Question about Sony Minidisc Deck Mds-je510 Recorder
My minidisk deck will not load the cartridge into the mechanism to play
Only sometimes it will play but now most of the time the disk is stacked inside and a eject sound is going continuously. Of course this wonderful machine is faced out for obvious reason and so far no on can fix the problem. Is there anyone who experienced similar problems in the past and could help me ( and my technician) with some good hinds?
  • Fred Stumpf Oct 28, 2012
    Ok I will add a few more details to the problem. When the power switch is off it start to switch it on and of with messages like STANDBY or WELCOME etc. When I try to put a disk into the loading tray it want go in because the mechanism is not grabbing it while the motor is still running inside. If I push it a little more than it gets stuck and I have to dismantle the top cover to remove it. Don't know what to do, I have had a few Technicians to have a check up but they always come up with no answers or that there are no spare parts to come by.Its a shame then I like this system better than any other CD player
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 236 Answers
. This webpage will (eventually) show you how to shim the microswitch: http://snnake11.tripod.com/ .
The 510 is from 1998 and is a bit long in the tooth. Later models sound better. Buy a used one from ebay or craigslist. It's easier and cheaper than trying to fix and old one.
And see the MiniDisc Equipment Browser -- http://www.minidisc.org/equipment_browser.html
Posted on Nov 12, 2012
4 Suggested Answers
Obertelli
  • 3006 Answers
SOURCE: minidisc problem
Only just seen your question whilst trawling for old unanswered questions.
My answer will be way too late for you, but may be of benefit to others searching the site.
You didn't state the make and model of MiniDisc player, but the symptoms are classic indicators of a failed playback head.
Sadly, it's irreparable. It's definitely not a DIY job, the parts will almost certainly be impossible to find, and even if you can, will cost more than obtaining a replacement model.
I'd suggest that you search or post a request on your local FreeCycle/Freegle group (first postings must always be to offer something, but you can reply to existing offers straight after joining). Failing that, you can pick a unit up very cheaply on auction and classified sales websites.
Posted on Feb 03, 2010
Arpi
  • 326 Answers
SOURCE: problem with the mds-je320
Hi there, it seems that one of the sensors is bad. Please contact me at LIVE session. Arpi
Posted on Jun 24, 2007
TOLhamRadio
  • 509 Answers
SOURCE: Hi have an mds-je500 minidisk
The small limit switch for the disc in position typically goes bad on about 40% of all Sony Minidisc recorders. It is a $5 part, but will probably cost you $35 to get it installed.
Posted on Nov 09, 2010
After tape is loaded plays a few secs then powers off
Sounds like damage to the mechanism. An inspection inside will determine if any plastic parts are broken. You can also watch the deck load the tape with the top cover off, you will see where it fouls up. The shutting down is simply to prevent further damage. Sometimes the mode switch can play up. This tells the electronics which position the video is in, be it play, record , rewind etc. If it gets dirt or the contacts are worn it starts telling lies to the electronics and so it shuts it down. But I think more likely some mechanical issue, than the mode switch. Observation will soon show up any faults in playback.
Nov 29, 2016 | Televison & Video
Sony stacking system LBTd505, the sound from the record deck suddenly went very faint. The cd and radio sections are fine. I have tried a new stylus, but no difference. Any ideas?
You have two options. First a faulty cartridge. Or a faulty pre-amp in the main amp.
You can find out if the cartridge (and amp) are playing up. By removing the connectors on the cartridge.
Then with the volume turned up to about half, with your finger, touch each one of the wires one at a time. It will not harm you at all. But you should hear a loud buzz on one wire on the right and a loud buzz on the left on another wire.
The two other wires will either produce a crackle, or a tiny buzz, or nothing at all.
If you do hear a loud buzz on two wires. The cartridge is faulty and needs replacing.
If you hear a slight buzz on them or weak sound. There is either a bad connection between the deck and amp. Or the pre-amp inside the deck which is only used by the record deck so will not effect any other function, is faulty.
You can remove the record deck connections to the amp and again with the amp on half full, touch the inputs with your finger. If you are not hearing a loud hum or buzz, the pre-amp is faulty. If you do the connectors are faulty.
