Question about ADVANTAGE Calculator
Convert to proper fraction or mixed number .851
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • ADVANTAGE Master
  • 102,366 Answers
851/1000
Posted on Oct 25, 2012
How to solve franctions
Multiplying Fractions:
  1. Make sure you're working with two fractions.
  2. Multiply numerator x numerator, then multiply denominator x denominator.
Dividing Fractions:
  2. Flip the second fraction upside down.
  3. Change the division sign into a multiplication sign.
  4. Multiply top x top and bottom x bottom.
Converting Mixed Numbers into Improper Fractions:
  1. Convert mixed numbers into improper fractions.
  2. Take the whole (non-fraction) number and multiply it by the denominator.
  3. Add that answer to the numerator.
  4. Put that amount over the original denominator and you will have an improper fraction.
Method for Adding and Subtracting Fractions:
  1. Find the lowest common denominator (bottom number). For both adding and subtracting fractions, you'll start with the same process.
  2. Multiply fractions to match the lowest common denominator.
  3. Add or subtract the two numerators (top number) but NOT the denominators.
Mar 07, 2017 | Homework
What is a mixed number or in a fraction in simplest form 0.15%
A mixed number is a number composed of an integer (whole) number and a proper fraction, one that has a numerator less than the denominator. Example 2 1/3 =2+ 1/3. 2 is the integer part, and 1/3 is the proper fraction part.
Certain fractions can be simplified further because the numerator and denominator share a (common) factor. By cancelling the common factor in the numerator with the factor in the denominator,
one gets a fraction with smaller numerator and denominator.
For example the percentage you provide 0.15% can be converted to 15/10000.
Since 15 and 1000 are both multiples of 5, the number 5 is a common factor in both. 15=5*3, and 10000=5*2000
Cancel the two 5 (simplifying by 5) in numerator and denominator leaves 3/2000. Thus
0.15%= 0.15/100=0.0015=3/200
I hope that this makes sense to you.
Sep 04, 2014 | The Learning Company Achieve! Math &...
That depends on the problem.
A mixed number is a number composed of an integer part and a proper fraction (fraction where the numerator is less than the denominator
A measure gives you 1 foot and 1/ 2 foot. Instead of writing 1.5 feet some people write 1 1/2. If you don't like mixed number you can convert them into improper fractions (fraction where the numerator is greater than the denominator.
1 1/2=1+1/2=(1*2+1)2=3/2
If you use them in a subtraction you should be careful because
7- 5 1/2=7-(5+1/2)=7-5 -1/2=2-1/2=(2*2-1)/2=3/2
You can multiply them, divide them, but any other operation quickly becomes ridiculously complicated. Some people like to use them. I don't much care for them.
In multiplication and division the general rule is to convert every number into its (reduced) improper fraction equivalent and then operate, using the rules for manipulating fractions.
Jan 09, 2014 | Office Equipment & Supplies
Multiplying mixed fractions
Convert each mixed number (what you call mixed fraction) to an improper fraction, then multiply the two numerators and multiply the two denominators. Reduce the resulting fraction to its simplest form
Example
(2 1/3)*(1 5/7)=?
Convert 2 1/3 to an improper fraction 2 1/3=2+ 1/3 = 6/3+1/3=7/3
Convert 1 5/7 to an improper fraction 1 5/7=1+ 5/7 =7/7 +5/7=12/7
(2 1/3)*(1 5/7)= (7/3)*(12/7)= (7*12)/(3*7)
The 7's in the numerator and denominator cancel one another leaving
12/3=4
(2 1/3)*(1 5/7)=4
Not all products of mixed numbers will give a simple result as this one. More likely they will not.
Dec 12, 2013 | Computers & Internet
How to divide mixed numbers?
Probably the simplest is to convert both numbers to improper fractions then divide.
Some calculators can work with fractions. With one of those, simply enter the first mixed number, then divide by the other.
Aug 14, 2013 | Mathsoft Computers & Internet
Probably the simplest is to convert both numbers to improper fractions, then divide.
How do you do a fraction on a sharp el531w
Hi eamon at hom,
Doing fraction on the Sharp El 531W really isn't that bad. I had to use pictures because, the symbols will not transfer over to your posting for me to show you. When you select the [ON/C] this clears the calculator of previous calculations and, data so that they won't interfere with your new calculations.
