Question about Apex Digital PF3230 32" TV
Clicking Noise, Jumpy Sound, No Picture
I left my TV on when I went to run some errands and when I came home about three hours later, there was no picture and just jumpy sound and a clicking noise emitting from the unit. The sound basically is like someone is precisely muting and un-muting the TV every second and the clicking is in sync with the muting. I unplugged the TV, let it sit for about an hour and tried to turn it back on. After pressing the power button, I hear the usual "bahmb" telling me that the tube is firing up, but after about 30 seconds the picture is not there and the muting/clicking begins. I turned it off, removed all the cable inputs, etc. and the same thing happened again. There have been no warning signs of it going out, and it is fairly new - about 1 to 1.5 years old. I just don't know what else to do! Thanks for your help!
  • 934 Answers
The SMPS (switch mode power supply) is a bit tricky in this unit. Failures in the SMPS can give false impressions of what's actually happening with regard to the symptoms. You'll need to ESR the caps in the SMPS first. C525 250v/10uf is a good place to start. It sounds like the B+ voltages are present by the noise you're describing and that would indicate that the regulator circuit is probably okay. Next I'd check things like the HOT (horizontal output transistor) for short. NOTE: If you don't have an ESR meter the job is nearly impossible. Electrolytic caps don't always show any outward signs of damage. Only by checking their equivelent series resistance are you able to determine if a lytic is the culprit.
Posted on Jun 01, 2007
Bad ignition switch
I had the same thing happen to me with my 2002 Sable GS. Drove it home from work about 35 miles and shut it off. % hours later needed to run some errands and the car did nothing, did not start and there was no clicking. I cleaned my battery terminals ( the were dirty and dark colored but not your typical battery corrosion .. white chalky looking) and placed a battery charger on it and it started. I hope this helps someone.
Oct 11, 2017 | Mercury Grand Marquis Cars & Trucks
1990 f150 wont start
Bad ignition switch.Here's a link.Here's the part.
May 07, 2013 | 1990 Ford F150
It is a 2007 Jeep Commander rocky mountain edition... My husband drove it to do some errands and then came home. About 45minutes to an hour later we went to leave again and it wouldn't start giving us a...
We have the same exact problem!! been happening the past year (about 5 times). Finally went all the way out friday, wasnt able to start after 2 hours, left work and went back sat and finally started after an hour. got it home and it wont start again. Why isn't there a FN recall on this problem that so many LOYAL JEEP OWNERS are having?!?!?!?
Feb 20, 2011 | 2007 Jeep Commander Rocky Mountain
My 2005 Dodge caravan will not tart no lights are
alternator bad??? causing a drained battery
Apr 13, 2010 | 2005 Dodge Caravan
Element electronics LCD, was on for several hours picture went blank, sound is still perfect. 12 hours later still no picture when turned on, great sound though.
Typically this failure is due to the backlight inverter going out. On this model of tv there were two runs with different parts. Open the back of the tv and open the control box. If you see a large black circuit board on the top, replace that one. If its tan then you need to take out the control box and remove the black plastic backing. If you're looking at the back of the tv the inverter will be on the left side of the control box. Its a long skinny board that has 8 black metal squares on it. Good luck and be careful.
Mar 14, 2010 | Element Electronics FLX3210 32 in. LCD TV
Randomly won't start, happened after jumping dead battery
Probably the battery. Take it the chain auto parts place and they will test it for you.
Aug 29, 2009 | 2007 Mazda B4000
1997 saturn sl did some errands, then wouldn't re-start
If it wouldn't start, you have to see if you are missing fuel or fire. Could be a bad sensor, or a bad fuel pump, or if the security light is blinking, a problem with the security system.
Jun 25, 2009 | 1984 Volvo 240 Series
Apex Digital PF3230 32" TV Logo
99 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
