Rosetta Stone program have disable my sound, I have Window vista.
  • alston_ella Jan 03, 2009
    No that did not work, this is a headset with speaker that is connected by USB. My system show that I have not sound until this headset is connected.
  • alston_ella Jan 09, 2009
    Thanks for your help, but the problem was in device manager. Once I unpluged that USB headset
    and open device manager, sound, select my laptop sound device, update it system is now
    working.... Thanks :)
    Scholar:
  • 76 Answers
Go to: Control Panel /Sound /Playback /Properties /Levels/ and
check to make sure the Speakers button is not marked with mute symbol. click it to unmute.
Let me know if this helped you
Posted on Jan 03, 2009
  • mwit465
    mwit465 Jan 04, 2009
    Ok if the headset & speaker connects via USB there must be some software fot it. Is it installed and configured correctly?
    If it is, let me know the mfgr and model of both the headset and computer.
    Let me know if this helps
Why won't my Rosetta Stone work?
This is a Adobe Flash player issue with the Rosetta Stone program Find the fix Questions Rosetta Stone Community
Jun 12, 2014 | Rosetta Stone V4 TOTALe: French Level 1-5...
Rosetta stone error 1117 with access to internet
temporarily disable avast and try it again. if it works it is a AV setting, otherwise maybe your internet provider is blocking. Remember to re-enable avast as soon as possible
Nov 03, 2017 | Rosetta Stone Computers & Internet
Getting message: Minor error 1007 when running Rosetta Stone Version 3 Personal Edition on Vista. The program runs but gets stuck changing pages.
Uninstall, reboot the computer, reinstall. If the problem persists I would contact Rosetta Stone's technical support hotline, they're very helpful!
Nov 13, 2010 | Rosetta Stone Spanish (Latin American) -...
I installed Rosetta Stone and got the error 2123, is this a driver problem?
Hello my friend.Usually this error is cause because antivirus is blocking that program and usually bitdefender.So
1.Open BitDefender Antivirus in Expert Mode,
2.Click on the Antivirus tab
3.Under the Shield tab click on the Advanced Settings button.
BitDefender Active Virus Control Settings window should be displayed
4.Now add an exclusion for Rosetta Stone(click on + and find your program and click ok)
If you don't have bitdefender add an exclusion like we did with bitdefender for your rosetta stone
Feb 08, 2010 | HP Computers & Internet
I have Japanese levels 1,2 and 3 for rosetta stone. i installed all the software and entered the activation code. it says my codes are activated but when i open the software i only get a blank screen with...
The problem is related to the FNPLicensingService.exe service and FNInterface.dll file.
The first thing you can try is open Rosetta Stoneto and kill the FNPLicensingService.exe in task manager. This may or may not give you access to Rosetta Stone.
If that doesn't work, install Rosetta Stone on another computer (your license will allow two machines) then copy the rosetta stone directory from program files to the new system. Then open Rosetta Stone and it should be fine.
Before doing either of these things it's best to delete the c:\program data\rosetta stone\tracking.id file.
Aug 06, 2009 | Rosetta Stone Japanese Level 1 & 2 for...
Rosetta Stone error 2123
1.)Open BitDefender Antivirus in Expert Mode,
2.)click on the Antivirus module
3.)under the Shield tab click on the Advanced Settings button.
(BitDefender Active Virus Control Settings window should be displayed)
4.)adding an exclusion for Rosetta Stone solved the problem
or
If you have any other antivirus software
adding an exclusion for Rosetta Stone solved the problem.
Jun 16, 2009 | Rosetta Stone V3 Spanish (Latin America)...
Rosetta stone won't recognize my logitech headset
Make sure that your device is set as your default device by making sure that there is a green check mark next to the device. If not, right click and select "set as default device" (or something like that... I have vista and not win7)
If that does not work, right click on the headphones and go to "Properties" then go and under the "General" tab, change the name of the device to "Microphone HS" For some reason, Rosetta Stone does not recognize the headset unless it has the word "Microphone" in its name... Kinda stupid if you ask me. Hope that helps...
Jun 15, 2009 | Rosetta Stone V3 Spanish (Latin America)...
Error 2123 when i enter app
You may get this problem if you have BitDefender Internet Security. To fix it:
Open BitDefender, click Settings, set UI to Expert Mode. Click OK.
Select Antivirus, Advanced Settings then under Exclusions click [+] symbol, a browser opens, go to the following; C:\Program Files\Rosetta Stone\Rosetta Stone Version 3 and select the RosettaStoneVersion3 file, click OPEN. Then OK. Sorted.
May 03, 2009 | Rosetta Stone V3 Spanish (Latin America)...
Cannot recognize working microphone
I found the answer. Rosetta Stone has a problem detecting the mics if the speaker input is not in someway connected to the mic. I'm not exactly sure how it works, but I don't care and neither should you.
Follow these steps each time you want to use it and you should be fine.
*I'm on Vista, but this should work for every one.
1. Open Control Panel
2. Open Hardware and Sound
3.Open Sound
4.Set Line 1 as your Default Speaker
5. Refresh the Mic list
*All of your mics should now show up.
6. In Rosetta Stone, apply the mic you want and finish the setup.
7.Start whatever language you're using and switch back to the Sound menu.
8.Set whatever speaker you want to use as default.
*Rosetta Stone will continue to work fine until you close it, switch Users, or remove the mic.
In short you have to set the default speaker to LINE 1 to get the mics to appear. Then when you apply the settings switch the default speaker back.
Apr 21, 2009 | Computers & Internet
Computers & Internet Logo
154 people viewed this question
David Payne
David Payne
