TXC15A shredder stuck on shread
For the money that was spent on this I fully expected it to function properly. I have to turn this "Off" every time I am done shredding anything, because it will keep running. I can not see anything jammed in either slot, i tried running it in reverse, in case the jam was deeper, did not work. If we just let it run, it will go until it overheats. any ideas?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 26 Answers
It may be that there is a broken connection under the plastic switch cover that activates the proper electrical switch.
Posted on Oct 29, 2012
SOURCE: My shredder keeps running and won't stop in on/auto mode
Does the shredder have the electronic eye to sense paper? Sometimes dust will collect on the sensor causing it to keep running.
Posted on Apr 16, 2007
  • 883 Answers
SOURCE: Shredder motor seems jammed
must disassemble feeder unit and visual check for jam. The debris may be a part of the shredder that has broken off.
Posted on Jun 21, 2007
SOURCE: My shredder stop shredding. has paper caught in it
Shredder drive gear is probably shredded - hard part to find or replace usually. Could mean a new shredder;-(
Posted on Sep 08, 2007
  • 4 Answers
SOURCE: Shredder won't shred any more.
I have the Infoguard SX100M Axeus, sold by Staples.
Only the reverse was working, UNPLUG and open back cover, the paper mechanical switch was working fine, red side switch, the gears and fuse were all ok, I think something on the circuit board was fried.
I switched the BLACK and WHITE wires with each other going to the shredder motor, thus when I switched it to reverse, it would go foward and shred. Its working now, only in reverse.
Posted on Mar 28, 2009
venexcsd
  • 1185 Answers
SOURCE: the shredder will run in reverse but will not run foreward.
Inside the shredder there is a motor which is wired to run both forward and backward, the way it does this is to transfer the power from the switch to a couple of wires on the motor
The forward running motor will be linked to the auto start button which will tell it to work with the paper sensor.
When you select the Forward function the Auto Start is taken out of circuit and the Forward switch should supply the motor
After all of that I would say that the switch is open circuit on the Forward contact and needs replacing
Posted on Jun 12, 2009
Shredder keeps running on auto
Unplug it and check to see if theree is any paper caught in the Start switch. Turn it Off, plug it back in and start in the Reverse mode. Then turn it Off and set the swich for On - shread.
If that doesn't work unplug it and find the start switch trip wire, Toggle it a few times with something thin - don't push too hard. You can also spray the switch the canned air used to clean keyboards. Plug it back n, start it in reverse then move it to shread.
Jun 19, 2014 | Omnitech 18-Sheet Cross-Cut Shredder
Model SPL-TXC15A. Why doesn't it operate?
The shredder may have gone into thermal overload as a result of trying to shred something unsuitable, such as a credit card or as a result of prolonged use. Sometimes operation resumes after a "cooling off" period. At others, the thermal overload shutdown is permanent.
Jan 17, 2013 | Office Equipment & Supplies
Cleaning ladies were here yesterday. Evidently they did something because today when I turned it on both the red and green lights are lit and the expected humming sound is absent.
Check for the trigger wire. On Fellowes it is usually a thin wire in the middle of the unit that triggers the shredding mechanism. Also check to be sure the shredded recepticle is pushed in fully.
Sep 01, 2010 | Fellowes Office Equipment & Supplies
Reverse shred does not work
either the switch is unplugged or defective, or the main board needs replacing. Also, they come with a 2 year warranty. try calling 1-800-955-0959 for fellows end-user support and have serial # ready (ser.# is found when you open the door).
Oct 29, 2009 | Fellowes C-420C Shredder
The Basket full light will not go out. I have cleaned the paper pathy and the light goes on after about 10 shreaded papers
Did you clean up underneith the cutter asm. Unplug the un it and remove the basket then turn it upside down and clean the shreds out then clean the led sensors with a dry cloth.
Aug 29, 2009 | Fellowes DM15C Shredder
Shredder wont shred.
the cutter wheels are probably filled with paper shreads, you need to unplug the shreader and clean the blade by hand
Jul 27, 2009 | Fellowes 3011001 Shredder
46 people viewed this question
jasbo
jasbo
