No signal is coming
Just give spite reset to my device because it is working slowly and after that No signal is coming and i also upgrade the new software in it .But the problem is remain same.Plz give the solution
  • 580 Answers
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Posted on Oct 26, 2012
I just purchased this treadmill. The internet was working on it. I needed to upgrade the firmware; but it wasn't allowing me to do so. I then moved the positioning of the treadmill. I still have a...
Please in the section open connections network give to repair, and the system will repair.
If the problem persist reboot the Modem-wireless router again, and see if the signal is coming more Strong.
Reset the Modem in the small hole, with some pencil introduce the pen and reset it
Retigh the wires coming from your Modem Wireless router. And finally Test again if is working. sincerely.
Sep 22, 2011 | Nordic Track NordicTrack Elite 9500 PRO...
Tip
How to fix a hanged/frozen/non responsive Pan Digital Novel E-Reader
If your Pan Digital Novel Reader... does not respond or hangs, it means the unit/device has frozen. This is a software/OS (operating system) problem.
Usually, resetting should do the fix. To reset, push the hole at the back of the unit with paperclip and the unit will reset. But if you have reset the unit by pushing the small hole at the back with paperclip (which means reset) and that seems not to solve the problem, then it means the operating system of the unit is corrupt. This is a software problem and to fix this problem, you need to install the firmware for your unit.
Firmware helps to remove the corrupt software and re-install a new one. Your unit will be as new once this is done.
Upgrade via PC
This option is for Windows PC only at this time.
With this method, you must connect your pandigital novel to a PC and then run a downloader program which automatically downloads the firmware to your device.
1. On your computer, go to www.pandigital.net/downloads.
2. Choose the "Upgrade with Your PC" option.
3. When asked to Save or Run, select Run.
4. Follow the prompts in the Upgrader window to download the firmware into your device.
5. After the download is complete, turn your device off.
6. Press the Volume + key plus slide the power key on simultaneously for 5 seconds, and then release both.
7. Your device is upgraded and restarts automatically.
8. In the Language setup screen, tap Save with English selected (other languages will be available in future firmware upgrades).
9. In the Date/Time screen, if necessary, tap in the Time Zone, Date, and Time fields to set the correct time for your location. IMPORTANT: In order to connect with your Barnes & Noble online account, the Date and Time must be set correctly according to your location.
10. Tap Save.
11. The HOME screen is displayed.
Re-Upgrade
If you have previously performed a firmware upgrade to your device using one of the above methods, we recommend that you move the existing upgrade file into a different folder before performing another upgrade, which allows you to revert back to the existing version if desired.
1. Connect the device to your computer.
2. In a Windows Explorer or Finder window, create a new folder titled Firmware, and then copy the existing upgrade file into the Firmware folder. (The upgrade file is named similar to SYY_MM_DDK_PD_INX7E_ENG_6410POP.)
3. Perform the new upgrade using one of the methods above.
Revert back to Previous Version
2. In a Windows Explorer or Finder window, delete the upgrade file from the root, and then copy the upgrade file from the Firmware folder back into the root of the device.
3. Turn your device off.
4. Press the Volume + key plus slide the power key on simultaneously for 5 seconds, and then release both.
5. Your device is upgraded again and restarts automatically.
6. Follow the prompts to re-set your language and date and time.
I hope you found the above helpful.
Regards.
on Sep 27, 2011 | Tablets & eReaders
Tip
Garmin GPS - stuck , not updating, no signal problems, update maps
If your Garmin GPS is stuck on a loading screen, not updating properly, not acquiring a signal or having other quirky problems. You can follow the steps below to help resolve some of these issues.
In order to update the firmware on your Garmin GPS device you will need a USB cable and Garmin's WebUpdater software. You can find the update software from the following link below,
Click here for update software
Click here for map updates
To update your firmware through the WebUpdater software, you want to turn off your GPS device, plug it into your computer. Run the WebUpdater software then turn on your device. If the software does not list your GPS then click the "Find Device" button.
