Question about Horizon Fitness EX-59 Elliptical Trainer
How to disconnect beep at startup - Horizon Fitness EX-59 Elliptical Trainer
I turn laptop on an screen is black... fan comes on power button lights up but no display
Do you get any beeps when the laptop starts up? There is a POST (Power on Self Test) routine that attempts to diagnose startup problems and send beep codes (pattern of short/long beeps) before the main programs start up. If you get any beep codes, you can search for your computer model with 'POST codes' added if you have access to another computer. That might tell you what was wrong. Also try disconnecting from AC and removing the main battery for 15-30 minutes and then put both back on and see if you can get any different response from the laptop. Watch for any other activity such as the hard disk light or WiFi LED lighting also. If you don't get any response other than no startup, a tech would have to diagnose the problem from the motherboard.
Jul 24, 2014 | Computers & Internet
Why does my notebook samsung np-nc10 beep on startup?
some laptops and desk tops beep on start up.but some beep when it has ram problems.
May 06, 2014 | Samsung NP-NC10-WAS1US Notebook
Compaq presario C700 continous beep when starting up
Potential Hard Drive failure, (Hard drive s.m.a.r.t. beep) or if MB beep it's chassis intrusion..
1. Remove battery + disconnect power
2. Hold down power button for 20 seconds
3. connect power only (no battery)
4. Turn computer on.
If the beeps stopped.. get a new battery, if the beeps continue..
ABANDON SHIP!
Apr 27, 2014 | Compaq Presario 1200,1600, Series CD...
6 long beeps
Make sure the keyboard is connected the proper port on the back of the computer.
Turn off the computer and disconnect the keyboard and verify there are no bent burnt or broken pins on the keyboard connector or on the keyboard connector on the back of the computer
Try a different keyboard on the computer.
Unfortunately if all of the above recommendations do not resolve your issue, the motherboard may have a bad controller and will need to be replaced
Aug 14, 2013 | Dell OptiPlex Computers & Internet
Dell Dimension 9200 beeps on startup, with nothing...
A beep code of 3-3-4= Video Memory(RAM) Test Failure that would explain why you get nothing on your screen the first thing you would need to do is disconnect your monitor and try it on another computer. if it works fine then the problem is your video card. If that the case and the video card is intergrated with the motherboard, you will need to repalce the motherboard --- Sorry-- Please vote me a 10 when this works
May 20, 2010 | Dell Dimension 9200 PC Desktop
Screen went blank, have yellow indicator on monitor, try to reboot, getting three beeps, nothing more.
One beep during startup is "good", but THREE is not good.
Three beeps means a hardware fault -- probably that the video-adapter on your computer has failed.
Connect the monitor to another desktop/laptop, to confirm that it still works.
Turn the computer off, and disconnect the power-cord.
Remove all the RAM, and then re-insert just one stick.
Reconnect the power, and try to boot.
If you still get THREE beeps, turn it off.
Disconnect the power-cord, and reinsert the remaining RAM sticks.
If you still have the problem, then it's time to replace the video-card on your computer. Take the computer to a computer-store, so that they can sell you a video-card that will be compatible with your motherboard.
Hopefully, if you buy the video-card from them, they will install it for a modest fee -- ask them.
Dec 31, 2009 | Intel D945GTP Motherboard
My bios speaker will beep on startup but nothing more. What avenue should I approach to get past this part of startup?
First you need to know which BIOS you have and how many beeps it is producing... these beeps are the POST - Power On Self Test. They tell us if there are problems such as missing keyboard, video card not working, memory faults etc...
Then you need to go to the appropriate BIOS site and see what the number of beeps mean.
If it is a single beep - it means all is well...
As you are not getting anything more you should check to see if the Hard Drive (HD) light flashes - if so - the HD is probably operating ok and loading your system but there is either a problem with your monitor or video card... borrow another monitor and see if that helps...
But it all depends on the number of beeps you get and what kind - long and short beeps (like morse code).
If this helped you at all please vote!
Oct 06, 2009 | Asrock M266A Motherboard
On startup it beeps and wont startup. i hit F12 and it works fine now. thats all i did. so what could be the problem? i've already replaced a power supply about a year ago. and also my dvd player is kinda...
On startup beep how many beep do you hear?
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Hope it Help you out ^_^
Jun 29, 2009 | Dell XPS 200 PC Desktop
One beep at startup - System does not bootup
You have what sounds like a RAM problem. Try known good RAM as a test. If it still fails, remove add on cards except video. Make sure that video card works. If it still fails to boot. Replace motherboard.
Jun 01, 2009 | E-Machines eMachines Desktop PC
I have an Intel D945GCZ mainboard At startup I
This is a diagnostic beep code which is designed to tell you something is amiss with your system. The code patterns of short and long beeps are not fully standardized, so it depends on who manufactured the BIOS for your motherboard. Generally three long beeps indicates an issue with the base memory - the first 64K. Try putting your RAM sticks in one at a time and powering up the system. Make certain they are oriented correctly (note the notch) and firmly seated in the socket.
Mar 04, 2009 | Intel D945GCZLR LGA775 1066MHz FSB DDR2...
Horizon Fitness EX-59 Elliptical Trainer Logo
26 people viewed this question
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
