Took fingerprint,dna test, photo.need to remedy
You may have this
posted in the wrong product category. Please select another category
appropriate to the problem and re-post the problem so the correct
expert will see and respond to the question..
This is for
car and truck problems related to factory installed systems not add
on aftermarket systems.
This post
can't be removed or moved, please re-post the question in the correct
product category. Thanks
SOURCE: 2000 Cadillac Deville DTS is in anti- theft mode
you can reset the system by turning key to on position for 5-10 mins and then try starting it but its probably a short or grounding prob try the engine to chassis ground
SOURCE: 99 Ford Ranger won't start because of theft system?
try turning the key to the acc position and leave it in that position till the light goes off. if it goes off then turn key off and then try starting if that dont work call a ford dealership and ask a mechanic
SOURCE: 1997 toyota 4runner anti theft system prevent ignition. How do we deactivate anti theft system.
you have to call tyota and thet have to send you a new computer
SOURCE: 97 mustang want start just turns over
no you cannot bypass it. What you can do is put an OBD I computer in it or there is a programmable ECM on the market now. These are very expensive options and alot of skill is involved. Where are you located?
SOURCE: 99 chevy cavalier theft system light on steady, car wont crank.
My 2000 cavalier has done this for 6 months. You take your key out then open your door, wait ten minutes and the system resets itself and the car will start-annoying you bet!!!
The CTD system requests the IPC to illuminate the indicator only when the ignition switch is OFF. The CTD system uses the indicator in order to identify system status. For specific CTD condition that will illuminate the security indicator, refer to Content Theft Deterrent (CTD) Description and Operation .
The IPC performs the displays test at the start of each ignition cycle. The indicator illuminates for approximately 3 seconds.
SERVICE THEFT SYSTEM
The radio illuminates the SERVICE THEFT SYSTEM message when the VTD system detects a failure. The radio receives a message from the theft deterrent control module via the serial data circuit requesting illumination.
This is one you need to take to the dealer , unless you have a GM factory scan tool !