Let take the first example where a mix number is being added to a improper fraction. Because I used the [a^b/c] key this makes the calculator display the answer in a mixed fraction format or, a proper fraction format. If I press the [a^b/c] key again after the answer the format will change to a decimal format. The fractional formats are displayed in a mixed number, improper or, proper fraction formats. A improper fraction is really a proper fraction number with the top number (numerator) is greater than or equal to the bottom number (denominator).
[ON/C] [3] [a^b/c] [1] [ [a^b/c] [2] [+] [4] [a^b/c] [3] [=] mixed number results. Now let's do the same calculation as a improper or, proper fraction format.
[ON/C] [7] [a^b/c] [2] [+] [2] [a^b/c] [3] [=] still a mixed number result. Even though I enter the fractions in a improper and, proper fraction formats the calculator will still display in a mixed number format. This is because the calculator first displays as a mixed number if it can. If it can't then it will display the value as a proper fraction and, never as a improper fraction. To convert from a mixed number to a improper fraction format if the calculator did not convert it to a proper fraction, I have to use [2ndF] [d/c] keys on the command line.
This show a little more complex raised power use of the [a^b/c] key.
This shows the [2ndf] [x^-1] keys being used to calculate fractions.
When I first saw this question being asked it, was answered with just use the / command. Which that isn't really a good answer because, in math we like to use elimination. If you use the / command eventually the numbers are going to be rounded off and, your not going to be able to eliminate anything. If you have any further question on how to preform fractions with this calculator be sure to post your comment and, I'll be glad to help.
Jan 13, 2011 | Sharp EL-501WBBL Calculator
How to convert a fraction into a decimal
First put the calculator in degree mode.
To convert from fraction to a decimal number first enter your fraction or, mixed number. I'll convert a mixed number to a fraction first since, I don't have a key for the symbol that shows that a number is a fraction on my keyboard. Example: [3][A b/c][1][A b/c][2][A b/cd/e][ENTER]
3/2 should be entered at the home screen. While at the Home screen enter, [2nd][FD][ENTER]
1.5 should now be displayed at the Home screen.
As you can see it is really just using the [A b/c] key to enter in your fraction and, [FD] key to do the converting. The [A_b/cd/e] key isn't necessary because, mixed numbers will convert to decimal numbers just like fractions do. I just don't have the key to show a fraction symbol that the calculator uses. So to show that symbol, I used the / symbol with the fraction number.
Dec 29, 2010 | Texas Instruments TI-30 XIIS Calculator
Can this convert decimal measurements to fractions of an inch
Enters a proper or improper fraction,
b?c (b { 6 digits, c { 3 digits). When
possible, improper fractions are
displayed as mixed numbers.
3 F 4 3?4
8 3 J 21?4
Single-variable functions display
decimal results.
1 F 2 0 0.25
a F b F c Enters the mixed fraction a b?c.
(a, b, c { 3 digits each, with the total
digits { 8).
6 F 4 F 6 64?6
J 62?3
"s Toggles display between a mixed
number and an improper fraction.
30 F 4 30?4
"s 71?2
"s 15?2
"s 71?2
"y Toggles display between fraction and
decimal.
55 F 24 55?24
"y 2.291666667
"y 27?24
If a result would overflow or if fixed decimal is 0, no
fraction to decimal conversion occurs. It is not an error.
Denominator must be a whole number {999.
Nov 28, 2010 | Texas Instruments TI-30XA Calculator
How to change a decimal into a fraction
Use the [a b/c] button to convert a displayed decimal number to a mixed fraction. If you want to convert further to an improper fraction press [SHIFT][a b/c] to access (d/c).
The sequence [SHIFT][a b/c] (d/c) toggles between improper fractions and mixed fractions.
Sep 07, 2010 | Casio FX-300MS Calculator
ADVANTAGE Calculator Logo
63 people viewed this question
Top ADVANTAGE Office Equipment & Supplies Experts
julievelor
Level 1 Expert
Mishan Kasiparsad
Are you an ADVANTAGE Office Equipment and Supply Expert? Answer questions, earn points and help others