Updating the maps can resolve issues with missing streets, or the unit being off entirely(roads are updated throughout the world on a constant basis). Keeping your software up to date is always recommended.
Firmware upgrades will help resolve issues in the operating software, and may even help GPS problems you are experiencing. If not, you can perform a soft reset. As a last resort, you will want to perform a hard reset below.
Perform a hard/soft reset
A hard reset will reset the device back to factory defaults. This will also delete any of your personal favorites saved on the device.
Garmin Nuvi
Soft Reset
Slide the power button to the left and hold in this position for 8 seconds. Push the switch to the right to power the GPS back on.
Hard Reset
Turn the unit off. Press and hold the bottom right of the GPS screen. Continue to hold while powering on the GPS. you should now have a prompt asking you to erase all data. Select Yes. Afterwards, it is recommended that you leave the GPS outside somewhere safe to acquire a GPS signal. Once this is done, you can update the GPS using the update steps described at the beginning of this article.
-G33k
Be sure to check out some of my other Tips and Tricks articles by clicking here. I have articles on internet issues, computer problems, connecting video game consoles to a network, router issues and more!!
Keywords
Garmin GPS stuck, Garmin software update stalled, Garmin reset, Garmin hard reset, Garmin soft reset, Garmin updates, Garmin firmware, Garmin stuck on loading screen, Garmin no signal, Garmin not updating
on May 15, 2011 | GPS
The LED vizio comes on the front of the tv...........screen is blue with floating signal saying No Signal!.
Tries unplug the tv and the cable or satalite boxes too.Replug it all back like an hour later.The tv know will reset itself back to the factory setting.The cables or satalites boxes it upgrading it softwares.The tv should have incomming broadcasting signal and work now.Not,call the cables or satalites compannies to replaced those inputs boxes first,have the same problems with those new input cables or satalites boxes.Than the tv,the Tuner signal board have problems and the cause.That the board,where the incomming broadcasting signal cable plug into it.That the tv Tuner signal board.Tries websites Shopjimmy.com,Ebay.com to buy a whloe refurbish Tuner signal board for the replacement.
Nov 07, 2010 | Vizio VX32LHDTV10A 32 in. LCD HDTV
Garmin 250w keeps resetting itself, GARMIN logo comes on and then as to press dot, then reset and GARMIN logo comes on again. Try soft reset, still reset itself. Unable to upgrade firmware because...
Probably needs a new logic board at this point. If they don't give you a new one under warranty, are third party Garmin repair services that will fix it for cheap. Also, I found an DYI GPS repair guide,so you can do it yourself too, not that difficult.
May 10, 2010 | Garmin nuvi 250W GPS Receiver
My philips 42pf5321d/37 will not come on. Upgrade firmware fix was temporary and the red light no longer comes on, but now even unplugging and reseting no longer works. It now gives me sound for a second...
try the software upgrade again but make sure it is the correct one because if it is not then you can cause the small signal board to go bad, if that is the case you will need to replace the small signal board
Jul 06, 2009 | Televison & Video
I have the sbg900. It suddenly quit working. I get the green power light and orange wireless light. The recieve light blinks slowly. The send, online, and activity lights do not light at all. The wireless...
Best to call up the cable company and go thru the phone prompts...you may just find that they're having trouble in your area...
They can also send a reset signal to your modem too.
Give em a call..
Jun 07, 2009 | Arris SURFboard SBG900 (49402201900) Modem
Garmin Etrex Legend Cx - no signal
Have you tried upgrading the unit's software. Go to Garmin.com and download the latest software for your unit. This will sometimes fix satellite reception problems.
Sep 28, 2008 | Garmin eTrex Legend GPS Receiver
Text-to-speech not functioning (voice guidance stopped working)
I reset the device and updated the software from TomTom Home. Now it is working good.
Apr 02, 2008 | Tomtom GO 700 GPS Receiver
Device stays on GSM
You may need to upgrade software, but if you have a sim card pull your sim card and battery leave them out for a couple minutes, put phone back together and see if it resolves your issue, could be a glitch in the network.
Dec 07, 2007 | RIM BlackBerry 7290
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
