Question about Karcher Garden
Hi i have a karcher hds 745 and when i turn the switch on the motor runs all the time and dose not stop
My hds 745 keeps runing wether you pull the triger or note the motor only stops when you turn the switch off
SOURCE: karcher HDS 750 HOT HIGH PRESSURE WASHER
G-day Mate.
Did you check if the igniters? they may be cloged up with ****. Unscrew the Sight glass on top of the boiler and run the machine (in cold or hot mode, doesn't matter, as the igniters are running all the time) and see if there are working, you should take them out anyway and give them a wipe with a rag as general maintenance item, and when you put them back in there should be about 5mm gap between them.
Less common reasons for the boiler to not work
- Faulty fuel solenoid valve, (You should hear a click sound about 5 - 10 seconds after you pull the trigger)
- Dirty fuel filter,
Take a look at those simple things and let me know if its any of these.
I have a Karcher HDS 750 1989 Year model
This machine just keeps going, it's had a fairly tough life but it has stood up to it all,
i hadent spent anything on it until about 6 months ago when i purchased a new fuel pump for it as the old was wasn't pushing 170PSI to the Disiel injector it had slowly droped 70psi, and it doesn't create a hotter burn in the boiler, but still very good for a 19yr old pump,
other than that thats all it's needed, it's still going strong to date
Very robust machine.
my e-mail is cgodfx@internode.on.net
Cheers Matt.
Posted on Nov 07, 2008
  • 14 Answers
SOURCE: Karcher k4.98 switching on and off
The machine has a pressure leak. Check for a cracked controll head or either a leaking outlet elbow. The machine will short cycle if the holding pressure can not be maintained
Posted on Mar 06, 2009
  • 92 Answers
SOURCE: my karcher hds 745 has started blowing fuses. it
Dear dumbelldaveb,
Having a 13A fuse I am concluding that the machine is single phase. Most probably you have a faulty capacitor. Check the capacitor and if you find it expanded and leaking...then you must change it with a new one. If you see the capacitor is normal just the same it could be shorted. So change the capacitor with a new one and try to start the machine WITHOUT LOAD. Which means no water inlet and no gun attached. Doing this you can also remove temporarly the micro switches. If the motor still hums, then most probably there is a fault in the electric motor.
Now if you find out that the fault is the capacitor (which in my opinion it is the case)...you must see why the capacitor broke. If when using the machine and the gun is closed, the machine starts on and off on its own,...this will damage the capacitor. This on and off fault could come from a leaking gun. Or a leak from the seals. Whatever....the machine must not be left going ON and Off when the gun is closed. This ON and OFF could be due to faulty micro switches and control valves.
I am very sorry to mention a lot of things, but I hope as in many cases,..the changing of the capacitor will solve the problem. I wish to add that the electrical lead wire must be checked. On many occasions I found that the electrical lead wire from the plug to the machine was damaged and shorted, ..due to pulling, wear and tear.
Regards,
Fulltech.
Posted on Apr 22, 2009
SOURCE: my karcher pressure washer has lost its water power
I have the same problem. With mine I have to remove the tip that I am using then pull the trigger and then replace the tip and pull and pressure should return. I believe that one of my valves is sticking causing me to reprime the pump frequently. I am trying to clean or replace my valves to fix the problem.
I hope this helps.
Posted on Apr 25, 2009
  • 92 Answers
SOURCE: karcher 550m has lost alot of its pressure,Why
Dear emmettbrickw,
Many of the models of Karcher machines, have a valve that under pressure...will compress and at the same time it will let water by-pass and circulating inside the head. As this valve compresses it also puts off a micro switch. This all happens when the gun is closed. This valve is called a SPILL VALVE or sometimes a CONTROL VALVE. Now for various reasons (example you store the machine with pressure in the system)....the seals of this Spill Valve get damaged. So you can have a problem in which the machine stays off....or a problem like yours...the machine continues running with gun closed. Your problem with gun closed...the spill Valve is not compressing and therefore not stoping the machine. At first when this happened it caused a fault also in your machine's valves. The gun was closed...pressure grew high...and this burst the intake valves for sure.