Jun 11, 2016 | Sony Audio Players & Recorders
The tape cassette doesnt rewind
This can be a toughy without having the unit but the Chinese decks (After 1992 vintage) all but the expensive units and here are the makes they are using the same mechanism. This deck has two belts and the one is from the motor to the capstan and the other is fed from the capstan (under the flywheel) to the fast forward and rewind mechanism. If the fast forward is okay and the tape plays okay then the belts sre working and the rewind gear is out of position and if you are lucky then all you do is to push the left reel spindle in and replace the small plastics circlip which by the way do come loose sometimes. If that does not help then is it sometimes cheaper to buy a cheap portable set and fit that into your deck The motor on some is on the side and others sort of on top depending if it is a top loading or front loading machineI have seen these same mechanism in the following makes Philips Telefunken Akai Sony Teac Supersonic Roadstar and so on I hope this help.
Oct 08, 2014 | Audio Players & Recorders
10 disk player inconsitently plays or reports "err" for each disk position. How to fix?
Please remove the cartridge and check all the discs on it ., It is possible that over a period of time the disc could have warped. The disc while loading could be going into the wrong track and hence the mechanism needs a check on the path . Alignment of the loading tracks must be checked or corrected.
Feb 25, 2011 | Cherokee Jeep Grand CD Changers - 10-Disc
Do you make a firewire compatible with Handycam DCR-DVD105E and a Mac pc? Mac does not support minidiscs. I also have an external minidisc drive which allows me to play the discs on the Mac but I want to...
If you can "play" the minidisc into the Mac, it should be possible to "copy" the files onto the Mac's disk-drive, at maximum-speed, rather than playing them in "real-time" mode.
The Sony MZ-RH1 mini-disk player allows "digital" file-transfer of the contents of minidisks into a computer, through a USB (not Firewire) connection.
Jan 11, 2011 | Sony Handycam DCR-DVD105 DVD Camcorder
Hi have an mds-je500 minidisk player that stopped accepting disks, worked perfect one minute, says load error next each time i try to load, then says eject even though disk doesn't go all the way in....
Nov 05, 2010 | Sony MDS-JE480 Mini Disc Player
Sony DSR-80 DVcam - Cartrdge loading mechanism fouled...
The part number for the cassette assembly is A8312671F and it is around 500.00 NOT 200.00 as quoted in the article, and this price comes from the store that is reccommended in the article.
The service manual with the part numbers and prices is 9-977-696-22.
May 01, 2009 | Sony DSR-80 DV/Mini DV VCR
Speakers thumping and crackling even when turned off ,varies
im not knowledgable about car audio systems, but i would check to make sure your deck/changer is clean. it takes very little debris getting into your changer/deck to foul cd deck mechanisms. if you dont regularly check the surfaces of your disks for prints/smudges/exc.. you can easily foul the deck by repeated insertion of dirty disks. it could be that an internal motor is weak, a tiny drive belt could be sheared, or a gear inside has broken teeth. the lens that reads the disk information (instances that the disk did load) can be fouled leading to messages on your deck face. both problems you mention , to me, seem to point to fouled internal mechanisms. if you have kids, they can do awful things to your car when you are not around. im a parent and i know lol. the only thing i know to suggest to you to slove these problems is if it is after market deck, you may need to remove it and take it to a repair facility because most cd decks at least the ones ive had arent shade tree mechanic friendly. if the deck is your factory installed, check your car owners manual for information. lastly, if it were me, i would use a multi-meter and check for proper voltage at the wire terminals. good luck!
Jan 15, 2009 | 2005 Chevrolet Equinox
AIWA AM-F75 delete a disk
if same as am-f70 press play then rec/edit with red button pressed, advance mode button till erase is displayed (trk only) or erase all (whole disk) hope this helps!
Dec 08, 2008 | Aiwa AM-F70 Personal MiniDisc Player
Problem with the mds-je320
Sep 30, 2006 | Sony MDS-JE320 Mini Disc Player
Sony Minidisc Deck Mds-je510 Recorder Logo
193 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
