Question about Uniden DECT 6.0 Cordless Phone ID
I have a hissing sound but no dial tone - Uniden DECT 6.0 Cordless Phone ID
The visual ringer will not flashing.
At an educated guess sounds like dial tone is set to decadic if there are two phones the other phone will set off ringer when numbers dialed. May need to get phone provider to change dial mode in exchange line interface circuit to be Dual tone Multi Frequency Dialing and then switch phones to Tone dialing rather than pulse dialing.
Jun 01, 2015 | Lands Phones
Why when I follow instructions does my fax not work
Dear
Try to send a fax as per following steps.
Few MFPs are comming with COPY and FAX KEY on the key board of the fax machine. Select FAX key.
Put the document face down ward on the platen glass or face upward in ADF.
Press OHD/SPK phone key, here the dial tone (the tele. line/CO line should connected to the fax machine where the socket marked as LINE.
Dial the fax no. get the RX. Tone(after ring back tone some kind of beep with hissing sound)
Then press START/SEND key.
Hope this will help you, Further it would better if you provide the make and model.
Thanks.
Feb 25, 2015 | Office Equipment & Supplies
Gigaset AL110 REGISTERED , CANT DIAL OUT OR IN
Is there a dial tone? And have you tried another phone? If there is a dial tone make sure the phone is set for tone dialing. There will either be a switch on the side of phone for pulse or tone, set for tone. or go into the menu and look for it there...
Apr 14, 2014 | Lands Phones
Need help with SSI Cineplex 1500 Home Theater hook up..have all speakerwires hooked up,have 2 wire rca cable hooked up to input on system,going to output on satellite reciever, whaen I hit test tone I hear...
Hi, Hiss soundare from RCA cables.You need to reconnect again,but using a different cable for connection.
And also sometimes home theater acts that way during test mode, Check the manual and you will see how to set the home theater to see the mode that will allow all speakers to work. It's a normal thing when connecting a newly bought home theater.It the settings.Use the manual.
Take care.
Jul 07, 2010 | Audio Players & Recorders
Won't dial out
might you have your phone set for tone on a pulse line???
Do you know what kind of line you have?
You can use pulse and/or tone on a tone line. But you cannot use tone on a pulse line.
A pulse line is cheaper ... I have a pulse line from the mid 70's and I refuse to upgrade it (costs more) to tone - whats the point - I never get any calls and im not in that big a hurry to dial for the extra couple bucks they want.
Oct 13, 2009 | Lands Phones
Samsung SGH D900I- cannot turnoff keypad sound
The steps are outlined in the article below:
D900 FAQ – How do I disable or mute the keypad tone on my SGH-D900? admin March 6, 2009 --> Note: In order to disable the keypad tone, the Dialing Display Font Type must first be set to “Normal”
To change the dialing display font type follow the steps below:
  1. From the standby screen, press the left soft key for Menu
  2. Select Settings (9)
  3. Select Display Settings (3)
  4. Select Dialing Display (6)
  5. Select Font Type (1)
  6. Highlight either Normal or Theme, using the navigation keys
  7. Press the left soft key to Save the Dialing Display Font Type setting
To turn off the keypad tone follow the steps below:
  3. Select Sound Settings (4)
  4. Select Keypad Tone (2)
  5. Highlight Off, using the up navigation key
  6. Press the left soft key to Save the Keypad Tone setting
Aug 29, 2009 | Samsung SGH-D900 Cellular Phone
No dial tone on uniden 5.8GHz digital phone
there is no dial tone on my land line uniden 5.8 ghz.
Jan 24, 2009 | Uniden Cordless Phone
Dial tone
my phone has no dial tone and when you call the phone it has a busy signal. There is no static just sounds like it is not hung up.
Sep 23, 2008 | Panasonic KX-TG1033S Cordless Phone
HISSS on line; no dial-tone; no fax in or out
it sounds like you may not have any dial tone. the hiss [white noise] you are hearing is from the dsl modem.try plugging a regular corded phone into the jack to check for dial tone.if there is none,call your phone company.also try plugging the fax machine into another jack where you know there is dial tone.
good luck
wg
Feb 02, 2008 | Brother FAX-2920 Plain Paper Laser
Uniden DECT 6.0 Cordless Phone ID Logo
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
