Question about NEC MultiSync® LCD195VXM+ LCD Monitor
Black screen with message Video Input 1D-sub No Signal
2 Suggested Answers
  • 95 Answers
SOURCE: Video input: 2 D-sub No signal /Video input 1 DVI-D No signal
Below is a link that may help you...Good luck http://www.techspot.com/vb/all/windows/t-35070-DVI-to-DVI--No-Signal-on-LCD.html
Posted on Apr 06, 2010
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
'no signal input'
D-Sub is usually used for input from a computer, make sure the TV's input source is set to Analogue or Digital (or DTV) as it seems to be set to accept input from a computer, if you do not have a computer connected, then this is why it is complaining of no signal. It will not automatically defer to normal TV without being told to do so, have a look in the manual, or guess around the remote control to change the source of the signal.
Sep 14, 2007 | Westinghouse LTV-19W3 19 in. LCD...
Dell 2407 Can't get rid of "No S-video input signal" message on screen. How do I get rid of this?
Your S-Video connection is referring to a round plug for a TV input signal. Most computers will not have this connection unless you have a TV based video card. If your using a TV 'monitor' as your computer's video device, their will either be a button on the monitor or your remote to allow you to choose the input signal. If you are using a VGA or HDMI or DVI cable as the connector between the two devices, most likely, the light is referring to one of these, as its video source. You will need to match the cable & monitor source detected to get a usable picture output.
Good luck.
Toby.
Sep 28, 2015 | Dell Computers & Internet
Computer screen keeps going black,,turn the monitor off and on,,screen come up for a bit,,the d sub appairs then gos black again
Hello there
You dont say which machine you have but a common problem is they are set for the WRONG input,
Have you checked using the 'onscreen' menu,of the monitor that you are looking at the right INPUT ???? D-sub is the 15 pin video cable input from your computer to the monitor. .It will go dark if you are not supplying a signal on that input.
Sep 24, 2014 | Computers & Internet
Sansui no signal
Acer produces a number of LCD computer monitors. Acer's monitors range from 17 inches to 27 inches. Some monitors offer wide-screen viewing, embedded speakers, high-definition visuals, and various display connection ports. Acer computer monitor problems include common issues such as dead pixels, error messages, and blank screens caused by incorrect connections. Some reviewers have also detected image problems with DVD playback on some models.
"Input Not Supported" Error Message Acer computer monitors such as the G24 may issue an "Input Not Supported" error message when users set the display resolution too high. The G24's maximum display resolution is 1920x1200 with a 60Hz refresh rate. Maximum resolutions vary according to the specific monitor model and according to the capabilities of the computer's video card. b> "Input Out of Range" b> Some Acer computer monitors may report an "Input Out of Range" error message due to incorrectly set monitor refresh rates. Much like the display resolution, each monitor also has specific monitor refresh rates with which it is compatible. Blank Screen or "No Signal" Error b> Like other monitors, Acer computer monitors feature color-coded power indicator lights. If the power indicator light shows green, the contrast or brightness levels may be set too low and should be adjusted via the OnScreen Display. If this does not rid the monitor of a black screen, the monitor may be experiencing hardware failure. The "No Signal" or "Check Cable message" may indicate a problem with the monitor's cable connection with the video card. This error may also appear on a blank screen backdrop if the monitor is plugged into the incorrect port on the computer or if the computer is frozen and needs to be rebooted. Faulty power cords or outlets may cause the screen to be black and to show no power indicator color. b> Image Issues b> Some review sites such as CNET have reported problems with streaking and ghosting during DVD playback on some Acer computer monitors such as the AL1931. (A "ghost" is an identical offset image as the primary or desired image.) Unstable or unclear image issues may be caused by incorrectly programmed VGA timings or incorrectly installed monitor drivers. b> Dead Pixels b> Dead pixels and sub-pixels can cause a variety of display enjoyment problems. Acer will only accept returns on LCD computer monitors that have "more than four (4) defective pixels per million pixels." Further, the central area of the monitor may have no more than one defective pixel. Acer does not differentiate in warranty terms between pixels and sub-pixels. Hope this helps.
Jan 20, 2013 | Acer Aspire 4720 Notebook
I have a samsung syncmaster 930b attached to an HP Pavilion Slimline s5660f Desktop PC, plugged into the DVI port of the PC. However, I cannot get the monitor to come up. There is power to it. I get the...
from user manual troubleshooting section
(When connecting D-Sub cable) Check the signal cable connection. (When connecting DVI cable) If you still see an error message on the screen when the monitor is connected properly, check to see if the monitor status is set to analog. Press Source button to have the monitor double-check the input signal source.
Source button Activates a highlighted menu item.
/ Push the 'SOURCE', then selects the video signal while the OSD is off. (When the source button is pressed to change the input mode, a message appears in the center of the screen displaying the current mode -- analog or digital input signal.) Note : If you select the digital mode, you must connect your monitor to the graphic card's port using the DVI cable.
https://images10.newegg.com/User-Manual/User_Manual_24-001-063.pdf ninth page in user manual
source button fourth from the left when facing monitor. looks like a box with an arrow pointing left.
Mar 05, 2018 | Samsung SyncMaster 930B 19" LCD Flat Panel...
I got a teac ag-v8060 audio/video surround receiver and I'm tryin to hook up some surrounsound speakers along with a jbl g cinema sub can you describe where the wires go in the back of receiver? The sub...
On the back of the receiver, there could be "pre out-subwoofer". If your subwoofer has the same type cable input, that would indicate it is a powered(amplified) sub. Connect those two. If subwoofer only has red/black speaker inputs, it is a passive sub, which means spkr signal runs thru it and then to your main left and right spkrs.. Run your receiver main or front spkr left (red/black) and right (red/black) to those corresponding sub inputs, and then sub spkr outputs to each of your main left/right spkrs..
For surround, on the back of the receiver, there should be spkr outputs (red/black) noted as "rear".
Just make sure red to red, and black to black.
Hope this is helpful.
Apr 28, 2010 | Teac AG-V8060 Receiver
I have a blank screen on my HPf1905 monitor. I have a HPm7330n computer. How do I know if its the monitor or the video card? Monitor shows a message no input signal,then goes to sleep mode.
if the message you recieve is no input signal if only means that you have a problem with your video card, the monitor is fine but you need to have your video card check
Nov 21, 2009 | Computers & Internet
How to hook this monitor onto my computer
You would have got a CD with this moniter..
we ahve install that cd..
and its better to check the cables first which would be the
VGA CORD that is blue in colour which connects your moniter with the tower.
We can check the connections with the moniter for the Tower and then install the cd.
Feb 06, 2008 | Computers & Internet
NEC MultiSync® LCD195VXM+ LCD Monitor Logo
139 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
