Question about Sony VPL EX7 LCD projector 2000 ANSI lumens XGA (1024 x 768) 43 VPLEX7 VPLEX7 Projector
Sony VPL-EX7 Lamp/cover error - Sony VPL EX7 LCD projector 2000 ANSI lumens XGA (1024 x 768) 43 VPLEX7 VPLEX7 Projector
4 Suggested Answers
AJIN G
  • 6694 Answers
SOURCE: Sony VPL-CX61 lamp/cover blink. Power on, it
hi,
your projectors lamp cover may be open. or there is some thing happened (may be contact problem) with the lamp cover open sensing switch. just open the door and close it. and then try again.
ok
Posted on Dec 20, 2010
Testimonial: "Thanks! And please tell me where is the lamp cover located."
welcomejee
  • 10594 Answers
SOURCE: Hello, good day. My problem
Either lamp is dead/ broken in projector or lamp cover is not fixed properly (its located at bottom side)
Please check lamp and replace it if its broken and make sure lamp cover is fixed back on its location securely after lamp replacement/ checking.
Thanks.
Posted on Jan 24, 2011
heathgr
  • 442 Answers
SOURCE: Sony VPL-EX3 "Lamp cover problem", it wont switch
There is a small switch that detects when the lamp cover is securely tightened down, so that it protects the user from the high voltages, hot surfaces, excessive bright light in the eyes, and damage to the face if the lamp implodes due to old age and overuse.
so check if the switch operates when a toothpick is pushed up and down in the cavity.This model suffers this problem when the cover is slightly warped with old age.
so put a strip of folded paper between the cover plastic protusion that actuates the switch and the switch and secure the cover and see if this is all that is needed to activate the switch properly.
if it now works, you can try putting a small drop of silastic on the cover protusion and wait till it sets over several hours in order to lengthen it slightly so that it reaches the switch properly
Posted on Jul 01, 2011
How to removed Lamp/cover error of Sony VPL-EX5 projector?
Take the lamp cover back off. Check the mechanism that the projector uses to sense the door. It might be a small pressure switch. Check whatever triggers the mechanisms is still attached to the door and hasn't broken off.
Sep 15, 2014 | Sony VPL-EX5 Projector
Want to reset sony vpl ex7
where it the RESET located? I do not have any on my VPL-EX7
Jan 02, 2012 | Sony VPL EX7 LCD projector 2000 ANSI...
I have sony vpl ex7 and the power button keeps on blinking?
If it blinks with 2 flashes, it's overheated. Check the filter unit.
If it blinks with 4 flashes, a fan is not working properly. see if any fan is not turning on, and check why.
If it blinks with 6 flashes, it's a system internal failure.
Jun 28, 2011 | Sony VPL EX7 LCD projector 2000 ANSI...
Hello, good day. My problem is relationship my sony xga vpl - ex7 not turn on. Only lighting the lamp/cover.
Thanks.
Jan 24, 2011 | Sony VPL EX7 LCD projector 2000 ANSI...
hi,
ok
Dec 20, 2010 | Sony VPL-CX61 LCD Projector
Sony VPL-ES3 Multimedia
Hi Marsat!
Actually both the filter cover and lamp covers have a long straight plastic part which is inserted in small hole. At the end of the holes are micro switches. When you fit the filter cover this switch is pressed and projector knows that it is ok to turn on. Similarly if lamp cover is loose the micro switch is not fully pressed resulting in this message. Tightening it presses the micro swith and the indication vanishes. In your case if plastic parts are intact, lamp cover screw is fully tight, filter is clean and properly seated with a click sound, then may be some micro switch has malfunctioned and you have no option but to take the projector to some qualified repariman.
Regards
Raheel
Jul 10, 2008 | Sony VPL-ES3 Multimedia Projector
Sony VPL EX7  LCD projector  2000 ANSI lumens  XGA (1024 x 768)  43  VPLEX7 VPLEX7 Projector Logo
320 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
