Advent m312 wireless mouse driver installed but wont work..
The laser is flickery, i downloaded the drivers but still wont work... is it the batterys they supply? and also the laser goes off and on, ive tryed connecting
  • 1 more comment
  • happy Aug 27, 2013
    http://forums.logitech.com/t5/Mice-Hardw... WORKS!!!!!! on xp and vista
    just read the thing follow the steps un install the driver and plug out receiver turn off the mouse then put in receiver preess the connect button 5 seconds and it wil work withen 5-10 secs after releasing
    atleast mine did
5 Suggested Answers
SOURCE: Microsoft wireless notebook optical mouse 1023 - not working!
If you know that the battery is good then try this next. There is a VERY tiny shark-fin shaped spring-loaded button on the bottom of the mouse that is pressed in, when you insert the receiver, while the mouse is not in use, that turns off the mouse to save the batteries. If you haven't used the mouse in a while, it can get stuck in the in position, so that when you pull out the receiver, it doesn't spring out and turn the mouse on (indicated by the red light on the bottom). If you notice that the light isn't coming on. Just try manually pushing in the little shark-fin thing a couple times to make it spring back out. After a couple times, you should be able to get it unstuck and the red light should come on.
Posted on Apr 04, 2009
EWSteelman
  • 15 Answers
SOURCE: the wireless mouse works but the laser 5000
press connect on the wireless device...let go and then within 5 seconds press the button on the bottom of the keyboard. Repeat the same steps for the mouse whther its working or not. The problem usually is that the keyboard and mouse are on the same "Wireless Channel" and only resyncing them puts them on a seperate channel, hope this helps.
Erick
Posted on Dec 20, 2009
jazzyboy11
  • 728 Answers
SOURCE: advent wireless mouse doesn't work
Make sure you have the correct software installed for it or else it will not work. The computer will not recognize it until the correct software is installed.
Posted on Nov 10, 2008
Techjoel
  • 79 Answers
SOURCE: Sylvania wireless mouse not working
Press the button on the reciever, then press the small recessed button on the bottom of the mouse (may need to use point of a pen).
Good luck,
Techjoel
Posted on May 25, 2009
Advent wireless mouse
Drivers are available at advents web site.
May 25, 2014 | Advent Computers & Internet
Advent wireless mouse AMWL13 works for 30 seconds then freezes
Sorry to hear you're having that problem, Karen. I was unable to find the model # that you posted, but I DID find something for an M312 wireless mouse made by Advent:
http://www.adventcomputers.co.uk/forums/advent-printers-and-peripherals/advent-m312-wireless-optical-mouse-freezes-problem
If you look at the response to this issue, it lists everything I would've typed in here to suggest trying. Wireless peripherals are a "strange animal", in that so many different factors can influence their optimal operating condition. Hopefully something in this article can help you, and good luck! :)
Nov 07, 2013 | Computers & Internet
Advent mouse not working
You need to install a software driver to make it work, normally Microsoft will recongnise a USB or serial mouse and install the driver for you.
If no,t take it back to whoever you bought the mouse from and ask them to install a driver, or to send you one.
Oct 26, 2013 | Computers & Internet
Hi i am using a PA3745U-1ETB wireless laser mouse with my toshiba qosmio f60. my mouse is no longer working but the keys(click) and scroll button work.when i reconnect the batteries the cursor will move a...
1) Try to download and install a free driver updater software, e.g. http://www.innovative-sol.com/drivermax/index.htm - let it scan and update all your missing drivers - it may fix USB general problems if this causes also the mouse problems.
2) If it doesn't help - then there might be problem with the laser beam of your mouse (check the laser beam while the mouse is still moving, and then compare it with the beam when the mouse has stopped moving, maybe the laser beam is out). In this situation - bring it to the warranty repair service or ask for replacement from your seller.
Mar 07, 2011 | Toshiba Computers & Internet
Wireless Keyboard and Optical Mouse wont work.
Make sure the AA batteries in your mouse and keyboard are new and that you have downloaded and installed the correct drivers from the Microsoft website
Feb 10, 2011 | Dell Wireless Keyboard Optical Mouse w0147
Microsoft wireless notebook laser mouse 6000 not working
I have a miscrosoft wireless laser mouse 6000, and it also stopped working on my laptop. I changed the battery, still no workie. I tested the battery in another device, and it was good. I moved the mouse to another computer, and it did not work. The light on the usb connector was lit. [No changes at all to my laptop.]. It seemed like there was no power to the mouse, and I looked at the contacts inside the mouse. The contact just inside the mouse's opening for the battery appeared to be bent down (away from the contact on the battery tray). So, I pulled it up a little so it would connect when the battery drawer closed, and (after tweaking it a couple of times), it finally worked!
Jun 26, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
No light on mouse (ie the laser underneath)
Maybe your laser is very tiny, like mine.
Mar 29, 2009 | Computers & Internet
Advent wireless mouse wont work
ya u need the battery...................
if it dosent work even then ...........
and u r using window's then check wheter your configuration is enabeled........
if it is not enabeled enable it .and now it would work
Feb 01, 2009 | Computers & Internet
Microsoft Wireless Notebook Optical Mouse 3000 not working
Most devices last a long time. Have you tried re-installing the software for the keyboard & Mouse> Also go to microsoft download center and get the latest drivers for you setup. Make sure when you do, choose the right Operating System driver for your Keyboard & Mouse. Hope this helps. Bud
Dec 30, 2008 | Microsoft Wireless Optical Mouse
Computers & Internet Logo
1,694 people viewed this question
David Payne
David Payne
