Sony ecm-99 mic connections ?
Sony one point electret condenser microphone ecm-99
2 Suggested Answers
  • 1138 Answers
SOURCE: how to use Sony Electret Condenser Mic ECM-102
The closest manual I find is at http:// www.mutinymedia.co.uk/tie_clip_mic_files/ecm44b.pdf. Shows where the battery compartment is and gives specs and usage tips.
Posted on May 19, 2009
Not working
Is it an electret condenser type then it needs a battery in the shell. The body normally can be screwed open to expose the compartment. Otherwise if it is dynamic make sure it does not need a "Phantom" supply from your mixer. Is it a balanced mic then some of them need a transformer so without seeing it and do tests this is all I can offer
Mar 29, 2014 | Samson R31S Microphone
Casio wk-7600: I just purchased it and trying to set it up. I connected a dynamic mic. in "mic. in" slot as the user manual described. The mic. didn't amplify my voice. Do I have to configure the use
Use only DINAMIC microphon (computer microphons are not dinamic- they are condenser-electret) with MONO jack.
1. Turn knob (beside "mic.in") "mic.volume" (T-7) full clockwise.
2. Press "MIXER" (C-7).
3. Press "<" (R-17) while is shown "MIXER PART>:EXT(M/I)
4. Set (check) Part [ ON]
Volume: [80...127]
N.Tresh [0]
If after microphone disconection there is a noise from speakers - set
PART [off] or N.Tresh [20] (or higher))
Jan 12, 2014 | Casio Music
My at4033a/sm is about 6 years old and only used 2 or three times .plugged it in...there is no sound
I have two words for you...Phantom Power.
Electrete condenser mic's MUST have phantom power to operate. Look for "Phantom Power" button on your Jackie (surely means Mackie) and try it again BUT turn volume down before engaging phantom power or testing mic.
Feb 06, 2013 | Audio Technica Audio-Technica AT4033A...
Hallo .i have a problem with this: microphone condenser electret toshiba EM-220 how should it work?? it need a phantom power 48+??? i have just a normal audio jack on the mic.to plug into my mixer with...
If it is a condensor mic, it will need phantom power, some mixing desks have specific inputs that have phantom power and there is usually a switch to press. Also some mics use a battery instead of using the phantom power on the mixing des.
Good luck
Aug 09, 2011 | Toshiba Audio Players & Recorders
Need a replacement mic for a TRC 447. Can't find one, and Radio Shack is of no help....AT ALL !!!!
The radio takes an electret condenser microphone. You can also use a dynamic type in a pinch, but audio quality and strength varies depending on the microphone. Several sources for replacements came up from a search, and here's one. If you need to rewire the plug or install a different one to fit the replacement mike to the radio, wiring information is here.
Mar 07, 2011 | Radio Shack TRC-447 CB Radio
How to use Sony Electret Condenser Mic ECM-102
May 17, 2009 | Sony Audio Players & Recorders
Sony ecm 719 doesn't aseem to be working properly
Hi kollydogg
The mic you purchased is a condenser type that requires either a battery(you now have), or a sony power supply. Without it, I would expect it to not do much at all. The specs look ok on it. Good for bootlegging concerts :)
regards
robotek
Jun 27, 2008 | Sony ECM719 Consumer Microphone
Problem recording in stereo
Most likely you have a problem with the MIC. Has this ever worked with this unit? If not maybe the un it is not compadable with this Mic. The instuctions and specs are available for download Here http://esupport.sony.com/US/perl/model-documents.pl?mdl=ECMDS70P&LOC=3 Good luck
Jun 12, 2007 | Sony One-Point ECM-MS907 Consumer...
Problem recording when connected to computer
In the volume control panel look for mic boost and tick the box to boost the microphone volume. It's under options properties/Advanced controls etc.
Apr 13, 2007 | Sony One-Point ECM-MS907 Consumer...
Open Questions:
206 people viewed this question
 Grubhead
Grubhead
