Question about Camping, Backpacking & Hiking
What is a cartridge stove? - Camping, Backpacking & Hiking
    Problem Solver:
  • 21 Answers
A cartridge stove is a type of stove that uses pressurized cartridges in order to burn fuel. This type of stoves is very convenient for people who don't want to carry heavy equipment on their outdoor trips because it is small and light.
Posted on Oct 25, 2012
Where can I buy this ?
Army navy surplus store camping store or even superstore it's just camping gaz cartridge for stoves or lamps
Mar 31, 2013 | Camping, Backpacking & Hiking
Jenn Air halogen cooktop - front burner control turns on both burners
No,it's just a waste to have the two burners working at the same time in the first place!
May 04, 2017 | Jenn-Air Kitchen Ranges
I'm going on my first backpack trip and I'm not sure which type stove to use. What would you recommend?
While backpacking, I personally use a cartridge stove because it is really easy to carry around and also I there's barley anything I need to do in order to maintain it. You can read about the different kinds of cartridge (canister) stoves on this website: http://www.amazon.com/b?ie=UTF8&node=2615788011.
Oct 25, 2012 | Camping, Backpacking & Hiking
Do cartridge stoves perform well in all types of weather?
Cartridge stoves generally don't work very well in cold weather because the fuels it uses become less efficient. For example, butane won't work at all below 0 degrees.
What types of fuels are used in cartridge stoves?
Cartridge stoves use the following types of fuels: propane, butane, isobutene, and a blend of fuels like butane and propane together.
What are the advantages of cartridge stoves?
Cartridge stoves offer many advantages:
  • They are lightweight
  • They are small
  • They are very easy to use and to maintain
  • They are using cleaning burning fuel
I am looking for a plug in electric unit for a 1980 Jennaire counter top stove.
if your looking the cartridge that fits in and has burners the cartridge has its own model number which can be found on the underside of the cartridge
Aug 13, 2011 | Jenn-Air JES9860 Electric Kitchen Range
Replacing electrical outlet for stove top burner cartridge
You need to remove the cartridge then all of the screws that are around the inside perimiter of the well. You may also need to remove the control panel via the screws securing the top trim and the bottom flange. The part numbers for the wires with contacts are as foloow: 71002326 blue wire, 71002604 brown wire, 74005845 violet wire and w10116778 yellow wire. They should retail at @ 7.-8$ each.
Apr 07, 2009 | Kitchen Ranges
Need to fix regulator for coleman stove 5410708
Just where the regulator attaches to the burner there is a small nut that may be loose. If you look closely at this and turn the regulator (stove off and hose detached!) you may see the nut hat turns easily. Tighten it and make sure the regulator does not rotate too freely, but still turns to adjust when attached to the hose or the smaller gas cartridge, if using that. Test carefully after this.
Feb 06, 2009 | Coleman 2 Burner Propane Stove 5430E700
Stove top burners
It is not the cartridge. It is the ignition switch (sometimes called a cooktop switch) I found mine on ebay. In particular it is a faulty rear switch. Save your money on the cartridge.
Feb 10, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Camping, Backpacking & Hiking Logo
55 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
