Question about Zyxel Prestige 660HW Wireless Router (PRESTIGE660HW)
How do i enable DHCP on my router
I'm trying to connect my xbox to my wifi using my macbook, but it keeps telling me it cant use a static ip or obtain one from the router, so i want to enable DHCP on my router but i cant
  • 25 Answers
The problem most likely is not the router problem since the router use DHCP as default setting.
Posted on May 01, 2014
I keep trying to hook to my wifi and it wants to change my IP address continuously. I had to change the settings to "static" and type in my IP address. Unit connects initially and then reverts to an
Keep the router to supply IP address using dhcp mode. Increase the lease time to 24 hours and don't forget to bind your device mac address with the dhcp IP in the router. This way it will always get the same ip from the router.
Dec 30, 2014 | Computers & Internet
No internet connection
Check if you can , by pass the wizard and set the connection manually. Let me find more details for you
Thanks
proton
Jul 24, 2008 | NetGear RangeMax WPN824 Router
I'm using TP-LINK TD-W8101G ADSL Modem Router to connect internet, I'm trying to connect it with Linksys WRT120N Router Wirelessly. I want to use WRT120N as access point to extend TP-LINK...
Unfortunately, you can't use two routers together in that manner. You must have a device in between them such as a switch or bridge or you'll have to disable the DHCP server settings in the second router. The second router then pretty much becomes a switch you may then use all the ports on the second router with the exception of the WAN port it must remain unoccupied. However, if you need wireless connectivity in another location far away from your main router then your only solution would be to indeed purchase an actual access point/bridge device
Sep 06, 2011 | Linksys WRT120N Router
Limited accessibility for wifi
For that you need to enable DHCP on router.or set static ip in wireless network adapter tcp ip property. You can enable DHCP with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on DHCP and enable it then save settings and restart router then check. Let me know if you need further assistance. Thanks for using FixYa.
Aug 28, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
How to connect my Linksys router with my wi tribe modem?? my laptop pick up the wireless signal and can connect,,it says "connected" but when you open a page it says either "invalid server...
The Linksys Wireless router is fine, but your latop is not configured for DHCP (Dynamic Host Configuration Protocol). The computer is connected to the router at layer 2, whereas HTTP (Hypertext Transfer Protocol), sits
atop the TCP/IP (Transmission Control Protocol/Internet Protocol) layer, and seems to be trying to
query the ISP's (Internet Service Provider) network for a nameserver (via DNS (Dynamic Name Service) protocol) that doesn't exist on the ISP's network. Configuring the laptop for DHCP and specifying no nameserver will fix this (the ISP's network will dynamically assign a DNS).
Its also possible (though a remote possibility) that your Linksys wifi router may be configured to disallow TCP/IP virtual circuits to/from your computer's IP address - but this is a really advanced
capability of your Linksys wifi router - few know this capability even exists.
Connecting multiple wifi devices to the Linksys router should be no problem, just configure them all to interact with the router using DHCP.
Jul 04, 2011 | Linksys WRH54G Wireless Router
Cant connect to xbox live. ive used my laptop b efore but now it will not let me can u help me? i think the settings are messed up when i test connection from xbox to network it doesnt go any further
First access your router then check its settings of ip address.
It must be in the range of your router settings.
Means if your router ip is 192.168.1.1 and subnet mask is 255.255.255.0
Then your xbox ip is 192.168.1.3
gateway is 192.168.1.1
It is good enable DHCP in your router so your xbox get autoip from router if you set suto ip getting from router.
For that For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Then Enable DHCP in router then save settings and restart router.
Jan 31, 2010 | Microsoft Wireless Network Adapter Xbox...
Cant obtain an ip address from router or modem and not sure how to check if dhcp is enabled or disabled configuration problems trying to connect to xbox live wit console and pc
Connect a desktop or laptop to the router.
Click Start
Click Run
Type CMD and press ENTER
Type IPCONFIG/ALL and press ENTER.
Does it show "DHCP enabled"?
Does it show an IP-address (probably starting with '192.168.') ???
If so, then DHCP is enabled on your computer,
and your router is handing-out IP-addresses.
Nov 01, 2009 | Microsoft Windows XP Home Edition
One static IP has internet. how on a LAN?
You need two network adopters in your system.
Connect Internet connection in first Network card and from the other network card give it to your Switch or hub
If you are using XP system you can use Internet connection sharing to share the internet in your LAN systems.
Follow the steps to enable using ICS
1.Enable Internet Connection sharing in the LAN properties in the first network card.
2.Now your second network card automatically get an IP address in the range of 192.168.*.* series
3.Connect other systems in the LAN and make sure the system has selected Optain IP atomatically from DHCP.
You are all set.
There is also an advanced way to setup this .
Install IPCOP firewall in a system with two network cards and u can share the internet with the firewall settings
Aug 28, 2009 | Computers & Internet
Home Network Problem with Netgear MR814 and Netgear FS105
Is your ReplayTV and Xbox configured to use DHCP? If not, you may need to configure static IP addresses for each of them.
Feb 17, 2009 | NetGear ProSafe FS105 5-Port Ethernet...
My NAT type is on moderate so I cant play Xbox Live
I tried everything and eventually figured this out.  Do this!
Enable DHCP set the start ip to 192.168.1.100, and remove any static IP address on your xbox 360 (have it automatically detect connections)
Set the MTU to 1364.
enable UPnP.
if you are using wrt-dd (if you aren't, you should be)  setup QoS so xboxlive has premium priority.
And you have hit the ground running.  Even microshats own website wont' help you fix this stupid problem.
I promiss this will work ;)
May 16, 2008 | Computers & Internet
Zyxel Prestige 660HW Wireless Router (PRESTIGE660HW) Logo
108 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
