Question about Lexicon Pro Audio Players & Recorders
No audio input or output from Lexicon Omega interface
Although MIDI functionality is fine, I do not appear to be getting any audio input (or output) from my Lexicon Omega. This applies to all line mic inputs. I've uninstalled/reinstalled the latest drivers and have no problem with cubase, Sonar X1 and Ableton recognising the unit (although even playing previously recorded tracks from these DAWs isn't outputting from the Omega either). In addition, I was under the impression that even disconnected from the computer, the unit would still function as 4-in mixer and would at least show/monitor levels from an input which would be audible from the main outputs or headphone socket. This is not happening either. I've had the unit from new and used it for a couple of weeks without issue. It has been lying unused in a drawer for some time but appears to be in mint condition. I certainly don't remember having any trouble when using it previously. Can you help please?
SOURCE: Blue Screen of Death when running MIDI input to Lexicon Omega
I tried the above - works perfect!
Thanx lumps...
Posted on Feb 07, 2008
SOURCE: Sonar Producer 6 - Audio/midi devices/controller-surfaces..Which settings??
o always run at 0 on play back recording -3 with drums use anlog cables then select anlog 48000 24 bit if u can if its digital cable might use 96000 bit rate ok spdif watch it close on digital for digital clips never go in red keep steady balence cheak your sorse tape how loud is that adjust your stuff to sound good at peaks never hit red in digital mode does this help sum
Posted on Mar 13, 2008
  • 174 Answers
SOURCE: Drivers Disappear
Its a fight between 64 and 32 bit versions. Audio codec is not so compactable with your sound card sysaudio file You need an updated driver which is compact-able with direct x latest can solve your problem
Posted on Jul 19, 2008
  • 46 Answers
Install Windows Vista service pack 1.
Posted on Aug 28, 2008
SOURCE: I installed my tascam mk2.under Cubase LE4. Midi
Have you clicked the little "monitor" icon (looks like a speaker) on the armed audio track so that it goes orange? Once on, you should see a signal on the VU meter (assuming the line in has a good signal etc). Once recorded, turn the monitor off again to listen to the track with all the others.
Posted on Mar 31, 2010
I have an Omega/Lambda/Lexicon and the vocals seemed to be delayed with the timing established by the instruments. Any ideas of what to do?
Without the configuration you are using we have little to go on. How is the system wired? Are you saying when you run instruments AND mics into this then record they do not play back together? If the instruments are MIDI types and you play back along with the vocals I would expect the MIDI instruments to be delayed a little as it takes time to transmit the note info at 31.25Kb... It takes about 1/3000 second for EACH MIDI character and note messages take three of those for a total of about 1 ms. One millisecond IS noticeable by the ear... and if you have several instruments it may take several milliseconds to service all the instruments. If you are recording ANALOG instruments the delay should be imperceptible.
Apr 26, 2011 | Lexicon Lambda 4x2x2 USB Audio Interface
I have a lexicon omaga drive but when i hook it up its like i need a 64 bit driver
Don't know what OS you're running. Omega has published drivers for Vista and 7 64-bit versions. They say they don't support XP 64, but when I hooked my unit up to my computer and the hardware install wizard came up the OS found and installed Microsoft published general USB audio device drivers for all inputs, midi, and mac USB channels of the Omega, and automatically set it as my default device. I hooked headphones into the Omega unit and could hear system sounds. So far so good. Went to My Music and fired up an audio file. Windows Media Player started up and the song started playing but I couldn't hear anything. Opened the same file with Audacity, could see the VU meters bouncing, but still no sound in my headphones. Went in to the preferences of Audacity, and manually set the speaker default to the Omega mac USB device. Hit play again and voila! I had sound. Closed the file, started WMP manually, went in to options, and again set the speaker default to Omega mac USB. Opened the same audio file and this time it played just fine. The driver files Windows used for my card were
C:\\WINDOWS\SysWOW64\, C:\\WINDOWS\System32\drivers\ks.sys, C:\\WINDOWS\System32\drivers\ksthunk.sys,
all version 5.2.3790.1830
Hope this helps everybody else with this problem.
May 21, 2010 | Lexicon Omega Pro Studio External Sound...
Omega Studio won't record to computer
The omega is like an external sound card. It has to be connected via your computer with a device driver,the software that came with the lexicon. Then you record on a software program such as Cubase.
Go to the guitar center for more help or go to google .com and type in lexicon omega. Lots of sights to look for answers or better yet go to lexicon omega's home site.
Feb 28, 2009 | Lexicon Omega Desktop Computer Recording...
Lexicon Lamda Problem
I have a Sterling st-51 condenser mic and purchased a Behringer xenyx 1002b mixer. Similar problem, dynamic mics work in low impedence with or without phantom pwr on. My Washburn acoustic bass with preamp in line input section. So I tried it on my Omega Lexicon interface. The condenser mic and everything else works on the Omega. This unit has a wall wart ( your Lambda is USB powered). I checked the voltages with a meter and found 23 volts from the mixer and 48 volts from the Omega. Further, I have two Shure SM-82 line mics which work on the mixer with the inputs turned all the way down but do not work on the Omega nor on my Spirit SX mixer which has 48 volts phantom power. The SM-82s are old line mics that have a 9.6 volt battery in the sleeve. They overload badly in all but the 1002B mixer. Their voltage should run btwn the 9.6 battery or a 22 volt phantom power.
Check your Lambda voltage, It could be way less than needed by the st-51. I will check with a friend who has the Lambda and check its voltage. Bet it is too low.
Again, My St-51 and 1002B mixer combo barely works at 23volts, the Mic gain is all the way up as is the channel slider and the main output slider. I cant get any reading on my led meters, occasional bump on the first light, no possible way to clip the input or the output and have to turn the high eq off and the mid way back due to hiss noise. Hope this helps,couldn't find minimum voltages on the ST-51 as yet.
Dec 27, 2008 | Lexicon Lambda Usb Desktop Recording...
Can't get signal on an audo track.
in my system sound not working
my system is VIA samuel 2
Dec 15, 2008 | Lexicon Omega Desktop Recording Studio...
Lexicon omega driver
Yes having the same problem with new driver that Lexicon put on their site 2.5 driver has screwed up everything and the soundcard is nolonger working because of this new driver even their website is down very poor avoid Lexicon Omega
Aug 09, 2008 | Lexicon Omega Pro Studio External Sound...
Lexicon lambda no sound during playback
AFTER you open a new poject go to "Devices" then "Device Setup" click on "VST Audio System" then on he right side where it says "ASIO DRIVER" make the selection say "Lambda ASIO" then click OK
Jun 05, 2008 | Lexicon Lambda Usb Desktop Recording...
Cubase and Lexicon Omega
Yep that's Vista for you! Try microsoft. com for a patch or the product's website.
Mar 16, 2008 | Lexicon Omega Desktop Recording Studio...
60 people viewed this question
Top Lexicon Pro Audio Players & Recorders Experts
Are you a Lexicon Pro Audio Player and Recorder Expert? Answer questions, earn points and help others
