Question about Harman Kardon AVR 300 Receiver
Harmon/Kardon AVR300-Surround Sound is always in the Off Mode.
No matter what setting the reciever is on, the surround sound
shows off on the display screen. Just the front speakers seem
to operate when a DVD is in play. The speakers work when in
a test mode, except the surround speaker is not included in the
testing operation on the AVR300
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: no surround sound
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Posted on Jun 04, 2006
renosean
  • 492 Answers
SOURCE: humming noise
Usually Humming noises come from frequency interferance.  In this case it is being caused by your input sources.  A smiply solution is to replace the cables and or seperate the source cables away from any electircal cords or sources.
Posted on Jan 07, 2009
SOURCE: Harmon Kardon unlock error
I have the same problem. All of a sudden no sound through my TV connection (but through the DVD connection the sound was still working). I changed the connection from video 1 to video 2 and got the sound back. It is not a real solution, but a practical one :-)
Posted on Feb 01, 2009
  • 4234 Answers
SOURCE: Harmon Kardon AVR300.**protect** blinks when
The protect message means that the outputs are shorted. This is a fairly common problem that can easily be fixed by any shop that handles audio gear. Expect a parts cost in the $20-$40 range.
Dan
Posted on Mar 17, 2009
Left speaker is very quiet
This may be a capacitor problem, evaluate and replace if bad.
Feb 12, 2014 | Harmon Kardon AVR 700 A 5.1-channel...
Do you know if the harman/kardon avr125 reciever is 3d capable?thanks ..mrmitchfinance@yahoo.com
Actually Home theater sound, is 3D. (Three Dimentional) Your receiver, using surround speakers reproduces 3D sound.
i.e. It is Left to Right, and Front to Rear. Thus it's 3D. If your get a 3D TV, your sound will be just fine because it doesn't come from the set. The sound SOURCE is the DVD player, CD player or Cable Box. If you use digital audio outputs (optical cable or orange colored RCA cables) from these items connected into the Harmon-Kardon, your will get the full Home Theater sound. The Harmon Kardon does not have HDMI inputs however it will not need them for the purposes of sound. Your Receiver is a high quality unit. If you want the thrill of 3D TV, go ahead and get one. After you have set it up, if you then decide you want to go to 7.1 or some other SOUND upgrade, go ahead. One thing you should know, is that there is not a whole lot of audio quality improvement available after 5.1. Unless you have a very large living room. The real quality counts when choosing the speakers and sub woofer that go into the system, not the amount of speakers you have.
I have done a number of high end home theater installations and the experience of hearing the systems (mostly 5.1) has been a thrill for the owner.
I hope this helps you,
Best Regards,
Mark
Jan 20, 2011 | Harman Kardon AVR 125 Receiver
Harman Kardon AVR 500 Only works in NON-Surff mode ?
This is a good indication that the surround processing section has a problem. This can be anything from a supply voltage being missing to a defective processing IC. Without testing inside the unit, it wil be difficult to determine. With surround procesing turned off, the entire section is bypassed. This is why standard stereo mode sounds OK. The static sound is digital noise and can be poor processing or a bad D/A converter IC.
Hope this helps,
Dan
Feb 26, 2010 | Harman Kardon AVR 500 Receiver
I have a Harmon Kardon-AVR 320, DVD 25, PA 2000. I can't get any sound with when trying to watch a DVD. I've tried every setting on each system. The L and R speaker light blink on the DVD setting. The...
We have this same problem We had friend visiting; he pushed a button and we've lost sound but only on the dvd. I've tried every setting I can think of, but can't get sound. Did you find a solution?
Dec 27, 2009 | Harman Kardon AVR 320 Receiver
DVD player and receiver will not play a dvd in surround sound ?
The dvd player is responsible for reading the surround sound track, and sending it to the receiver. First make sure you are playing the surround sound track on the dvd, many have a stereo track too. Next, try another dvd and see if you can play surround sound on that one. If you can't play surround on ANY dvd I would start looking at the audio connection from dvd to receiver. Are you using an optical cable? Red, white, and yellow RCA cables? Optical will transmit any sound over only one cable, RCA cables need one cable for each channel (LF, C, RF, LR, RR, sub.) If your connections are correct, is the receiver set to play a surround sound track? Is it set in 2 channel mode?
Dec 28, 2008 | Harman Kardon AVR 35 Receiver
Blu- Ray Surround Sound
Try optical from PS03 to reciever then change sound settings in menu.
Oct 22, 2008 | Sony Playstation 3 (PS3) Console
Apr 13, 2008 | Audio Players & Recorders
NO surround sound coming from our harmon/kardon speakers when set up to our onkyo tx-sr601 receiver. wires connected in correct areas, front left, right and center speakers work, subwoofer works. setup for...
Jun 04, 2006 | Onkyo TX-SR601 Receiver
Harman Kardon AVR 300 Receiver Logo
102 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
