Question about AT&T 1718 Digital Answering Machine
The machine doesn't answer
The machine will not answer after the appropriate number of rings. It worked fine at my house but won't work now that I have taken it to Mom's place. She lives in a facility where she has to dial 9 to get an outside line. Is that the problem? Another answering machine that was built into the phone did work but it was too difficult for her to operate. Please help!
  • Lisa Bullock Oct 28, 2012
    The machine is supposed to answer after 10 rings if the call log is full. I have cleared out all the messages and it doesn't pick up even after 10 rings. The number that I call Mom is not the number that shows up on my caller ID. Is the machine somehow recognizing the wrong number so it won't pick up?
frankmann
  • 47 Answers
SOURCE: Answering machine doesn't pick-up reliably
I found in the manual that if the machine doesn't answer after the correct number of rings, then it may be the ringing system used by the phone company. But I have also heard of people with VOIP (such as Vonage) having problems with this as well.
http://telephones.att.com/docMgt/public/art/21714/1738_english_manualpart2.pdf
Posted on Dec 13, 2007
  • 3 Answers
SOURCE: Answering machine atarts working after 2 rings only
Press the 'Change' button
Press the 'Setup' button until you hear the voice say "Number of rings"
Then use the "Skip" and "Repeat" buttons to change the number.
Press the "Change" button to finish.
Posted on Dec 31, 2007
SOURCE: Audio Feedthrough
how do you delete message that the machine is full
Posted on Jan 06, 2008
  • 13 Answers
SOURCE: Number of rings before recording answers
Choose how many times the line will
RINGS IS...” ring before the system answers a call.
• Set for 2 to 7 rings, or choose
Toll Saver 2/4 or Toll Saver 4/6.
• When set to Toll Saver 2/4, the system
answers after four rings when you have
no new messages and after two rings
when you do. Toll Saver 4/6 causes the
system to answer after six rings when
you have no new messages and after
four rings when you do.
• During setup, the Message Window will
display the number of rings (8 for Toll
Saver 2/4, or 9 for Toll Saver 4/6).
Posted on Nov 01, 2008
SOURCE: change # of ringer on an AT&T 1717 digital answering machine
I don't have a solution, I'm looking for an answer
Posted on Nov 12, 2008
Ge refrigerator won't cool. compressor doesn't come on
The compressor is gone, only option replacement.
Apr 18, 2012 | Televison & Video
Fax won't answer
If you have an answering machine connected to the same line as your fax:
To make sure the printer picks up incoming faxes, set Auto Answer to On, and then set the printer to pick up after a greater number of rings than the answering machine. For example, if the answering machine picks up calls after four rings, then set the printer to pick up after six rings. This way, the answering machine picks up calls first and your voice calls are received. If the call is a fax, then the printer detects the fax signal on the line and takes over the call.
If you have a voicemail feature associated to the same line as your fax:
Voice mail and fax can share the same telephone line if you subscribe to a distinctive ring service offered by your telephone company. This feature allows you to have multiple telephone numbers on one telephone line. Each telephone number has a designated ring pattern (single ring, double ring, triple ring, or double and triple ring). The different ring patterns let you know which telephone number was dialed, and which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
I hope this helps.
Should you need further assistance, please contact Lexmark Technical Support Center.
Feb 14, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
My new Hp Officejet j3680 caller ID is not working... All the phones in the house display the incoming phone numbers except the j3680. I wonder why?!! it shows instead ringing!!!
The caller ID phone having the tip & ring detection circuit to detect the incoming phone number, but in this model doesn't have tip & ring detection circuit to display other phone number but after connecting the other fax it will read the information which was stored like company name & phone number of other one..
Jan 04, 2012 | HP J3680 Officejet All In One Printer
Answering machine Model 25865. Is there any way to turn the answering machine "on" remotely. Example: while away, electrical storm causes machine to turn off. Is there any way to remotely...
The manual for this phone doesn't say you can turn the answering machine on remotely, but every one I've ever seen can do so. Most of them say call your number and let the phone ring...and ring...and ring, and eventually the answering machine will turn on. Ten rings is what I've seen most often. I guess the manufacturers figure most callers will hang up fairly soon if the machine doesn't answer, so they pick a large number. Try it on your phone; worst that can happen is it won't work.
Jul 09, 2011 | Uniden Cordless Phone
1. Too many rings before answering. How can I shorten? 2. Because message is short, how do I bring "beep" closer to my message?
You don't say what brand and model phone or answering machine you have, so I can't give you a step-by-step answer. But here is general information.
