Question about Homelite Garden
What size chain do i need for a 16in bar for a homelite 38cc engine
  • Homelite Master
  • 14,405 Answers
  • 35 Answers
SOURCE: Chainsaw chain won't move on 16" Homelite bar
Sounds like th clutch brake is engaged. Try Pushing firmly foward on the hand guard in front of the handle. It should click to release the clutch brake.
Let me know if this helps.
Posted on Dec 31, 2008
  • 10865 Answers
SOURCE: spark plug gap
hi kathy. this is an easy one. first of all you will need a spark plug gapping tool, about a dollar at any auto parts store. Your chain saw most likely calls for PLUG TYPE: Champion CJ6 SPARK PLUG GAP: 0.025 in. (0.63 mm).
Here is the website of a short video to show you exactly how to gap the spark plug. write back if you need any more info.
www.expertvillage.com/video/6078_spark-plugs-gap.htm
Posted on Feb 07, 2009
SOURCE: need true chain/bar size for my husqvarna Model 254 chainsaw
Maximum bar size of 20" but would recommend 18", if it is running sluggish, check compression, if low replace the piston, if it is 135psi or more then make sure the airfilter is clean and then tune the carb and make sure you get good revs and throttle response throughout the rev range, use the typical carb adjustments from the owners manual from the Husky web site. This is a 5hp saw and is capable of cutting some big lumps of hardwood so no excuses on the power front
Posted on Mar 16, 2009
dontbother10
  • 2220 Answers
SOURCE: homelite 290 manual
I have to ask, does it have a chain oiler?
Oregon Bar & Chain Selector
http://www.oregonchain.com/commonpgm/Selguide_Selctmfg.asp?BusId=OCS&SellReg=USA&LangId=ENG&ShowRem=Y&ShowAnsi=Y&ShowQuality=Y&ShowCombo=Y&usertype=OCC
Your model is listed. HTH
Lou
Posted on Oct 15, 2009
dontbother10
  • 2220 Answers
SOURCE: need an owners manual
Contact Us
All McCulloch Products
1 (800) 521-8559
Good luck with an Owner's Manual
Please have your saw within easy reach.
Posted on Oct 24, 2009
Picture sketch
'Bogging down' Incorrect fuel air mix, fuel starvation or air leak.
Jul 31, 2013 | Poulan Pro Chain Saw 38cc, 16in. Bar,...
Need replacement part
Google Homelite PN# 310508001 and you will find it at many locations
May 09, 2013 | Homelite 33cc 38cc 45cc Chainsaw Oil Pump...
Chain will not move with engine running. Brake is off
Try loosening the chain adjustment (bar) screw or locate and clear as needed any material found to be caught between the drive sprocket and chain.
Jan 07, 2013 | Husky Husqvarna Chain Saw 240E w 16in bar
Manual for 330 homolite chainsaw
losen the nuts for the clutch cover and tighten the screw on the side of the bar
Mar 23, 2012 | Homelite 33cc 38cc 45cc Chainsaw Oil Pump...
Need to tighten chain
Hi, first you need to use some pressurized air to blow out all of the debris from the attachment points of the bar. Then, loosen the retaining bolts for the bar . Find the tensioner screw beside the bar. You can spot this screw by looking at the saw head-on. Next, turn the tensioner screw clockwise until you can only lift the chain a quarter inch from the bar. Afterwards tighten the retaining nuts, but do not over tighten! Hope this helps.
Nov 16, 2010 | Homelite 33cc 38cc 45cc Chainsaw Oil Pump...
Chain not moving
Perhaps. The chain and bar get very hot, sometimes causing the chain to bind, there is a reason for the bar oil reservoir. You may have burned out your clutch. Your chain may be excessively tight. I suggest you find a neighborhood chainsaw seller/mechanic and pay for a quick inspection. While there ask for a 10 minute instruction on how to use your saw. Purchase of a complete set of personal protective gear sounds like a good idea too. HTH
Lou
Sep 17, 2009 | Homelite Garden
The gas cap will not go back intto it's place also the bar oil cap very hard to get back on. 16in. 3816au 38cc
Poulan uses poorly made gas and oil caps that are easily crossthreaded.  The body is metal so usually only the caps are damaged.  You may be able to repair the threads with a small file by working carefully, otherwise they can be inexpensively replaced. Just google Poulan Wild Thing parts
Mar 23, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Cutting crooked
The chain is not sharpened evenly. One side is cutting faster than the other. Also check to be sure that the bar itself is not worn excessively on one side. The cheapest way to test this is to change the chain.
Dan
Feb 17, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Garden Logo
88 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
