Question about JVC HD-52G786 52" Rear Projection HDTV
No sound picture fine but no volume. checked mute no problem.
    Top Expert:
  • JVC Master
  • 14,553 Answers
I have seen several of these (some brand new) where the audio board fails, if I remember it wholesales for just under 100 but is not real easy to get at---entire audio circuit is on it.
Posted on Oct 26, 2012
Hi, my Logik LE22A13BTCDG864 with built in dvd player has no Volume but the picture is fine can you help plrasse
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Dec 22, 2014 | Televison & Video
No sound but picture fine
It is very simple to troubleshoot any sound problem by checking the followings:
1- Speakers ( Check for continuity)
2- External sound jacks( maybe short circuited or need re-soldering)
3- Sound amplifier IC
4- Sound amplifier IC supply voltage ( Can be tested)
5- Sound mute function ( Check that it is not activated)
6- Volume control
7- Sound settings on the main menu
Jun 08, 2014 | Audiovox Televison & Video
I have voice, but no sound
Plug the USB connector into an available USB port.
• Check your computer's volume level.
• Check if your computer's volume is muted.
• Check your operating system's audio input and output settings.
• Check the headset's volume and mute settings.
• Restart computer.
May 11, 2012 | Dynex DX-840 Headset
I have a Sharp LC37D43U TV that has no audio. The volume indicator shows can be moved up or down but no sound comes through the speakers. The picture works fine. I have nothing else connected to the TV....
It appears you ve discovered the sound task levers required to adjustment properties. Your Tv can still move levers even when the volume is set to mute. Select the unmute button before any voice or audio would be reactivated. Assuming that seting the TV on mute has predominant integrety over the volume functions where not unmuting usually with the same button on the remote would not achieve accessibility to the volume functions. refer to the TV user guide for diagnostic audios. Good luck
Jan 09, 2011 | Sharp Televison & Video
Sound has gone on Samsung LE23R87!
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Apr 10, 2017 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
There is no sound
Make sure the scart lead is fully in,on the box and tv,also check the volume buttons on the box
Sep 22, 2009 | Televison & Video
LG evV Touch seems to be muted when volume is set to High
just have your phone on and pull the battery(MAY LOSE SOME DATA RINGTONES,PICTURES,ETC
Aug 20, 2009 | LG enV VX9900 Cellular Phone
Laptop volume
please give more details on laptop and win verson u are using.
if it is xp-home. there are known soundcard issues with the earlier service packs, try to get at least sp3 + fixes via windows update, reinstall drivers,
this could do the trick...
Aug 04, 2009 | Computers & Internet
Bougth in my 2004 Compaq; work fine; Last week tried using no sound no recording.
It's possible your volume has been muted. Look down where your clock is, if there's a small speaker icon, click it once. A menu will pop up with the volume controls, and if the "mute" box is checked all you have to do is uncheck it. If the slider is at the bottom of the box, slide it up until you have sound.
If there is no speaker icon, do this: Click Start. Click Control Panel. Double-click Sounds and Audio Devices. This will bring up the sound control, and you need to check the box beside "Place volume icon in the taskbar". Also, there's an option to mute the volume above that; uncheck the box if it's already checked. This will keep the speaker icon down by your clock so you can adjust the volume anytime.
If this doesn't solve your problem, check that your speakers are plugged into the right hole in the back of your PC (not in the microphone jack). There will be little pictures beside each of the jacks so you know which is which. And if your speakers themselves have volume knobs/buttons, make sure they're turned up.
If none of this is helping you, your sound card may have come loose or become defective, so you should have a professional inspect it and possibly replace it. But it's very, very likely that your volume is muted or your speakers are unplugged. You can try using headphones if you think your speakers may be defective!
Hope this helps!
Jun 26, 2008 | Sonic Computers & Internet
Sound but no picture
If "mute" has been selected, the volume will still show on the screen, and will only unmute if the volume +button is pressed or if mute button is pressed again...accordianman
Mar 09, 2008 | Audio Players & Recorders
JVC HD-52G786 52" Rear Projection HDTV Logo
32 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
