Question about Philips 14PV225 14 in. TV/VCR Combo
HAVE CONNECTED TO SAORVIEW BOX BUT CANT GET INSTALLATION SCREEN UP ON TV
Switching from HDMI2 watching computer back to HDMI1 to TV channels I have no picture coming on the TV. Why ?
Look if there is a FIRMWARE update for your model of TV and the SAORVIEW.
Many a times, the TV lock in with the frequency and will not release until the proper reset command arrives.
Try switching to a different resolution on the computer before you switch HDMI port
Aug 16, 2016 | Televison & Video
Technika 32" led 32-2481. Keeps loosing the saorview tuning. Have to auto scan every time move from hdmi back to saorview. What's the problem.
Main system control memory IC is faulty. Replace it. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 31, 2014 | Televison & Video
Does my tv have a saorview tuner
Only you would know that when trying to access values that you are seeking when using the device.
May 10, 2014 | Televison & Video
Could tv star t1020 box cause reduced vertical picture
The box may be causing this, many now have adjustments in their menu for centering and height and even width of the image.
It of course can be a problem in the set but that would show even with the box removed.
Dec 12, 2012 | Sharp 19G-M60 TV
I cant make the freeview box work without the operating instructions
OK - please follow these instructions carefully to setup the Freeview box. If you get stuck at any point in the instructions - or anything I've said doesn't make sense or match what you can see - just post another message here and I'll deal with each problem as it arises.
1. Switch the TV and Freeview box to STANDBY. There should be a red light on the Freeview box;
2. Connect the aerial cable to the freeview box. Make sure you are connecting this to the correct socket. This should be labelled "RF IN", "IN" or "Aerial/Antenna". If you have connected to a socket marked "RF/TV OUT" or "TO TV" or something similar, it wont work;
3. Connect the SCART cable to Freeview box and the back of the TV;
4. Switch the TV on;
5. Switch the Freeview box on - you should get a green light on the front of the box;
Most TVs will automatically switch to the external input when a SCART device is switched on while the TV is already on. This is why you should switch the TV on first.
At this point you should be able to see the installation / setup screen for the Freeview box displayed on your TV. If you cannot see this:
A. Press the INPUT button once on your SAMSUNG remote control once. This is the button in the top-right corner of your remote control.
B. If you still cannot see the installation / setup screen, press the MENU or SETUP button on the remote control supplied with the Freeview box.
The instructions from this point forward will be different if you had to press the MENU / SETUP button on the Freeview remote before anything appeared on the TV screen. If this Freeview box has been used before the installation screen will not appear, but you will get at on-screen menu after pressing the MENU / SETUP button. If this happens, please let me know and I will provide alternative instructions for setup.
Assuming you have been able to access the installation screen, it should be easy enough to follow the instructions on screen from this point. Use the UP / DOWN / LEFT / RIGHT arrow keys on the Freeview remote to highlight the relevant options and then press OK / SELECT to choose that option.
I don't want to make this too complicated by providing alternative instructions for every possible scenario. Please run through the instructions above and make sure you are getting an installation screen or "menu/list" displayed on the TV. If you need further instructions from there, I will provide them in another message.
Good luck - I'll await your reply.
Regards,
BElectric
Feb 09, 2011 | Televison & Video
Although the Freeview box is correctly installed with my TV,when the men button is pressed the only message to appear on the TV screen is No Signal,HELP!!
Ok, if you have "No Signal" that can only mean you must be selecting the wrong INPUT, when it is hooked up yo the TV, essentially the TV, is just a Display Monitor, and it doesn't use "Channels" anymore, it uses the AV, or EXTERNAL Inputs, any channel changing is done on the Freeview box. Make sure you are connected color to color, cables are connected. The antenna, goes into the freeview, the AV cables go to TV, taking the Video 7 Audio, from the Freeview box, to the "Screen" TV, set to the External input, that the "Box" has been connected too. Check your manual out.
May 08, 2010 | Televison & Video
Lost the Welcome/Installation Menu
http://www.ezdigitaltv.com/support-files/ns_dxa1_manual.pdf
All you have to do is use the auto tuning function. Your remote control has a menu button, you can get to the feature via the on-screen menu.
If you press the menu button while the box is on and you see no menu, change your television's input to match what the box's output is.
Nov 23, 2008 | Insignia Digital-to-Analog Converter for...
Philips 14PV225 14 in. TV/VCR Combo Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
