Question about Hoover F7452-900 SteamVac Upright Vacuum
I have a hoover steamvac f7254-900 that needs brushes but unable to locate any that would be compatible. if you know of where they can be purchased i would really appreciate it. thank you.
SOURCE: brushes not rotating on hoover f7425-900 steamvac v2
I had the same problem and it was inside the turbine assembly. If you take the turbine assembly off the machine and open it up, you will see the turbine blades on one side and the reduction gears on the other side. The problem on mine was a needle bearing sandwiched between two washers on the reduction gear side. This bearing/washer stack is the stabilizer for the turbine gear shaft. Mine was rusted solid. I removed the washers and bearing and cleaned them up with a wire wheel being careful not to lose any of the tiny needles. Once evrything was rust-free, I reset the needles with grease and sandwiched the bearing between the washers. I then reinstalled this stack back in the case along with the other gears, regreased everything, and buttoned it up. Brushes are spinning better than they have in a long time.
Posted on Mar 22, 2008
reddevil6
  • 1673 Answers
SOURCE: Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
Posted on May 26, 2008
  • 3 Answers
SOURCE: Hoover SteamVac F7222-900 steamvac Brushes do
Solution for Hoover SteamVac (F7452-900) brushes not spinning
Uses the turbine model and same solution would be similar. Root cause is simply the main gear attached to turbine becomes stuck. This problem should not happen as often as I see other people also having this problem. Must be a poor design on Hoover’s part. It takes about 30 minutes and a Phillips screw driver and wrench. Pretty easy, just have to remember what screws went where.
Remove brushes, and front suction cover
On the bottom of the machine:
Remove the 4 screws behind brushes which attach the top faceplate
Remove the 2 screws from base in the sunken holes
Remove the two long silver screws from base which connect all the way to turbine assembly
Stand machine upright
Remove the floor select switch handle
Remove 1 screw near the center beside the intake hole
Remove the 2 screws over the rear wheels
Remove faceplate cover, the front will need to be gently pried over the clear plastic part, be careful about the upright disengaging lever under faceplate, move it under the metal wire
Remove the 2 screws in the front of the turbine assembly
Remove the 2 hoses on either side
Disengage the bar on the floor selector switch
Pull out the turbine assembly
Remove the 4 screws and 3 clips to separate the assembly
Remove the filter (which is most likely clean since, cleaning this is the manufactures only solution)
Remove the large white gear and with a wrench remove ball bearing
Remove other large white gear
Note that the metal gear attached to turbine will not move (this was my problem), with a wrench gently grab metal gear and twist free. Spin turbine to make sure it moves freely.
Put everything back together again and you should be good to go.
Posted on Jan 24, 2009
  • 3 Answers
SOURCE: We need the OPERRATING MANUAL for Hoover Steamvac 6020-900
download the manual for hoover F5810 at hoover.com. it's the same for your model.
Posted on Feb 11, 2009
  • 294 Answers
SOURCE: Hoover Steam Vac - Brushes not turned, no suction power
The Brushes not spinning is most likely is caused by seized bearings in the turbine, requiring shop service (easy fix). The suction issue can be caused by the standpipe seal missing or lower recovery tank not on properly, on some models missing front panel. I would need more exact model info to assist further.
Posted on Mar 15, 2009
Steamvac f7452-900 carbon brushes
are you shore it's not the turbine that you have a problem with
Oct 30, 2012 | Hoover F7425-900 SteamVac V2 Widepath...
Why don't the brushes go round on my Hoover carpet cleaner
HI There,
Here's a link to a Fixya repair solution that I recently did on this exact problem. It's actually a fairly common problem. The second link is to another solution that will walk you through step by step how to replace the turbine assembly if you find out this is what the problem is.
How to Diagnosis a Hoover steamvac spinscrub brushes stop spinning:
http://www.fixya.com/support/t4286338-hooverspin_scrub_brushes_always_stop
How to replace the Brush Turbine Gear if you find out this is what has gone bad:
http://www.fixya.com/support/r4530769-diagnosis_fix_hoover_steamvacs_when
If you need to purchase a new spinscrub brush block, here's a direct link to the exact brush block that's used in your model:
Hoover SteamVac Brush Block - 5 Brushes Part # 48437022
If you have any follow up questions, please don't hesitate to ask them by using the comment form here on the Fixya repair page.
Thank you,
Chris Jones
GoVacuum.com
May 12, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
I have a Hoover F7458-900 steamVac all terain. I
You can reach under the brush (on top) and pull down. The manual for an all terrain is here to download
F7452900
Apr 10, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
My brushes on my hoover steamvac all terrain carpet and hard floor cleaner will not spin what do i do
I am not sure if you have the F7222 or F7452 all terran. There is a plastic piece on the back of the block brush (spin scrubbers) these wear out or break. You may need to replace the block brush. You can find the parts below follow the link. Please don't forget to give positive feedback.
Hoover F7XXX Link
http://www.usavacuum.com/Hoover-Steamvac-s/107.htm
Jan 29, 2010 | Hoover STEAMVAC VACUUM Vacuum
Broken Brush on Hoover SteamVac Need to order new brushes
Yes you can order a brush block. It comes complete it is around $35. You can buy or order them at any vac shop or call me at my shop and I can ship them out.
Josh 614.868.0799 m-f 9:30-6 sat 10-2
Dec 18, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
I have a Hoover SteamVac SpinScrub. The brushes
If the speed control switch on the hood is in the On position, it would appear the drive mechanism for the brushes is not spinning internally. The drive mechanism could easily be replaced by a technician.
Oct 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
How to clean my Hoover steamvac brushes? or
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Press all four latches (B) and pull brush
block out. The brushes can be cleaned
under running water
Godbless
Jun 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Mar 04, 2009 | Hoover SteamVac F5914-900 SpinScrub...
The brushes aren't spinning
The brushes are belt drive by a belt. The belt is probably broken. You can purchase a new belt at a local discount store and replace it. You won't find anything that looks like a pulley, it'll just be a bare round metal portion of the brush assembly that is located at one end. The motor end will look similar.
Feb 23, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My Hoover Steamvac- the brushes are not rotating neither L or H
my hoover steamvac the brushes are not turning what makes the blue triangle that the brush attachement fits to move?
Feb 21, 2009 | Hoover F5900-900 Upright Steam Vacuum
Hoover F7452-900 SteamVac Upright Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
