Question about Refrigerators
Coleman Powerchill overheating plugin
When I plug the cooler in any 12 volt outlet, the plugin of the cooler gets real hot. The first plug even melted. I'm worry about causing a fire. Is there some problem with the wiring of this cooler? How can I fix this problem?
  • 159 Answers
SOURCE: my coleman cooler is not cooling!
does it work with 12v and 110v and lp gas if it does it take up to 1 day to be very cold
Posted on May 16, 2009
SOURCE: EVERSTAR COOLER HDBC36ID
Mine is 11 months old - pooling water on right (which is theside i keep colder for beer/soda/water), also my glass door on right has water between panes, I just called franklin (everstar) and they say a service guy will call in 5 days... I hope.
Did you get help and are you 'happy' with the service done?
Posted on Jul 04, 2009
  • 4 Answers
SOURCE: Coleman 12-volt cooler stoped working/fan burned out
Sound like you have the newer version. These fans can be found at Radio Shack or anywhere computer parts are sold. It doesnt have to be an exact replacement. Just big enough to fit over the Cooling fins. Also make sure it's a 12 volt motor
Posted on Jul 14, 2009
  • 49 Answers
SOURCE: Overheated melted light cover could this have caught fire?
This is not a recall but the manufacturer will most likely cover the repair. The relay for the lights is stuck closed on the control board. The repair should include all cosmetic parts that were damaged plus a new improved control board and a new socket assembly with a thermostat built-in. Contact your local certified service depot for the repair.
Posted on Aug 20, 2009
SOURCE: thermoelectric plate does not appear to transfer heat
you should see if theres a DC voltage going to the plate or not. it should noticeably heat up instantly with proper voltage applied. if power is there and it doesnt heat then the thermoelectric device needs to be replaced. also you should be able to measure a resistance of the plate. Should not be shorted or open. it should be a relatively low resistance. like a few ohms. and it may read different depending on which direction you connect the leads.
Posted on Nov 07, 2009
Small 12 qt. Coleman cooler (3000000540) works in RV, works plugged into ac adaptor. Doesn't work plugged into 12 volt in my car or my brother-inlaw's car. Phones do charge in these same outlets.
Could be that the 12 volts circuits in your cars are not supplying enough amperage for unit to operate . Low amp items will work but the hungry ones will not.
Sep 09, 2015 | Home
I have recently bought a 40 qrt coleman eletric cooler. Has it one da y and dc plug stopped working. Replaced fuse, and checkes all volt outlets in truck as well as fuses in fuse panel they all work.
Did you accedently or spark power wires? These have a tendency to blow the diode if that happens. Also check fuse in plug of cooler. Take it apart an look sometimes the wires break.
Jan 11, 2015 | Coleman 40 Quart Powerchill...
How to remove fuse from Coleman thermoelectric cooler
Unscrew the chrome circle at the tip and it will come out.
Nov 28, 2014 | Coleman Thermoelectric Cooler 12v...
Can i use a coleman ac adaptor model 5232f640 for charge a car battery
Isn't that the power cord for a Coleman 40 qt Powerchill Thermoelectric Cooler? Without the proper equipment, you take a chance of over-charging and blowing up your battery as it would be a direct current with nothing to regulate it and no needles to let you know how much of a charge it has.
Why not catch a ride down to AutoZone and buy a NOCO/180 mAh 12 Volt solar battery charger (that's right, solar power charger) for less than $25? It comes with 8' of cable and suction cups to mount it on the car while it charges with sun light. Neat little things for sure. I own two.
Sep 14, 2013 | Electronics - Others
Coleman thermoelectric cooler not cooling
Sounds like the Peltier effect elements have failed.
http://www.tetech.com/Peltier-Thermoelectric-Cooler-Modules.html
Depending on your handyman skills, you can change them yourself or have someone troubleshoot and change them.
Sep 12, 2012 | Coleman 40 Quart Powerchill...
Coleman 564 refrigerated cooler - Need male plug. Where to find.
get a new plug from lowes. it will tell you what collor goes were. cut old plug off and take with you.
Jul 03, 2010 | Coleman (100076) Compact Refrigerator
Kool Mate 40 Cord melt down
The unit itself is the problem. You should call coleman customer service and tell them you have been haveing this problem from the start and ask to talk to a manager. Tell them that the cord has been replaced numerous and that you checkd voltage and this is fine. You want a new unit because it has been happening since you bought it and all the keep sending is the cord. Tell them if anythig bad happens pertaining to safety issues that you don,t want to call the better bussiness office and that they will be responsible for any damage done due to a faulty unit. Be professional about it and I am sure they will help you.
Jan 08, 2009 | Coleman (100076) Compact Refrigerator
I HAVE A COLEMAL 40 QUART POWERCHILL COOLER. THE MOTOR BURNED OUT AND I CANT FIND THE RPLACEMENT PART. THE PART IN THE DIAGRAM DOESNT LOOK LKE THE 1 I NEED
Coleman 40 Quart PowerChill Thermoelectric Cooler
What diagram are you looking at? I only see one motor in the unit and it's the only one that Coleman has made for your item.
If all else fails, Coleman has a customer service line that can help, 1-800-835-3278 or you can email them at consumerservice@coleman.com
Hope this helps,
Glenn
Jun 29, 2008 | Coleman Heating & Cooling
Refrigerators Logo
100 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
