Question about Black & Decker Leaf Hog Blower Bv4000
How do I switch between vac to blow? - Black & Decker Leaf Hog Blower Bv4000
  • 718 Answers
The long thin tube is for blow and the larger dia. tube is for vac. and usually mounts at the fan area on bottom of your machine. Do you still have your instruction book or the local home center where you purchased it, will answer this question and give direction. Good Luck...
Posted on Oct 26, 2012
Sucking and blowing
Shop-Vac® Brand. The Original Wet/Dry Vac™
https://www.shopvac.com/
Shop-Vac® is proud to be an American-based company. ... When we say the Shop-Vac® is powerful, we're talking debris cleaning, leaf-blowing, heavy-duty, wet or ... Many of our vacs are backed with a 3 to 5 year warranty, but we've seen ... I had just gotten back from work, so my arm was hurting, and I really didn't want to ...
My ShopVac Blows - WOOD Community
community.woodmagazine.com > Forums > Tools and Tool Buying
Nov 23, 2009 - My ShopVac suddenly started blowing dust out the exhaust ports. I don't mean a little dust, it blows almost as much dust as it sucks in!!!! ... ... I'd look it over very carefully looking for tears or splits. Might be a good idea just .... A few months ago I purchased a Dust Deputy and hooked it up to my shop vacuum.
10 Shop-Vac Vacuum Hacks For Around The House - Thrillist
https://www.thrillist.com/.../10-shop-vac-vacuum-hacks-for-around-the-...
Sep 14, 2015 - Simply flip the switch from suck to blow and blow leaves to your heart's... you really need to get your act together if you're using a Shop-Vac for ...
Shop Vacs...and dust control? - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Cleaning Tips
Jan 09, 2016 | Shop Vac Vacuums
How to switch it to blow instead of vac
Usually when you remove the vacuum part there should be another part that snaps in place of the vacuum part. This puts a safety grid over the intake propeller and protects the user from cutting their fingers off
Dec 18, 2014 | Garden
How to repair Toro Super Blower no longer blowing, only vacs/intakes?
when you remove the vac part there should be another "grid type" part that snaps in place of the vac tube. This engages the safety switch and keeps your fingers out of the impeller.
Oct 05, 2014 | Toro 51592 Super Blower Vac 3-In-1...
The a/c only blows out of the top of the dash. it does not blow through front or feet area. i was told it is a hose,vacuum, and switching mechanism. under dash or hood. i am just hoping that it is...
your air direction control is vacuum operated. either the vac line came unhooked, or it has a leak in it. trace the vac line, and replace it. should work.
Sep 29, 2013 | 2003 Jeep Grand Cherokee
Heat and air are not blowing
Usually if the vent system is vac operated, the air will blow out the defrost if the system fails. I am showing a blend door actuator that could have stuck in one place. But it could have vac controls too.
If you can see the actuators that control the direction of air flow you can test them with a vac gauge and hand pump.
You may need to get a used shop manual to get the repair procedures.
Mar 04, 2013 | 1992 Buick LeSabre
2004 silverado ac vent switch
Vac. Leak check under hood & behind dash vac.hose smaller than a pencil
Jul 23, 2012 | 2000 Chevrolet Silverado
A/C stuck on floor vent.
a vac. problem several possible causes a vac. line off at the vac. canister under the hood. a broken vac line with time some lines crack and are no longer functioning a bad activator under your dash. a bad control head on your dash if it just started acting up I would look to source vac.
Jun 25, 2012 | 2005 Nissan Altima
A/c and heater air blows only in windshield vent
That means you lost your engine vacuum source and defroster mode is the default position. Check for the vac. line coming off engine to the firewall under hood if that vac line isn't damaged or leaking,check under dash allthe way up to the vacuum selector switch for the HVAC if you have good engine vac at siwcth around 17-18 inches of vacuum. Then it must be a faulty switch assembly.
Sep 14, 2009 | 1997 Chevrolet Lumina
Black & Decker Leaf Hog Blower Bv4000 Logo
333 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