The number of rings until the answering machine picks up is controlled on some units by a switch. Most of the time you'll find it on the rear or one of the sides. If it's a cordless phone/answering machine combo, the switch will be on the base unit. These usually have positions for 2 or 4 rings. Some have a "TS" position as well. This is for "toll-saver", which extends the number of rings if there are no new messages. If you call to check message while you're away, if the phone rings more than the number of times you selected you know there aren't any new messages. Then you can hang up before the machine answers and you won't be charged for a call. (This is a hold-over from the days where you might need to make a long-distance call to check your messages. Most people have cell phones with national calling plans now and it doesn't really matter.)
Some newer units have a setup menu where you'll find the ring selection. On a cordless phone the menu button may be on either the base unit or the handset. It depends on the make and model.
On most of today's answering machines, the beep tone is added when you're done recording. Usually you press and hold a button to start the recording, make your announcement, then release the button. The beep is recorded when you let go of the button, so there shouldn't be much delay after the message end. If the beep comes a long time after you finish speaking, either you're not releasing the button, or you have a very old style machine with a fixed recording time. The instructions that came with these usually gave suggested messages that would take the time, and typically had you end with "...please wait for the beep and leave a message".
You can usually find manuals for downloading from the phone or answering machine manufacturer's website, or on one of the many other manual sites on the Internet. Try a search for "(insert your brand and model here) owner's manual" as a start. Of course, if all else fails another option is to get a new machine. Basic models aren't expensive, but if what you have can be made to work the way you want, why spend money?
Good luck and thanks for using Fixya!
May 29, 2011 | Lands Phones
Message: Lock lens aperture ring at minimum aperture (largest f-number) I think I'm doing this but the message won't go away and the camera won't work.
You must lock the aperture ring to f/22, so the camera can engage the aperture adjustment lever on the lens. Then, you can change the aperture with the command wheel.
When you change the aperture with the command wheel the aperture ring on the lens doesn't move when the camera actually adjusts the lens aperture.
Take the lens off and locate the aperture adjustment lever on the lens mount.
Unfortunately, this won't work with older AF lenses. So if you are using an older lens, the only thing you can do is change the camera setting to M (Manual) to adjust the aperture on the lens yourself.
May 16, 2011 | Nikon D60 Digital Camera
HP L7650 will not auto answer incoming faxes
To set the answer mode to manual or automatic via the control panel
? Press Auto Answer to turn the light on or off, as appropriate for your setup.
When the Auto Answer light is on, the device answers calls automatically. When
the light is off, the it does not answer calls.
To set the answer mode to manual or automatic via the embedded Web server
1. Open the embedded Web server, click the Settings tab, click Fax in the left pane,
and then click the Basic sub-tab.
2. Select On or Off in the Auto Answer drop-down menu in the Other Basic Fax
Settings section.
Set the number of rings before answering
If you turn on the Auto Answer setting, you can specify how many rings occur before
incoming calls are automatically answered.
The Rings to Answer setting is important if you have an answering machine on the
same phone line as the device, because you want the answering machine to answer
the phone before the device does. The number of rings to answer for the device
should be greater than the number of rings to answer for the answering machine.
For example, set your answering machine to a low number of rings and the device to
answer in the maximum number of rings. (The maximum number of rings varies by
country/region.) In this setup, the answering machine answers the call and the device
monitors the line. If the device detects fax tones, it receives the fax. If the call is a
voice call, the answering machine records the incoming message.
To set the number of rings before answering via the control panel
1. Press Setup.
2. Press Basic Fax Setup, and then press Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press the left or right
arrow button to change the number of rings.
4. Press OK to accept the setting.
To set the number of rings before answering via the embedded Web server
2. Select a number in the Rings-to-answer drop-down menu in the Other Basic Fax
Settings
section.
Dec 02, 2010 | HP Officejet Pro L7650 Printer
My machine won't receive faxes! I can't figure out how to set the rings incoming to make it work
Page 18 of the manual describes how to setup the fax Page 39 of the user manual - see link below to user manual - and I have also copied instructions at end of this post
Direct link to the manual http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=uk&lang=en&os=2093&product=441125&
Heres the support site for your machine http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=uk&cc=uk&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=Officejet+5610+&submit=»
To set the number of rings before answering from the control panel
  1. Press Setup.
  2. Press 4, and then press 3. This selects Basic Fax Setup and then selects Rings to Answer.
  3. Enter the appropriate number of rings by using the keypad, or press or to change the number of rings.
Apr 07, 2010 | HP Officejet 5610 All-In-One InkJet...
AT&T 1718 Digital Answering Machine Logo
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
