Question about Zebra ZM400 Thermal Label Printer - ZM400-3001-3000T
ZEBRA ZM400 LABELS WON'T PRINT - Zebra ZM400 Thermal Label Printer - ZM400-3001-3000T
  • 5 Answers
SOURCE: Printer = Zebra TLP 2844-Z Problem = will not calibrate
just switch off the printer ,and then hold the green button power on the printer now and wait upto 4 bliknks of green led then remove the fingers.now printer will calibrate the label..
if still the problem exist .check the notch in the ribbon core.an adjust the spring tenson of rippon supply and take of roolers in printer
Posted on Dec 05, 2008
  • 257 Answers
SOURCE: how to load new labels
http://www.scanonline.com/Online-Store/ZM400-600
Download the ZM400/600 Quick Reference Guide on the right hand side of the page. They have a diagram on how to load labels.
There should also be one inside the printer - printed on the back wall...
Posted on Jul 10, 2009
  • 62 Answers
SOURCE: Zebra 2844
Do NOT use the Zdesigner driver. Ensure that you select the Zebra printer driver or ZUD driver, which can be downloaded from zebra website. Go into the driver settings and select the correct label size. Print a windows test page to verify correct operation, Once the correct windows driver is installed you can then open any windows application, paint, word, excel...etc.. and print to your zebra printer. Do NOT use the Zdesigner driver.
Posted on Jul 20, 2009
  • 32 Answers
SOURCE: Zebra S4M label printer
Check the drive belt. It might be missing a tooth if the printer is older. I can assist if you want to check this.
Posted on Oct 27, 2009
  • 185 Answers
SOURCE: I am having problems with Zebra printer MDL#ZM400
Try entering the Menu system and exiting, whilst exiting and instead of saving permanent, cycle around to load defaults. once you have done that make sure the settings are as you need such as Thermal Transfer etc and save permanent. You won't have a problem after that. If you do I would be checking the page setup in the software to make sure it fits the lables.
Posted on Jan 25, 2010
Zebra ZM400 drops interface on port 515
make sure you have no network traffic for your printer and decrease the printing speed, and make sure you are using a free port not a used and default port for the service..
Jul 20, 2014 | Zebra ZM400 Thermal Label Printer -...
How to solve this problem in zebra zm400 error condition paper out \
check the sensor under the paper, reload labels roll, labels are possible on top of sensor black plastic and not between. move gap sensor to midle of label with. check manual to know how to fit the labels thought the sensors and printhead.
Sep 17, 2013 | Zebra ZM400 Thermal Label Printer -...
Zm400 media darkness settings get reset after printings lable from SAP
The printer driver settings override the printer settings unless you tell the driver to use the printer settings. You can tell by setting the printer setting and saving it permanently. Print a configuration label. Send a label to the printer. Print another configuration label. Compare the config labels and If it changed, then the driver changed it. Set the driver as above and it will not change when you print.
Jan 18, 2013 | Zebra ZM400 Direct Thermal-Thermal...
How to downgrade ZM400 printer firmware
If the firmware here is the one you have, contact their support direct and ask them for the older version. You won't find it anywhere else.
ZM400 Industrial Printer Support Downloads Zebra
Jul 26, 2017 | Zebra Office Equipment & Supplies
On the Zebra it was printing 4x13 labels without a problem. However when I tried to print a 4x6 label it still thought there was 4x13 stock in the printer. I played around with the label format size, even...
I think this is more related to the calibration of the label each time you change the new label size. I use ZM400 and your printer should also have the same setting. Under setting, put the When Head Close setting to Calibration. This will let the calibration perform automatically when ever you load a new label size and close the print head. Well 2 label will be lost every time.
Aug 31, 2011 | Zebra 105SL Thermal Label Printer
Will not print onto the label. but can see it on the black ribbon reel.
Perhaps your darkness is set too low, or your labels are not coated to accept thermal transfer printing. Let me know if this helps!
Aug 28, 2011 | Zebra ZM400 Thermal Label Printer -...
Zm400 just keeps on spitting out blank labels even after a hard restart
It's possible the labels are not loaded correctly and are missing the label sensor. Be sure the labels are loaded all the way to the left, if you are looking at the front of the printer.
Jun 16, 2011 | Zebra ZM400 Thermal Label Printer -...
Printing and counting problem with Zebra ZM400. We have connected a Zebra ZM400 to our network and we now have a problem with printing. When we print he prints the labels 1 by 1 instead of de total...
if you sending a file (ex. pdf or picture). to the printer, can do this, if you send the proper format with normal fonts (caracteres))to the printer, work fine. build new label from zebradesigner
May 20, 2010 | Zebra Z4Mplus Label Printer
Zebra zm400 turn printed info 180 degrees
Yu can rotate the print orientation in the Z Designer printer driver, in the OPTIONS tag tick the 180Deg box
Dec 17, 2009 | Zebra 300DPI CUTTER [zm400-3001-1000t]...
How to load new labels
Jul 10, 2009 | Zebra ZM400 Direct Thermal-Thermal...
Zebra ZM400 Thermal Label Printer - ZM400-3001-3000T Logo
741 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
