again within one second, you get the light. If you flip the switch on - off - on - off - on, you get both. The trick is to do it fast enough so the internal power circuit doesn't run out of capacitor charge and forget what you're trying to get it to do.
Sep 28, 2011 | Hunter 52" Ceiling Fan With Light And...
HEAT TO MUCH
Hi rcantu4444...
Dryer Running Hot
Check and clean if necessary your vent hose.
If you vent hose "seems" to be clean then,try running the dryer with the vent hose off and see if the dryer is not running hot anymore.
If you are running too hot you are not moving enough air thru the system.
It could be that the fan blade is plugged up.
The problem could be a large lint ball build up in the center of the fan or a sock,thin pants,a pen,etc. that has gotten into the fan by falling down the hole where the lint screen is normally inserted.
You have to find the air restriction to solve the problem.
It also can be a loose or worn out blower wheel/fan.
Free Answer...Please take time to rate me.
May 16, 2011 | Whirlpool LER4634J Electric Dryer
Back of dryer getting very hot and keeps tripping the heat switch works fine not for long without overheating
Dryer Running Hot
May 16, 2011 | Dryers
What is the whirring diagram
Most fans have 3 wires usually a white, black, and a blue(or black with white stripe) the white wire is the neutral and goes to the white wire in the ceiling box, the black wire is the fan hot lead and goes to the black hot lead in box and the blue(or other blk/wht) is for the lights and would go to the switched lead in the ceiling box(sometimes another color but not white or green)..if you don't have a switched lead coming out of the ceiling box and just two wires then the white goes to the white in the ceiling and both black and blue go to the black wire in the ceiling box
Jan 22, 2011 | Hunter 21617 Palermo Ceiling Fan
All hooked up, fan works, but lights do not there is a wire that says light connection . do I switch them?
The light wire needs to be connected to the hot lead out of the ceiling. If you have only one hot lead (usually a black wire) connect both the fan motor wire and the light wire to this lead. If you have a second hot lead (usually Red) you can connect the light wire separately.
For free troubleshooting advice call The Fan Man 952-898-2754 or 1-866-600-FANS(3267) www.fanmanlighting.com
Nov 09, 2010 | Hampton Bay 52 In.Carriage House II in...
My lakewood high speed floor model HV-21T stopped running. After shutting off it started running again but shut off again and this time the motor and cage was extremely hot.Also are new motors available on...
Try replacing the "start-run" capacitor. It is the rectangular black box mounted on a tab next to the motor inside the cage, two wires attached (cut them close as close to the capacitor body as possible). Other symptoms include not moving at all with a hum, and getting very hot. The capacitor is a 5% tolerance 8 microfarad rated at 250vac. It doesn't have to be the exact form factor but it does have to be heat rated at or above 70C per design parameters of the fan.
WARNING! Make sure to protect the leads properly because this capacitor is connected directly to the power mains during operation. If one of the leads electrically shorted against the fan housing or cage could cause a catastrophic failure of the fan, and possibly a fire, and possibly give a nasty shock to whoever was switching on the fan at the time.
-Brandon
Aug 22, 2010 | Lakewood HV 18-c Floor / Box Fan
2000 ford windstar. Problem: positive lead from battery becomes hot when the radiator fans come on, lead is hot enough to burn to the touch and drains battery. When the fans are not on, the positive lead...
Clean the battery terminals with a wire brush & sandpaper. Make sure the fan is well grounded also. You may have to clean the black wire ground at the grounding spot. Also your fan motor may have a dead short & need to be replaced. Good luck!
Aug 15, 2010 | 2000 Ford Windstar
Electics for fan off honda crf250r
If you are talking about the CRF250r and not the CRF250X. I can probably help. I put a Fan on my CRF450R.To avoid over talking it without a specific question, what the X model has that the R model dose nt have is a clean DC power source, fan mounts, or Thermistat switch.
None of these are a big problem except when talking to other people to find out what you need.
I used a 2005 250x fan kit on my bike it comes with the most basic kit, a fan & a thermal switch.
Then I orderd a condencer from trail teck, to use instead of a battery. Not likly to ware out, and I, am not using a fan when the motore isnt running.
I alsoe neded a DC regulator. Basicaly all I am doing is adding a basic DC light Kit to my bike in oder to ad the DC Fan in its place. I run boath
I could not get any information on the fan From Honda without ordering one and testing the draw on my own.
It draws very little, a 250X youses a 35What light bulb wich is small and still can run the Fan.
The stator on the 250r has two leads making AC power. The aftermaket stator you buy should have two leads pluse two more leads that can be run as AC or DC light depending on if you yous one or boath of the extra wires.
Here is a link to see some one using the kit. IF I an figure ou t how to do it I will do one myself
http://www.rickramsey.net/CRF250Xbigbore.htm#coolingfan
Jun 19, 2009 | Honda CRF 250 R Motorcycles
High Pressure cutoff
YOUR OUTDOOR FAN MOTOR SHOULD NEVER SHUT OFF IN THE AC MODE. IT IS SUPPOSED TO SHUT OFF IN THE HEAT MODE WHEN ITS IN DEFROST. IF THE UNIT IS RUNNING IN COOL AND THE OUTSIDE MOTOR QUITS ,THE COMPRESSOR WILL QUIT SOON AFTER. EITHER THE RUN CAPACITOR FOR THE FAN IS BAD OR THE FAN MOTOR ITSELF IS BAD, IF CAP IS GOOD THEN THE MOTOR IS At FAULT. THE OUTDOOR PRESSURE SWITCH CAN ALSO OPEN IF THE INDOOR FAN MOTOR FAILS IN HEAT OR THE FILTER IS PLUM NASTY in heat OR THE INDOOR COIL IS PLUGGED UP in heat.. THE PRESSURE SWITCH USUALLY TRIPS AT 400 TO 425 SO ITS WORKING CORRECTLY. YOU MAY BE CONFUSING THE ISSUE SAYING THAT THE AIR IS HOT AND COLD INSIDE. IT IS COLD WHEN AC IS RUNNING HOT WHEN HEAT PUMP IS RUNNING IN HEAT BUT ESSENTIALLY not cold or hot if compressor isn't running, but a lot of folks describe the lack of cold air as hot when the compressor isnt running. but it basically is warm or house air temp.you test the capacitor with a capacitor tester or take it to motor shop and let them test it. odds are its a 5 , 7.5 or a 10. it should test within 10 % of rated value . ask for a RESCUE brand replacement motor. they are great ,reversable etc.carefully oil and sand the motor shaft and note exactly where the blade was located in relation to the grill so you get it back just the same. usually they wire up black to a leg of 220 power. white to the other leg of 220 power. brown and brown with white stripe to the capacitor.you can also pull whole fan shroud assembly on some units and take whole thing to motor shop and let them test motor cap, replace and all you do is return to unit and connect two power leads,
Oct 26, 2008 | Heating & Cooling
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