So my advice is that the spill valve must be renewed and also the intake valves. You must also check the Miro-Switch to see if it got stuck in the on position. If micro-switch is faulty, this also must be renewed. The Spill Valve is often located where you find a micro-switch holder with an electrical wire coming out. When you find this micro-switch...detach it from machine...then put on machine for a few minutes and press micro switch to see if machine stops. If machine stops...then at least Miro-Switch is OK. Always do these tests with electrical protective clothing, Shoes and Gloves!! Now if your machine does not have a micro-switch...then you have a spill valve which only by-passes water. This type of spill valve also needs checking and if need be renewed.
In a few simple words, the spill valve does all the work after one has opened or closed the gun. Sometimes by changing the spill valve only....the pressure will get back to normal. If not ...suction and delivery valves must be checked.
Regards,
Fulltech.
Posted on Jul 21, 2009
My Karcher 530M runs ok until I release the trigger, then it will not start again unless I switch and allow the water to run through for about 15 secs before switching on again
Hi Cliff:
My experience is that the pump pressures prevent the engine from starting, so we hold the trigger while starting.
My brother has cut a wedge of wood that he uses to jam the trigger open to bypass the problem. It can get a bit wild if the wand is not secured when the unit is started..
Aug 10, 2016 | Karcher Garden
My karcher isn't giving me hot water why? It's a hds 601c
Morning Chris Taylor,
You have an igniter/burner coil inside your system that has to be
functioning properly to have good combustion going inside the coils of your heater unit (very bottom).
I tried to pull the documents to see if yours was kerosene powered (like mine: not a Karcher)... but could NOT pull your HDS 601C up on the company site (Karcher.com, sorry... It's me & my new PC).
Poor water = de-lime water coil procedure
Cool water = No combustion, check kerosene, oil (burner fuel)... filter... (etc.) and check your spark!
If your air supply is insufficient to support great combustion your ignitor & fuel nozzles can get heavily built up in soot. My manual says to clean it with detergent & water... I have only ever used Berryman choke & throttle body cleaner.
All the precautions... don't hurt yourself!!
Hope this helps...
KARCHER HDS 601c ECO STEAM CLEANER BOILER HEATING COIL ELEMENT HEATER...
Operating manuals
http://www.ultimatewasher.com/download/hot-water-manual.pdf
May 01, 2016 | Karcher Garden
Why is my HDS 745 hunting
Please define hunting?
Sep 24, 2014 | Karcher Garden
I would like a karcher instruction manual for a HDS650 pressure washer
I believe the HDS sends spark to the ignitor any time the machine is on ( hot or cold) You should hear the crackle of the ignitor in the burner area. Perhaps the ignitor rods are not properly aligned. Perhaps your ignitor coil is bad. There are several safety switches and the thermostat that would keep the burner from firing if they are bad. There is a pressure switch that turns on and off the motor for hot or cold operation. That is apparently working. I think there is a flow switch that turns off the burner. The thermostat might not be opening and closing contacts and that will keep the burner from working. I believe there is a high temperature safety switch as well.
Jul 15, 2014 | Garden
Karcher hds 501c motor wont turn
never try to turn it on unless you squeese the trigger at the same tme it cant activate the pressure bypass unless it is running you will get ahumming noise and if you leave it on like that you will burn the motor out try that first if still no good come back to me
Aug 09, 2009 | Garden
My karcher hds 745 has started blowing fuses. it switches on the power light comes on and it makes a buzzing noise for about five seconds and then blows the mains 13amp fuse. i have replaced it twice but...
Dear dumbelldaveb,
Regards,
Fulltech.
Apr 19, 2009 | Karcher Garden
you have an electrical short in the motor windings. you'll have to either replace the motor or buy another washer. also check to see if the motor isn't locked up with a piece of trash. to do that you'll have to dissassemble housing until you get to the motor. it should turn easily by hand. if so you have a short.
Apr 19, 2009 | Karcher 2500 PSI Pressure Washer
KARCHER HDS 1000 de
Hi Jim,i have the same unit to,can you tell me are you connecting to mains water via the small black header tank at the back next to the boiler or is it connected straight to the pump head inlet?
Theres more than one reason i'll just start with this one 1st.
chris
Aug 08, 2008 | Karcher 2500 PSI Pressure Washer
Karcher HDS 750 HOT HIGH PRESSURE WASHER
G-day Mate.
Cheers Matt.
Apr 07, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
60 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
