Question about Dishwashers
How do you reset a Kenmore (Bosch-built) dishwasher (M/N: 630.13902011)
I have a Bosch-built Kenmore dishwasher (630.13902011) that is sending an error code E 24. I have blown and sucked out the drain tube and replaced the drain pump. When the washer first starts the pump does discharge water remaining in the sump area (I can feel the water coming out in the under-sink disposer). Then there is a pause followed by a slightly louder noise (more like a soft grinding) for about 7 seconds. If I do nothing, the E24 code appears. If I open the door and shut it, the dishwasher continues through all cycles with no further problems (water drained, dishes clean, etc). Does the control board need to be reset?
  • Steve Taylor Oct 27, 2012
    Or more simply: how does one reset this Bosch-made model? Amazing the dishwasher did not come with such instructions or with a list of error codes!
catriver
  • 878 Answers
SOURCE: Dishwasher doesn't drain
Greg, if the model number ends in GO1, your dishwasher has a piston nut assy. thats problably giving you the grief. If this assy. goes bad you will have water left in the tub at the end of the wash. A common GE problem. It's located under the filter screen in the back and just unscrews out. Part number is wd24x199. It's an easy fix. Look up the part on the net to get an idea of what it looks like. Catriver..post back.
Posted on Jan 27, 2007
Falling Down
  • 67 Answers
SOURCE: Danby DDW1802W Cycle Problems
The fill valve is probably stuck in the full position. It's at the bottom of the tub and looks like a small tube with a cap on it. You should be able to move the cap up and down easily.
Posted on Nov 30, 2007
SOURCE: Bosch Dishwasher SHV4303UC - Does not drain.
Try looking for slithers of glass etc under the impeller. Remove the sump covers (filters) and look into the bottom. There will probably be a small cover held down by a screw. Under this is the impeller. Roll up a hand towel into a cigarette shape and slide this under the impeller - that should clear anything out.
Posted on Apr 17, 2008
  • 1073 Answers
SOURCE: kenmore dishwasher makes grinding noise while draining
disassemble the top of the dishwasher pump, remove the bottom spray arm and remove the screws on the top of the pump housing this will get you started
Posted on May 03, 2008
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
My Kenmore Elite Ultra Wash Dishwasher keeps shutting off before entering the cycle. I have repositioned dishes, even emptied it, changed cycle and tried everything. When I press the start light flashes...
I too had problems with the Kenmore Elite (aka Bosch). The issue was solved by replacing the Lock Sensor on the door. After replacing the sensor the dishwasher has been working. Hope this helps.
Oct 08, 2013 | Kenmore Elite 24" Built-In Dishwasher with...
Bosch has discontinued making the front flip tine insert for the bottom rack. I have two broken in my Bosch dishwasher. Can I substitute another manufacturer's part?
A solution to this problem would be to sell me your dishwasher. The law firm for which I work is looking to acquire an old unrepaired Bosch SHU 33 dishwasher for some ongoing litigation. If you (or anyone else with this model Bosch) could send me some details regarding your dishwasher, you may be able simply to buy a whole new dishwasher. My email is JFraser -at- jshlawmi.com.
Thanks!
Sep 07, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
Bosch dishwasher will not drain
drAIN AND CANCEL BUTTON WILL RESET UNIT;)
Feb 25, 2010 | Bosch 24 in. SHE44C05UC Stainless Steel...
Bosch shx43c05uc dishwasher wont reset
press and hold the drain and cancell button together for 3seconds it will reset. let me know what happened.
Dec 13, 2009 | Bosch Integra 300 Series SHX43C0xUC...
How do I reset an old Bosch dishwasher SHI4302UC ?
Assuming that you can control power to the dishwasher from your kitchen panel switches, hold down the power on switch on the front panel of the dishwasher and recycle power (switch off and on) at the kitchen panel switch.
This will reset the dishwasher.
Sep 26, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher stopped. no lights, no nothing
My Kenmore just did the same thing, I verified power to the unit.
Jun 26, 2009 | Bosch SHU3306UC Built-in Dishwasher
Need stronger Door Springs, to able wood door panel
The best suggestion I could give you is contact either Sears or Bosch and ask for recommendations. You will require the proper springs designed for dishwashers.
Feb 03, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Bosch dishwasher
If you telephone Bosch on
08705 678910 they will be able to send one out to you
Hope this helps
Deep Diver
Jan 10, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishwashers Logo
69 people viewed this question
Top Dishwashers Experts
Owen Barnes
