Question about Sharp R-820bk 900-watt 0.9 Cubic Foot Convection Microwave, Black
We have a R-820BK-F Serial #71677 Sharp Carousel Double Grill Convection it seems that there is no electric going to the unit the electric is good the cord is good. This appliance is in a Motor Home. Thank you Melody
pgh_pa_guy
  • 2992 Answers
SOURCE: Built-in Sharp Carousel II Microwave Convection Oven died.
There are a couple of safety thermostats in the oven to shut down power if something overheats. One is on the magnetron tube (the microwave source), the other is on the cooking cavity. These sometimes go bad. There's also a power line fuse that may have failed, or become loose in its mounting clips. These can be tested with an ohmmeter; they should all measure very close to zero ohms if they're good.
Another possibility is that the control circuit board in the oven may have failed. I have worked on several Sharp ovens where the power transformer for the board has gone bad for no good reason. If the board goes bad the oven may appear to be dead as well.
Microwave servicing is best left to professionals. If you're thinking of keeping this one, take it to a service shop (or call for home service) and get an estimate. Then decide whether to repair or replace.
Hope this has helped a little. Thanks for using Fixya!
Posted on Feb 02, 2010
Testimonial: "Thank you. I will check it out and then decide whether to repair or replace."
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp Carousel Microwave Convection Oven
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Then let us know if the hard reset does not fix it.
You may have a bad keypad.
Posted on Sep 16, 2008
SOURCE: Sharp Carousel II Convection Microvave R-3850
My sharp microwave convection oven (R-1870) runs for 59 seconds and stops. If I push start it runs for another 59 seconds and stops. How can this be fixedd?
Posted on Oct 22, 2009
tiway1
  • 100 Answers
SOURCE: i have a sharp carousel
The tray is Sharp part # NTNT-A011WRF0 or NTNT-A034WRE0. (Same part, just different numbers).
Here's the link to where you can find it...
www.microwaveglasstrays.com
Posted on Jun 30, 2008
SOURCE: manual for sharp grill 2 convection oven
where is the fuse at on the sharp grill 2 convection
Posted on Feb 01, 2010
When the unit is turned on it shoots flames from the roof of the unit WHY?
It sound like the antenna behind the plastic plate may be warped and touching the cavity. From my experience when they start shooting sparks it is time for a new microwave.
Apr 23, 2015 | Sharp R-820BK Microwave Convection Oven,...
Stopped working without power. Unplugging/re-plugging did not work. No display, no buttons responding. Is there re-set option?
there is a fuse inside,take it to someone that knows how to repair,if you use the wrong fuse,you could cause a fire or health problems
Mar 14, 2015 | Sharp R-820BK Microwave Convection Oven,...
Manual for R-888B Double Grill Convection Microwave Oven
Did you check the Sharp web site? They usually have manuals that you can download.
Feb 05, 2014 | Sharp Microwave Ovens
Sharp jet convection double grill
Looking at other answers below your question on the page that i am viewing anyways. It appears that Sharp convection microwaves or Sharp microwaves in general seem to have an ongoing problem of that sort. The solution is to replace the main circuit board.
Nov 09, 2013 | Microwave Ovens
Sharp carousel microwave convection oven keeps blowing fuse
The service manual is here:
http://www.microwavedisplay.com/r820bc_bk_bw_sm.pdf
You can get Sharp parts from Encompass here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
See http://www.microtechfactoryservice.com/cap_test.html
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
See: http://www.microtechfactoryservice.com/xformer.html
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
See this: http://031d26d.namesecurehost.com/mwd/doorsw.txt
Aug 01, 2013 | Sharp R-820BK Microwave Convection Oven,...
I need instructions on how to use Sharp Convection microwave Grill 2?
Best way short of Sharp is Google the model number of the unit with "manual" to try to locate free one online.
Nov 04, 2012 | Sharp R-930AK Convection/Microwave Oven
I have asked the question why do you keep asking the same questions and don't answer the question I'm asking
there is a ceramic safety fuse inside the unit,to access the control panel or to remove it you need to open the case up and remove the outer cover,careful the h.v. capacitor can hold a charge up to 2000 volts if not discharged
Oct 25, 2012 | Sharp R-820BK Microwave Convection Oven,...
I need a users manuel for a Sharp carousel sensor microwave/convection oven combo Model #1874 serial # 128925 year 2005
You can find the installation manual and owner's manual online here.
Oct 12, 2011 | Sharp R-1874 Convection/Microwave Oven
Sharp carousel convection/grill/microwave maybe R990
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
Check also the turntable . It could be out of it's right place .
WARNING :
1:Don't slam your microwave door because this may cause the fuse to blow and this is the reason of bad door switch problem .
2: A microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Jun 03, 2010 | Panasonic NN-S254BF Microwave Oven
Sharp Carousel Convection Oven. Model R-9H54.touch pad
It depends on what you mean by "a problem with the touch pad assembly".
If some or all keys do not respond, you would probably need a new keypad, but the key units for all Sharp R-9H-series models have been unavailable for a few years now.
These units did indeed last a long time.
Sorry I can't bring better news.
Dec 06, 2007 | Sharp R-370E 1000 Watts Microwave Oven
Sharp R-820bk 900-watt 0.9 Cubic Foot Convection Microwave, Black Logo
202 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
