Question about Bosch 24 in. SRS43C12 Classixx Slim-Line Free-standing Dishwasher
Manual for Bosch SRS43C12 dishwasher - Bosch 24 in. SRS43C12 Classixx Slim-Line Free-standing Dishwasher
Bosch classixx dishwasher not heating water on cooler wash works on hot wash
Most dishwashers don't heat the water. They run on whatever temperature water you have it set for. They have heating coils on the bottom but that's for drying, not heating up the wash water.
Nov 30, 2014 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
There should be a plastic cover on the bottom, the removal of this gains access to most of the seviceable parts. beware of water spillage when you tip machine into its back!. Good Luck
Nov 21, 2011 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
The dishwasher doesn't complete the cycle and switches off without draining.
Try advancing the timer manually. It could be that your timer is sticking.
May 19, 2011 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Water not draining properly - leaving residue in bottom
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Aug 17, 2010 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
I have a bosch dishwasher that wont drain
Question! Did u buy this from Bosch? If you did not, then your contract is with the Store you bought it from and NOT Bosch and you should be contacting them and they should sort the problem.
A blockage, can sometimes be solved by putting one of those diswasher cleaning tabs in the machine a couple of times and see if that sorts the problem for you.
I suggest do that first it is the cheapest option and then if that does not work ring who you bought it from whether that be a retailer or Bosch themselves.
Jun 18, 2009 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Hi can't find the instructin manual for my
I usually find some manuals on here after entering the model. You sure that is the right model? Look on the inside by the door. Good luck
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
Mar 14, 2009 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch SRS4302GB Replacement Inlet hose - which type?
it should have and is delivered with the narrow bore high pressure hose
if your water flow rate is high more than 20 ltrs p min you could get away with a standard low preessure hose
you can download the instruction manual from the bosch web site or from the bsh home appliances web site
good luck
Mar 06, 2009 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
I have a bosch dishwasher classixx its less than a year old, the 'check water' light comes on and it doesn't complete the cycle. Water is left in the bottom unable to drain away. I have checked pipes as...
if its less than a year old why dont you contact the manufacturers service team it will still be under guarantee as the bosch guarantee is 24 months
you can dowload a copy of the instruction maual free of charge from the bosch or bsh home appliances web site
Feb 21, 2009 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch Classixx Electronic not working
could be faulty door switch check that either board may be at fault but before this hapens is there power at board if not you may have had a flood internally tripping flood switch
Dec 26, 2007 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch 24 in. SRS43C12 Classixx Slim-Line Free-standing Dishwasher Logo
114 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
