Question about Kenmore Sewing Machines
I have an old Kenmore Model #12493 and the needle and presser foot won't move.
The needle won't move up or down. The motor works fine. I put some oil but maybe I need to put 10-W-40 to unfreeze it. I believe the machine was not used in a very long time. Can anyone advise? Thanks!
  • Kenmore Master
  • 1,564 Answers
Are you sure it isn't in bobbin winding mode?
Posted on Oct 26, 2012
  • 2 more comments
  • Maria Agulles Oct 28, 2012
    No it is not in bobbin winding mode. The wheel won't turn either.
    Actually, the wheel turns but the needle doesn't move. The presser foot is in the up position as well. I think I should bring it someplace for service. Thanks for everyone's advice.
  • sylviaivie Oct 28, 2012
    BTW... If you ever use wd40 on a machine, which is fine for freeing things up. Always wipe off the wd40 and reoil. It's better to use Liquid Wrench which is kerosene based.
    Just reread your first post. Can you take off the hand wheel? There is a keeper washer which if it is not put on correctly, it will act like you are describing. The washer looks round with "fingers" pointing into the center. They need to line up with some knotches on the shaft.
5 Suggested Answers
SewExpress
  • 41 Answers
SOURCE: 7570 Presser foot leaver..Slow to dropp down
Good morning,
If it's been a while (more than a year) since you've had your 7570 serviced by an authorized Pfaff tech, it's likely that it's just gotten gummed up and needs some attention and adjusting.
It's definitely fixable, but not something that you'll likely be able to do yourself - some of those parts are just not easy to get to and the lubricants needed aren't directly available.
Hope this helps,
Kim & Linnette
www.sewingexpressions.com
Posted on Jul 16, 2008
MakikiChris
  • 84 Answers
SOURCE: Doesn't sew
Hi emnsam....please update your post with the complete Model Number in it's entirety and I will be able to advise you.
Posted on Aug 02, 2007
  • 27 Answers
SOURCE: Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
Posted on Jan 14, 2009
  • 5 Answers
SOURCE: i need to know how to clean and oil the machine
From the Sears Kenmore manual:
Using a small brush, remove the lint that accumulates in the shuttle area and around the feed dogs.
To Clean the Shuttle Area:
  1. This area must be kept free of dust, lint and occasional tangled thread. Raise the needle bar to its highest point and remove the bobbin case.
  2. Push levers of shuttle race aside and lift shuttle race cover and shuttle out.
  3. Clean the shuttle race with a small brush.
  4. Put a drop of oil on the center pin of the shuttle and shuttle race.
Posted on Jul 28, 2010
How to thread kenmore sear roebuck sewing machine model 158. 1789181 got at auction no books
Sears carries a lot of manuals for their machines, although usually not free. In the meantime, there are many threading videos that demonstrate machine threading. Machines of similar models will thread similarly.
Threading mom old kenmore sewing machine
Kenmore 158 17550 Sewing Machine Tutorial
Probably best to raise the presser foot when threading so the thread will seat in the tension disk.
Before trying to sew, be sure to oil your machine with fresh, good quality sewing machine oil. Open the top, the side near the needle bar, and turn it on its back to get the underside. Place a couple drops of oil every place that metal rubs on metal. Adding hot air from a handheld hairdryer will make the oil effective quicker.
Be sure to install a brand new needle and use good quality thread--not old or bargain bin variety!
On the top left, there is probably a push button. This is the presser foot pressure adjustment. When the machine is stored, this pop-up button should be released (press down on the outer ring). Being stored with the pressure full on will eventually compress the spring that provides the pressure. Also, be sure to store the machine with the presser foot in the down position (preferably on a piece of scrap fabric). Avoid running the machine with the presser foot in direct contact with the feed dogs as this will wear the feed dogs and also create grooves in the presser foot.
Kenmore 158 1601 Sewing Machine Cleaning oiling and Maintenance
Jul 29, 2016 | Kenmore Sewing Machines
How can I find accessories for an old machine?
Sewing shops are loaded with this stuff. You can order online too. You'll need the make & model number. Do a little research, I think Kenmores are simply repackaged Singers.
Aug 05, 2015 | Kenmore Sewing Machines
Kenmore model 117.300 presser foot won't move up and down
Has moving the lever felt mushy or really loose and wiggly lately? If so it's probably worked itself loose and jumped off it's path. OR if it is plastic it probably broken.
