Resetting code on napco express xp400 alarm
I moved recently to this rented unit and have the napco xp 400 alarm, I enable it but because I don't have the access code I can't disable it. I have to unplug it during the day and plug it at night. I shut down the ac to see if this would work but it didn't. I want to be able to arm and disarm the alarm.
SOURCE: Disarming / Access Code/ Resetting
Ask seller or previous owner the code, or read in the manual how to reset the system to factory defaults
On the previous version (Simon3) it was press cancel + clock set + Minutes+ at the same time and the power up from battery
Posted on Jan 12, 2009
SOURCE: uniden vs1100xr car alarm will
I had the same problem with my vs1100xr. The remotes for these (and other) unidens have a rolling code. Seems to me that either the remote runs out of new codes and cycles back to the beginning, or the alarm base unit somehow loses track of the codes. Either way, the alarm base unit stops accepting the codes of your remote, and so needs to be purged of its code tracking memory - reset, if you like. This is essentially the procedure for training the alarm base unit to recognise new remote (and forgetting old remotes).
This procedure is:-
1) Disarm alarm, or if in valet mode, take it out of valet mode (push valet button 3 times)
2) Turn the ignition on and off 2 times within 15 seconds.
3) Put the alarm into valet mode (push valet button 3 times) within 15 seconds of completing step 2. Alarm should beep, and remote training has started.
4) Within 15 seconds of completing step 3, push the button (#1) of the first remote you wish to use for the alarm. Alarm should beep, indicating acceptance of remote. Repeat for other remotes you wish to use - up to 4 in total. (Once the first remote has been accepted, you have all the time in the world to make the alarm learn other remotes)
5) Turn ignition on and off to end remote learning mode. Alarm should beep 2 times. New remotes have now been learned and previous remotes forgotten.
Some of these details may vary from country to country - who knows. If this doesn't work, I suggest that you contact Uniden in your country to obtain the procedure. Took me a few tries to get the timing right, what with the valet button hard to get at and having only 15 seconds between steps.
Posted on Apr 18, 2009
  • 12 Answers
SOURCE: New house, existing Simon3. How to access to add new sensors
I believe there are 2-3 different access codes-INSTALLER,USER,-Ive also had problems with programming the transmitters into certain " groups" with store bought units.
Posted on Jun 20, 2009
SOURCE: Toad car alarm - text alert texts when arming and disarming alarm
yes this is aknownprobplem to Scorpion (Toad), you will need to use relays on the trigger wires
Posted on Nov 14, 2009
SOURCE: viper alarm keypad will beep for 30 seconds every time I arm or disarm
Change the battery, 2-way remotes require 2 slim batteries on top of one another. Regular remotes only require 1.
Posted on Nov 16, 2009
Print photo using XP400 from iPhone
If it's an Epson xp400 it is compatible with an Iphone using Airprint. About AirPrint Apple Support
Jan 02, 2015 | Epson Xp-400 Small In One
How do I permanently disable a GE Simon XT alarm system? Recently moved in and I want it off so I can leave my front door open for air.
do you own the property or rent . if renting there is nothing you can do but ask landlord to do something if yours you can cut the wires feeding it if you want .
Sep 10, 2014 | General Electric Ge Simon Xt Wireless...
How to change code user 1 on a gem-rp8
I am in the same boat. We bought a house with this system installed in it. How can we change the user 1 code?
Nov 10, 2013 | Gemini Sound Products Napco Gemini Gemrp8...
I bought a home with this system and need to be able to use it. Who can help me set it up?
i bought a home with a gemini system in it / i dont have the old codes can i reset this key pad
Oct 07, 2011 | Gemini Sound Products Gemini Napco...
I have a Napco Gem-P800 Security System and the horn or horns have quit working. The manual says the horn output is 12vdc, checked voltage in alarm mode,but no 12vdc. The schematic shows a 2.2k resister...
First thing its not the resistor. The resistor is there only to make sure the siren wires are ok and not tampered with. Second found this in an install manual.
Bell Test
Enter this command to turn on the Bell, keypad
sounder and keypad LEDs for 2 seconds. The
battery is tested during a Bell Test, and automatically
every *24 hours to ensure proper battery
operation under load. The Alarm output
requires a battery in order to supply the specified
output. If the battery cannot sustain the load, a
low battery indication will be displayed. A battery
test is also performed on power-up after a 3
minute delay.
if the battery fails test replace it and try again.
Assuming no programming changes were made to the zone types that would diable the bell output. if this does not help, time for an upgrade. : ( GL
http://www.napcosecurity.com/images/panels/GEM-P800_WI850a_INST.pdf
Jul 27, 2011 | Gemini Sound Products Gemini Napco...
How can i reset visonic Powermax express
how can i reset poxermax system if i forget master installer code ?
Jan 24, 2011 | Visonic Powermax Express Home Alarm Kit
Dont know the reset code or anything about home security alarm sy
need to know brand name of system. IE Ademco, bosch, DS, it will be on the inside of the alarm panel.
Apr 23, 2009 | Electrical Supplies
Paragon alarm code
I have recently moved into a new property and it has a paragon plus alarm system fitted. I have tried contacting the previous owners for the alarm code, but to no avail.
Does anyone know a way around this problem?
Sep 10, 2008 | Computers & Internet
Computers & Internet Logo
192 people viewed this question
David Payne
David Payne
