Question about Compaq Armada E500 Notebook
E500 won't shut down
My armada e500 will not shut down, I have to disconnect the power supply and take the battery out to shut it off how do i fix this? also when I turn it on then all I get is a black screen...what's up with that?
  • brianfoote00 Mar 11, 2009
    Compaq Armada E500 PC Notebook problems with start up and shut down
My computer did not shutdown and I tried everything in the book. I later found out this was due to a battery in the computer which remembers your settings, always remembering to restart your computer. Here is the fix. Turn off the power to the computer and unplug it from it's power source. Next, unplug all the cords from the back of the computer. Now look towards the back of the computer on the side, you'll see a large screw. Unscrew this screw and slide the panel to open the computer (make sure the power is off). Once the side panel is off, turn the computer on it's side and look for a large round (watch type) battery. Fiddle with the battery and pull it out. Keep the battery out for about five minutes and then put it back in. Next put the side panel of the computer back in and screw it back on. Next, reconnect only the monitor, keyboard, mouse and power to the computer. Turn the computer back on. Once on the desktop, shutdown the computer and the computer should remian off. Goodluck!
Posted on Jan 15, 2009
  • Compaq Master
  • 787 Answers
It is probably not shutting down because there is a program running that will not shut down. Unnstall programs you no longer use and do a virus scan, often the programs that refuse to shut down are malicious. Holding down the power button for 5 seconds should shut down the computer (it signals the motherboard to power down). As for the black screen, not enough detail for me to say.
Posted on Jan 02, 2009
My armada e500 processor is built-in and processor not working
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jun 13, 2012 | Compaq Armada E500 Notebook
Armada e500 battery light blinks amber as soon as I remove the ac cord it shuts off
You need a new battery. batteries do not last forever and need to be replaced. Search ebay and you can find a replacement.
Mar 21, 2011 | Compaq Armada E500 Notebook
Computer worked fine last time i used it about 2 months ago, now it will not power up, any suggestions? compaq armada e500
Sounds like the you might need to replace the battery. Also check the power supply reconnect make sure connection are tight etc... its a long shot but make sure wall outlet is also active as well! Sometime it takes 20- 30 mins for an old battery to begin to recharge:)
Jul 25, 2010 | Compaq Armada E500 Notebook
Armada E500 notebook Power button not responding.
Unless you took the batteries to a service center, I am dubious about your ability to confirm the main battery is holding a charge. The average lifespan of these kinds of batteries range between 3-5 years and is likely at the end of its lifespan. This would explain the diminishing performance over the last year if there were significant power or power circuit issues, they would likely be observed on AC power as well. This model of laptop requires the battery calibration utility be run in order for the laptop use the battery. In fact, the battery can show a full charge and still not function if the utility and battery have not been properly configured.. . . instructions on HOW TO do this below. If this doesn't FixYa then the battery will need to be replaced (links to replacement sources) www.BatteriesOvernight.com/HP-Batteries,----- OR --- www.new-laptop-battery.com/Compaq/?Compaq-Armada-E500-battery.htm. You will still have to run the configuration utility when you receive your new battery.
Link to Armada e500 manuals:http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01124216/c01124216.pdf
How to run config utility: Standby and hibernation must be disabled for the battery to discharge completely and shut off. To use the Battery Calibration utility, first identify whether the battery requires calibration by launching the Power Management applet as described above. On the Battery Calibration tab, all installed batteries will be displayed in the primary list box. Next to each battery name will be an indication of whether calibration is required for that battery. If calibration is necessary, the phrase “Needs Calibration” will be displayed. Select the battery to be calibrated, and click the Start Calibration button. During calibration, the utility will display an icon on the Windows System Tray to indicate that calibration is in progress. Each phase of calibration (charging or discharging) will also be displayed. Calibration is complete when the icon is no longer displayed in the System Tray. Battery calibration requires several hours for completion. If you choose to continue using the computer during the calibration process, it must be connected to AC power. The calibration process must be allowed to finish without interruption. Performing any of the following actions will prematurely terminate calibration:  Clicking the Stop Calibrating button in the Compaq Power tab.  Unplugging AC power from the computer.  Unplugging the calibrating battery. (This action may result in data loss if a second battery is not installed.)  Undocking the computer.  Pressing the power or standby button.  Powering down or suspending the machine by using the Windows menu. IMPORTANT: If the calibration process is interrupted, it cannot be resumed. You must restart the computer and start the process again.
CALIBRATING WITHOUT THE UTILITY To calibrate a battery on computers without the battery calibration utility, complete the following steps: 1. Remove the second battery, if present, so that only the battery needing calibration remains in the computer. 2. Dock the computer or connect the computer to AC power. 3. Turn on the computer. 4. Check the current battery capacity level by positioning the cursor over the battery icon in the system tray. 5. Allow the battery to charge to 100%. You may use the computer, but the recharging process will require more time. 6. Set the system to “drain” mode on the battery conservation settings by pressing Fn+F7, or select Start > Settings > Control Panel > Power (or Compaq Power in Windows NT). 7. Undock the computer or disconnect the computer from AC power. 8. Restart the computer in MS-DOS mode by clicking Start > Shut Down > Restart the Computer in MS-DOS Mode > OK. 9. Allow the computer to discharge until it shuts off. 10. Dock the computer or reconnect AC power. 11. Allow the computer to charge again to 100% as in Step 5.
Feb 19, 2010 | Compaq Armada E500 Notebook
How to charge battery in compaq armada e500
You need to connect the power adapter and charge it for some time and check.
May 09, 2009 | Compaq Armada E500 Notebook
It wont stay on
Hi Kimberley,
Looking at your brief description of the problem a possible fault may lie with power supply and or battery.
Have you access to another Armada power supply? if not does the light go green when Pc is turned off and fully charged.
I would be looking in these area's for the problem.
Good Luck,
Paul 'W'
Onyer~EDson(:0) {#><U.K.
Jan 15, 2009 | Compaq Armada E500 Notebook
My lap top shuts it's self on am off
Try removing the battery and starting up only on AC power. You may have a faulty battery. It could also be the power supply or a bad memory chip. If it's none of these, then it's a motherboard problem.
Jun 20, 2008 | Compaq Armada E500 Notebook
How do i unlock my compaq armada e500?
I JUST LET IT SET AND IT FINALLY SHUT DOWN ON ITS OWN AND WILL NOW POWER UP.
Mar 14, 2008 | Compaq Armada E500 Notebook
Compaq Armada e500 refuses to start!
An immediate boot fail normally either indicates a flat cmos battery or a faulty processor. My advice is to take to a qualified repair shop, as notebook are not as easy to work with as desktops and finding the cmos battery alone can be a headache.
Nov 18, 2006 | Compaq Armada E500 Notebook
Compaq Armada E500 Notebook Logo
192 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
