Question about Olympus AS-2300 PC Transcription Kit
Unrecognized foot pedal
I made the mistake of plugging my foot pedal into my USB port before I had installed the software - obviously it could not find the device drivers, but now that I have installed the software properly it will not even look for the device drivers to try to re-install them for the foot pedal. I have tried going into device manager to see if I could remove it and re-install it but the foot pedal is not even showing so I have no idea how to go forward from here to get the foot pedal recognised. I have looked at previous advice about the serial number - I only have one serial number, which has a [T] above it, so I do not think it can be anything to do with that. FURTHERMORE, although the software appears to be installed properly, when I have tried to import files there is nothing showing in the folders - I try to repeat the process it says that the file already exists, but I CANNOT SEE IT! Any ideas here?
4 Suggested Answers
SOURCE: Driver Issues
My dictation pedal for the Olympus AS-4000 used to work on windows XP, but I upgraded to windows Vista and and the foot pedal no longer works. I have tried it on another XP machine and it works fine, so it can't be the foot pedal.
I have downloaded a patch from the internet, but unfortunately this does not seem to have resolved the issue.
I have contacted olympus twice and they have been very unhelpful.
Posted on Feb 20, 2008
DDMaster
  • 10 Answers
SOURCE: I have installed Oympus DSS player for transcription purposes.
Check whether your foot pedal is a RS-26 or RS-28, and the DSS Player version. For some strange reason the DSS v5 is not backward compatible with the RS-26 foot pedals, and so you would need to purchase a RS-28.
I hope this hepls!
Posted on Jun 11, 2009
Samsteve11
  • 11 Answers
SOURCE: Recovering deleted files from olympus VN-4100PC voice recorder
Chances are there to recover such kind of deleted files from your Olympus recorder.
First things first: DO NOT take any more videos or audio with the recorder that you want to recover files from in case you may quite possibly ruin your chances of voice memo file recovery.
Then connect your device to a PC, and have a try of Photo Recovery (also recover audio, voice memos, video files etc), a data recovery program which is good at recovering media files lost. If you are Mac OS X users, turn to Data Recovery for Mac.
Lastly, I hope you good luck. Again you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP.
Posted on Jul 14, 2011
I just received a sony foot pedal FS 85 that will not work on my laptop- is there a USB adaptor available so that I can use this foot pedal
The FS 85 is obsolete. I am not sure if it can be adapted to usb but there is a USB version of that foot pedal, the Sony FS-85USB Foot Control.
Details are sketchy but the highest compatibility is Windows XP and driver software isn't mentioned by I would be surprised if it would function without an installed driver...
Sep 28, 2017 | Sony Audio Players & Recorders
Laptop not recognizing device when plugged into laptop how to fix
The computer is not recognizing the device because the appropriate software or driver is not installed on the device.
Most of the time when you connect a smartphone into a compatible laptop the device drivers or software automatically install, so the laptop may recognize the smartphone.
Here are some possibilities as to why the device is not recognized.
1) The USB port is bad.
2) The USB port is not activated
3) One of the devices does not support the other
Here are a few possible troubleshooting solutions:
1) Go to the smartphone manufactures website and download and install the updated device driver and software then plug in the device to see if it is recognized.
2) (if Windows OS) Go to the Device Manager to see if the device is showing up when it's plugged in. If you see the device in device manager right click the device and choose to update the driver.
3) (if Windows OS) Additionally, in device manager you can check your device's USB ports to see if there is an issue with the ports that may be resulting in the smartphone not being recognized. You can choose to re-enable the USB ports or update the software for the USB ports.
Hopes that helps resolve your issues.
Open Device Manager Windows Help
Nov 07, 2015 | Acer Computers & Internet
Usb port flash drive unrecognized but broadband is ok before it is working suddenly its stop
plug your flash drive in to a different usb port. if it's still unrecognized try it on another laptop or comp. if the result is still the same then your flash drive is faulty.
Jan 08, 2014 | Lenovo 3000 Y410 Notebook
I can't get pictures uploaded for my kodak easyshare C813. I don't use an sd card, i just use the internal memory. Recently, i uninstalled the software (for some or another reason) and was just using...
When you plug-in the camera into the USB port, what is the message?
Do you see any pop-up on the lower right hand side of the screen?
Usually the pop-up is "Device is ready to use" or USB device unrecognized if the USB is not recognized
try the camera to other USB port
Oct 18, 2010 | Kodak Easyshare C813 Digital Camera
Can I buy a foot pedal to plug into a hp compaq hard drive?
Connect the foot pedal to your personal computer. Insert the foot pedal's USB cable into an available USB port on your computer. Insert the foot pedal's installation CD into your computer's CD-ROM drive, and follow the ensuing setup wizard's instructions. The installation CD will configure your foot pedal to the computer, and install a control application from which you may set shortcuts and commands.
Thanks for usinf Fixya
Proton
Jun 11, 2010 | Computers & Internet
I plug my usb external hard drive into my laptop but it does not read. How can I fix it?
Have you tried changing which USB port it's hooked into. If not is there any cd (Drivers/Software) for your external / that it came with?
If not you might have to search for unrecognized hard ware. This will help with that: http://www.techmantras.com/content/finding-drivers-unrecognized-hardware-windows-system
Dec 23, 2009 | SmartDisk FireLite 40 GB Hard Drive
Canon Rebel XTi not recognized when plugged into usb
Vista is your problem. Solution...buy an inexpensive card reader to download your pics to a folder you create on your desktop. From there, you can send the pics to your photo editing software.
Oct 23, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
RS-25 & RS-27 Foot Pedal not working with Vista x64
I had the exact same problem. Per Olympus you have to buy the RS 27 foot pedal. It IS compatible with Vista 64bit. RS 25 which is what I have IS NOT compatible with Vista 64bit.
Cheapest I found online is $43+ shipping for RS 27 foot pedal.
There is a free upgrade to DSS Player 7 on Olympus website that you will have to do for it to work with RS 27 foot pedal.
Jun 05, 2009 | Computers & Internet
EXT HD UNRECOGNIZED BY LAPTOP
Which operating system are you using? Windows XP or Vista?
Here is the website that you can download the driver for your external harddrive.
http://support.wdc.com/product/download.asp?modelno=WD1600JB-00FUA0+WD+&x=1&y=11
Mar 26, 2009 | Western Digital External USB 2.0 80 GB...
LS2208 scanner unrecognized by my HP notebook
It is not likely VISTA will run your scanner software as it is very old. However you could check program compatibility mode and set it to run as Win 95/8 Check compatibility in Start/Programs/Accessories or go to my Computer Windows Help[ and type compatibility in the search field But I don't think you will get far.
Aug 05, 2007 | Symbol LS2208 Handheld
Olympus AS-2300 PC Transcription Kit Logo
102 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
