Question about Acoustic Research P315 HO Speaker
Stays on standby & won't power up?
Tv won't power up straight away
when lcd tv`s fail to power up, but stay on standby. It is usually because of bad capacitors on the power board. My 22" lcd monitor did the same. It would not come off of standby. It starts with them being slow to turn on. "Sound familiar"? I fixed mine by changing the bad caps. There were two of them.
Jan 31, 2013 | Wharfedale LP160DTRHDMI
TV won't turn on. Stays in Standby mode
Someone is going to have to go inside and check voltages and other things --no brand or model is indicated here so this is as much as I can suggest.
Dec 20, 2012 | Televison & Video
My p315 speaker stays on standby and won't power up?
some design need audio signal in to get it wake up from standby mode.
Oct 25, 2012 | Acoustic Research P315 HO Speaker
Rca 20f512 tv won't stay on
Here is a troubleshooting guide for you:
Flyback Transformer
must have supervision of a qualified service technician
Sep 23, 2012 | RCA 20F512T 20" TV
Acer p241w stays standby
CHECK IN BIOS MODE ,THIS PC NOT GOES TO STANDBY SO PROBLUM IN YOUR OS .FORMATE PC NOW CHECK .
Aug 31, 2017 | Acer P241W 24 inch Monitor
My AVR 2700 standby light is on and will not switch over to digital. I have no sound!
If it won't turn on it won't do anything at a higher level of function.
Perhap it's self-protecting.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Jul 22, 2011 | Denon AVR-2700 Receiver
EVERY TIME I POWER UP ITS SAYING F61
The below doesn't work with all Panasonic equipment but if this fails then the only fix is a replacement Laser which isn't cost effective.
U61 Fault
Corrupted or Faulty DVD in Machine.
  1. Put Machine into Standby
  2. If won't go into Standby hold 'Power' for 5-10 seconds
  3. In Standby hold 'Stop' & 'CH UP' together for 5-10 seconds until tray opens
If this fails then re-initialise the Machine as follows
  1. Put Machine into Standby as above
  2. In Standby hold 'Stop', 'CH UP' & 'Open/Close' together for 5-10 seconds.
  3. Hello displayed followed by TM AV1
  4. Put Machine into Standby
  5. 11-11 then 12-12 and finally 22-22 displayed
Switch Machine on and Retune
Apr 23, 2011 | Panasonic Audio Players & Recorders
Top Acoustic Research Audio Players & Recorders Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you an Acoustic Research Audio Player and Recorder Expert? Answer questions, earn points and help others