If it is definitely broken contact Sears parts for a replacement. If it is metal then you can get into the head area.... you can probably tighten the screw that holds it in place.
Good luck
Sep 17, 2012 | Sewing Machines
What is the proper way to thread a bobbin?
first go to singer website & check & see if they have a manual for the machine
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 4016) & click search
here are some other websites to check for a manual
sewingpartsonline.com
sewusa.com
the presser foot has a lever at the back of the machine or side which
lifts the presser foot, the needle move up & down when you press on the foot pedal.
May 17, 2012 | Singer Sewing Machines
THE NEEDLE WILL NOT GO UP AND DOWN
if the needle bar doesn't move the needle up & down then the machine needs to be serviced, to find out why it isn't moving
May 01, 2012 | Bernina Sewing Machines
I have a 9960 singer machine and am trying to use the buttonhole presser foot for the first time and I can not get it to sew T
the buttonhole foot snaps on to the presser bar, there's a little lever at the back of the presser bar that releases the foot, then put the buttonhole foot down on the needle plate & use the presser foot lifter (number 11) to lower the presser bar down onto the buttonhole foot & you'll hear a click sound when it snaps on & make sure to use the buttonhole lever(number 31) because the machine won't sew a buttonhole unless that lever is pulled down.
Apr 26, 2012 | Singer Sewing Machines
Kenmore 385. 15343600
Remove bobbin, presser foot, needle. Tip machine back on towel gently. Unscrew plate--don't lose screws! Do not service in presence of children and curious pets. Put foot pedal next to you on tabletop. Use Zoom Sewing Machine oil. Any part MOVING that are NOT gears get one drop oil. Any DRY ONLY gears get dab of Singer sewing machine lubricant. Replace screws. Secure screws. Open left front compartment & one drop oil @ top of needle bar. Open race shuttle (where bobbin case fits in). One-half drop oil of on oscillating hook (bottom left - hand corner...smear that oil around! Insert NEW needle all way UP in needle bar groove, flat needle shank toward back. Turn handwheel towards you and raise. Raise presser foot so that threading locates all tension slots a's you pull thread TAUT from spool to each tension slot and left to right through silver, metal take-up lever, and down to tension bracket, pass needle, then pull 6" thread towards you and thread from FRONT to BACK of needle. Place bobbin into case and "thread" it. Set presser foot on DOWN position. Turn handwh towards you, dipping needle into needle plate. Make loop with bobbin thread, pull towards you. Place a good 7" underneath presser foot (both threads). Let machine RUN on 24" scrap to distrubute oil/lube. That's it! Jimmy
Apr 05, 2012 | Sewing Machines
My singer HD 110 will sew a bit then suddenly the needle will slow down to a stop & the handwheel seems stuck, yet the motor is still running.
Hello there! Make sure your pattern selector is compatible with the presser foot. Good idea to test with a straight stitch setting: Tension: 4. Width:4-5. Length 5 after you insert a new needle and re-thread machine. Your previous needle may have become bent when machine malfunctioned. Use fabric compatible with needle size. Always raise presser foot when threading! Then always lower presser foot before sewing. Remember to use blue tip scarf needles with synthetic fabric silk thread 50. Purster thread 50, mercerized cotton thread 50-60; #11 or #9 for fine or lightweight fabric with silk thread 50 or fine Pollyester thread; #18 leather needle for leather, #14 - 16 denim . Jimmy Sweep out shuttle carefully with small brush for broken threads and lint.
Mar 31, 2012 | Singer Sewing Machines
My Kenmore stopped making stitches. I changed the needle recently to a Singer Universal regular point needles 100/16, but I dont believe that is different than what was in there before. I have a Model...
Why are you using #16 needle, that is very heavy duty? Did your machine pick up the bobbin thread correctly? Try a different needle, #11, (inserted facing away from you) is usually good. Make sure that you have decent thread and that it is the same weight top and bottom. Now rethread, with the presser foot up and when you have that done, with the presser foot stiil up, pull top & bottom thread, it should feed smoothly, now with the presser foot down, pull the thread, it should barely move. This usually seats the thread in the tension discs. Put your top tension at 3 and see if that makes a difference.
Jan 19, 2011 | Kenmore Sewing Machines
Needle move up and down slowly and hits the presser foot
when needles hit the presser foot they are out of alignment and the needles get bent
Nov 19, 2009 | Kenmore 19110 Computerized Sewing Machine
Sewing Machines Logo
194 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
