Question about GE WSXH208A Front Load Washer
Front load ge washer humming and says door locked but no other buttons work
The washer is humming like it is draining and the front panel says door locked but no other buttons work, power, start, cycle etc. just says door locked and unplugging it and plugging back in doesnt work. cant get the door unlocked or the washer to work
  • 5 Answers
SOURCE: GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Posted on Oct 31, 2008
appldoctom
  • 311 Answers
SOURCE: GE Front Load Washer WSXH208HIWW Door Won't unlock
more info/unplug reset wait 5 min
Posted on Dec 31, 2008
SOURCE: GE Front Load Washer Model WBVH5100HWW - door lock light is on
I queryed another site; justanswer.com with technician Larry, who provided the solution. Replace the door latch assenbly part # WH10X1006 $146.99 from GE. A local parts house had the identical under a Whirlpool # WP8182634 for 59.46. Install the new assemble and all is well.
Posted on May 07, 2009
SOURCE: ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Posted on Sep 04, 2009
SOURCE: ge front load wcvh6600.
take the bottom panel off three screws and put your hand up where the door is located feeling blindly for a plastic latch....pull the latch to manually unlock door..... then with the door open unplug washer and wait 10 minutes...even if you have done this before this is different b/c the door will be open....still open plug back up and turn on..if the display comes on its the door lock...about $94.00 if no display its the panel board and that'a about $ 200.00...hope this helps too
Posted on May 29, 2010
GFWH1200DWW GE front load washer won't unlock red lock showing
From an article I found online:
See if manually opening the door will reset everything. Unplug the washer and remove the lower front panel like you're going to clean out the drain catch. Once you remove this panel you can reach up behind the upper front panel and pull down on the small plastic pull tab attached to the bottom of the door lock assembly. This will manually unlock the door so you can open the door.
Now once you have the door open, plug the washer back in and see if you can start another cycle.
Mar 06, 2016 | GE Washing Machines
Wfw97hexl0-door is locked and won't unlock or run a cycle just makes a buzzer noise every couple of seconds.
did you try to press the stop button then change the cycle to another then press the power button then press and hold the start button again that works most of the time.
Mar 11, 2013 | Whirlpool Duet WFW97HEXL Lunar Silver...
My Samsung VRT washer was working fine. The cycle appears to be finished but the door remains locked. I get no response from any of the buttons. You would think that the washer wasn't getting any...
I don't know if I have the same model SAMSUNG front loader, but I have a similar problem. The door has decided to stay locked at the end of the cycle. I can turn it off and on and even send it through another cycle, but at the end of the washing, it drains, goes to END but does not go the extra step of unlocking, like it usually would about 1min after ending the cycle.
My clothese have been through about 6 different cycles, hoping it will magically clikc open at the end. I assume they are very clean, but getting dizzy.
Any help out there?
Aug 12, 2011 | Samsung WF337AA Front Load Washer
My Maytag Epic Z washer stop in mid cycle then locked the door, we unlock the door via holding the cycle signal button down for 3 seconds, now we can open the door, close it, power up, start a cycle, but...
The low humming sound is from the pump. Remove the 3 screws on the bottom panel and remove it to check the pump filter. Here is a video for the "Duet Sport" washer. This washer is about the same. This video will show you the process and in this video the problem was similar to yours.
Happy Holidays The FixYa Team
Dec 19, 2010 | Maytag MHWZ600TB Front Load Washer
Making humming noise power not on door locked
turn off the unit.use a wet dry shop vac and attach it to the end of the drain hose this will remove all the water then you can turn it back on and should be able to open the door to get your clothes out.
after all thatis done you need to check the drain pump and make sure there is nothing blocking the pump.other likely problems are the door lock mechanism is bad or the main control board
Jul 05, 2010 | GE Energy Star WCVH6260F Front Load Washer
GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Feb 07, 2010 | GE WBVH6240F Front Load Washer
GE front load washer wont start model #WHDVH626FWW
there is a chance that your door lock has failed
Feb 06, 2010 | GE WSXH208A Front Load Washer
Washed load of towels wont work
try cleaning the drainage filter located under the front bottom panel.
Aug 14, 2009 | GE WSXH208A Front Load Washer
Ge front load washer won't go into rinse cycle.
Jun 03, 2009 | GE WSXH208A Front Load Washer
GE WSXH208A Front Load Washer Logo
107 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
